tire pressure ?'s
Old 05-07-16, 01:27 PM
ceelint
^that guy^
ceelint's Avatar
Bikes: '17 Wabi Classic, '86 Bianchi Vittoria, '92 C'dale R900 , '17 Trek DS 3
Quoted: 67 Post(s)
Liked 36 Times in 17 Posts
tire pressure ?'s
A buddy of mine races his bike and gets stuff from raffles all them time, he gave me some Origin8 Elimin8tor folding tires in a 700x28. With the weight of me and the bike it's roughly 230lbs and a tire pressure calculator says I need 104psi in the rear but the max rating on the tire is 87psi. 87psi just seems way to low. Could I safely add the extra 20psi?
ceelint is offline
Old 05-07-16, 01:45 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 4170 Post(s)
Liked 672 Times in 407 Posts
You won't need anywhere near 104psi in the back tire. I runs 28s exclusively, and have never run more than 85psi (and when I started riding, bike + rider weight = 265lbs.) I'm now a combined weight of 213lbs, and run 84psi F/R with Michelin Pro4 700x28-- but have run as low as 65psi in the rear on Schwalbe tubeless.
Start at 85psi for the rear, see how it feels.
DrIsotope is offline
Old 05-09-16, 02:36 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1269 Post(s)
Liked 121 Times in 83 Posts
You are probably safe at 104 psi but here's what I would do:
Inflate your tires up to 87 psi and ride it. If you find that you are getting frequent "snake bite" flats with 2 parallel slits, ease the air pressure up. If you don't (my bet) leave well enough alone.
Retro Grouch is offline
novemberhotel
13
03-03-16 03:34 PM
ModeratedUser150120149
Fifty Plus (50+)
88
08-03-14 01:26 PM
jskash
Hybrid Bicycles
6
05-18-14 06:34 PM
dpeters11
Hybrid Bicycles
5
11-13-10 03:58 PM
Inertianinja
Road Cycling
35
04-22-10 06:58 PM
