Tips on the removal of handlebar grips?
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
Bought a used Terry Classic for the wife several years ago but she thinks it's too big. I bought a Handsome Mixte frame that I want to build up for her as a hybrid. The Terry has Campy 8 speed components with Campy thumb-shifters on steel riser bars. I'd like to buy alloy bars and transfer the shifters to them but I don't know how to remove the grips. They seem to be hard plastic with a foam tube around them. They are kind of nice and in good shape so non-destructive removal would be cool but any suggestions would be helpful. I can take photos when I find my camera if that would be helpful.
Never try to teach a pig to sing...
Compressed air blower underneath the edge of a grip, or in the hole in the end of the grip (plug the other with your free thumb).
Likes For wschruba:
Quoted: 1074 Post(s)
Liked 295 Times
If available, I prefer to use compressed air. Poke the nozzle under one edge of a grip, give a blast and a twist and off it comes.
If that isn’t available I’ll work a spoke between grip and bar, squirt some water into the gap, twist a little and work it off.
Quoted: 7348 Post(s)
Liked 2,465 Times
Compressors are not easy to come by.
Use a thin, long screwdriver and a bottle of spray cleanup fluid such as Fantastik. Pry the grip up a little and spray in as deeply as you can. Then move the screwdriver to the opposite side of the grip. Keep working the screwdriver in deeper so you can reach deeper with the spray. Eventually, you will lubricate the surfaces enough to be able to twist the grip off.
You can really use any liquid, even water. Oily things will take longer to dry, and some won't ever stop being slippery. Some claim that hairspray is best because it goes on slippery and turns to glue, but I have not found it to be better than water. Fantastik is really fine.
Quoted: 338 Post(s)
Liked 314 Times
Thanks guys. I do have a compressor and will give it a try. I'll try Tom's method if the air doesn't work. Can't try it tonight, the compressor and I will scare my wife's cats out of the garage.
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times
I always use some isopropyl alcohol. Poke a thin screwdriver, pour a bit, wait a few seconds and should come off easily. For tough installs I do the same.
Likes For 2cam16:
Quoted: 18373 Post(s)
Liked 4,508 Times
I have a Novara that has a hard plastic covered with what is now slime. I just tossed the bars aside as they didn't meet my needs. But, perhaps I'll play around with them later, although the "slime" is bad.
I think the problem with several of the methods suggested above is that they require space below the grips, which the hard plastic prevents. Shoving in a screwdriver would be more likely to crack the plastic.
The alcohol might help.
Bikes: Bike Friday NWT, Rans Stratus, Cannondale R500, trek 720 multitrack, Rockhopper
Quoted: 35 Post(s)
Liked 36 Times
Liked 2,465 Times
I find those to be so wasteful and expensive for what they are. For dusting out computers, I got a plug-in blower.
Quoted: 4201 Post(s)
Liked 3,857 Times
AndrewRStewart
AndrewRStewart
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 704 Times
Good to know you're nice to cats.
Jeff Wills
Jeff Wills
Quoted: 836 Post(s)
Liked 1,061 Times
Hard plastic grips may come off with some heat from a hairdryer or pour boiling water over them. Heat also helps to soften up most adhesives.
If you use compressed air, make sure you wear eye protection. I've had old grips explode with bits of plastic shrapnel flying through the air.
Quoted: 3375 Post(s)
Liked 5,513 Times
(The righthand grip unbolts with the throttle mechanism.)
Quoted: 338 Post(s)
Liked 314 Times
Tried drilling a hole in the end of one grip and then putting 100 psi through it with no movement. Then was able to get the grips to rotate after injecting first alcohol and then silicone spray under them using a very small screwdriver. Still couldn't pull them off until I put the air nozzle back on and blew the opposite grip across the garage. I used a washer to block the now open end of the bars and put the air nozzle in the washer's center. The second grip came off after repeated air and rotation by hand. Thanks for all of the suggestions. I had considered using heat prior to reading those suggestions, but didn't follow through: no hair dryer and concern that boiling water would ruin the foam.
Quoted: 805 Post(s)
Liked 704 Times
Jeff Wills
Jeff Wills
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
The grip flew so far I had trouble finding it
I'll never struggle again, thanks
Quoted: 338 Post(s)
Liked 314 Times
If you've used silicone on the grips, I would throw them away. There's no way you'll get them to stay on handlebars now. In fact, you should clean the handlebars thoroughly with alcohol so grips will stay put afterwards. Having a grip come off while riding is not a good thing at all.
wernst
Bicycle Mechanics
70
11-12-19 10:25 PM
joejeweler
Bicycle Mechanics
7
02-16-13 05:47 PM
