Thinking about 11-speed
Quoted: 1528 Post(s)
Liked 718 Times
Campy early/late 11s compatibilty hack
Keep in mind that 2009-2014 shifters and derailleurs are not compatible with newer 11 speed parts. The shifters pull less cable. If you ever have to use a newer RD, there is a trick that improves the performance. Grind down the threads on the cable clamp bolt to the root, in the area where the cable contacts the bolt. This shortens the lever arm length and increases the RD travel.
