Mild adhesives
Bikes: 1975 Raleigh Sports, Cycles Toussaint Velo Routier, Yuba Mundo, Raleigh Sports (1970)
Quoted: 34 Post(s)
Liked 10 Times
Mild adhesives
My road bike has a chromed chainstay protector (it looks a lot like this one) and it is barely sticking to the chainstay. I'd like to secure it back in place, but I don't want to use anything that would potentially damage the paint or glue it down irreversibly.
What's a good adhesive for something that is not carrying any load and just needs to be stuck down enough to stay in place when the wind blows on it, but still be mild enough that the bond can be cleanly broken by hand?
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
3m makes some nice double sided bonding films. I use these for guitar repair, when I need to secure hardware with a strong bond that wont damage the finish of an instrument. You probably wouldn't need to cover the entire surface under the chain stay protector, to make it slightly easier to remove. Make sure to clean and prep both surfaces with rubbing alcohol or naphtha for good adhesion.
Quoted: 5774 Post(s)
Liked 2,573 Times
companies like 3m make adhesives with a wide spectrum of holding power. If the curvature of the protector matches the chainstay well, you could probably use one of the very low strength stick adhesives like the 3m post-it stuff. There are also heat activated glues where you'd heat the area with a heat g*n as you pressed the protector home, then heated it again to remove.
In any case, be sure to thoroughly clean the chainstay of any dirt or oil films so your light adhesive can hold.
FB
Chain-L site
FB
Chain-L site
Quoted: 4200 Post(s)
Liked 3,853 Times
I also find that heating up the stay and protector with a heat g*u*n or hair dryer helps to allow the usually flat protector to conform to the stay and not tend to pull up along it's edges. I do this with the Stay Tuff protectors on my own bikes. Andy.
Quoted: 1572 Post(s)
Liked 643 Times
I'd use 3M Trim and Badge adhesive. You can get it at auto parts stores. It's designed for that purpose.
Quoted: 1438 Post(s)
Liked 1,092 Times
If you apply rubber cement to ONE side only and put the parts together while it is still wet, it will hold well but be easily peeled off.
I also use spray artist's adhesive for light-duty, removable applications.
Don't forget the thin (not foam) double-faced tape as well.
Quoted: 427 Post(s)
Liked 339 Times
Liked 1,092 Times
Regular office rubber cement, not tire patch stuff, works like that. Putting it on one surface only turns it from permanent to "mild" and removable. You might have noticed that credit cards and the like are stuck to their accompanying letters with a similar adhesive.
The stuff in patch kits is vulcanizing fluid; it reacts chemically with the rubber to bond it. Not quite the same process as rubber cement.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
The peel-off stuff used to attach things like credit cards to paper in mailings is called fugitive glue. It often comes in hot melt form, but there are press-on "glue dots" available as well. Walmart and Amazon carry them. They may work well for what you want, assuming they're waterproof.
A couple dots of plain ol' hot melt glue could do the trick, too.
Cottered Crank
Bikes: 1954 Raleigh Sports 1974 Raleigh Competition 1969 Raleigh Twenty 1964 Raleigh LTD-3
Quoted: 8 Post(s)
Liked 11 Times
An adjustable-temp heat goone is much more handy than a hair dryer due to the true adjustability of the heat. HF has them for about $10-15
Cottered Crank
Quoted: 8 Post(s)
Liked 11 Times
Correct.
Very little sticks to well-cured automotive paint by actually bonding to it at the molecular level. Even paint doesn't stick to paint very well without being roughed up a little. If one takes a little bit of scratch-x or other polishing compound and buffs up the paint to a really nice gloss nothing is going to stick to permanently short of a two-part epoxy or something similar which could damage the paint.
A heat goone takes nearly anything off. it works great on automotive trim as well. It's what the pros use at autobody shops when they need to get it off without damaging it.
Quoted: 34 Post(s)
Liked 10 Times
