'Hook' rims vs 'hookless'?
Just looking at some carbon wheels, and the company mailed me this.
There are two versions for every model, hook, and hookless. If you are planning running higher pressure(over 80psi) you can go with the hooked version, otherwise, the hookless version is ok.
Are the hookless less safe? And, do they allow for easier mounting of tubeless tyres?
Quoted: 18883 Post(s)
Liked 10,646 Times
Hookless is for tubeless, and you won't be able to go with tires that aren't tubeless compatible without hooks. Your rims will be lighter and stronger though, particularly more impact resistant.
Quoted: 4717 Post(s)
Liked 1,882 Times
Hooked carbon clinchers don't have a big problem with cracking rim beads.
Hookless beads limit tire selection to tubeless tires only. That was deal breaker for me.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
This is what Boyd says...
My recommendation for people when they are trying to decide between the two is based on the tires and type riding they are doing. If you are low pressure (under 60PSI) and high volume (above 30mm on the calipers) then hookless is great. If you are high pressure and lower volume, go with the hooked.
https://www.velocipedesalon.com/foru...tml#post913029
Quoted: 20808 Post(s)
Liked 9,450 Times
^^^ What Boyd says. I wouldn't do hookless unless it was going to be a dedicated gravel wheelset.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Just go hooks. If it's even remotely used for a road purpose then go with hooks. Pushing even 60 psi on some hookless is pushing it. The tire tech isn't there yet but the rim tech is solid especially at low pressures.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Liked 10,646 Times
Yeah, I really thought there would be more options by now. It's not that big a deal for me personally because I found some tires I love ... but the selection really is pretty limited. And that also means prices are generally higher.
Liked 1,882 Times
It's probably not very likely to happen, but hooked rims give you the choice of using tubed tires if you have to(for whatever reason).
Liked 10,646 Times
Like if you get a puncture that won't seal, and the nearest shop doesn't have any tubeless road tires in stock?
Quoted: 4792 Post(s)
Liked 3,918 Times
Liked 10,646 Times
Yeah, that's what had to happen. And a dollar bill as a boot.
masi61
Bicycle Mechanics
3
02-19-18 06:06 PM
eyeheartny
Road Cycling
15
11-01-16 10:12 PM
qandaappraisals
7
02-10-16 02:57 PM
