Suntour Barcons, Ever had a one fail **********???
Building my version of a bulletproof touring bike. Figured this question would fit better here than in touring section since more folks using vintage parts here.
So, has anyone here ever had a Suntour barcon fail?? Something break internally or wear out ? How about buggered after a fall?? I know about losing the lock nuts,
but wondering about an actual failure of the part.
Thanks
Thanks
feros ferio
Quoted: 1390 Post(s)
Liked 1,322 Times
No. These things are very durable and reliable. I have had them for years on my daily driver / commuter / general transportation bike, the UO-8.
I have also ridden for several years with a missing outer locknut, and have not even had to retighten the pivot screw.
After the set up put a peice of clear tape over the lock nut and it will not fall out.
Never had a set break on me.
But... Stupid me switched the levers into the wrong body and it would not move. Once back in the correct body, they worked perfect. Close as I've been to barcon problem.
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
I saw a set at our local co-op which were broken even though they looked great on the outside. Took some convincing to get the guys to not try to sell them. So yeah, they can break.
...but the 2 sets I have are 34 and 26 years old and both work great without any issue. I move the levers and gears change. I took the older set apart after buying them to clean everything and de-crud the insides. The newer set is Accushift and doesnt come apart from what I can see.
If you take them apart, lay each component out in order of how they have to go back in because the number of spacers is mind boggling.
Bikes: 1972 Gitane Super Corsa Frankenbike, 1972 Motobecane Le Champion, Motobecane Grand Jubile, 1980 Bianchi Campione di Italia, 1984 Paramount, Trek 620, Trek 720, Cannondale 3.0, Kestrel 200sci, Kestrel 200EMS, Bob Jackson Tandem
Liked 5 Times
A trick I learned may be more durable... Put a couple drops of clear fingernail polish on the nut/bolt. It will act like glue and if you ever need to take the thing apart, it is easy to undo.
Quoted: 293 Post(s)
Liked 218 Times
I haven't had a single issue with the pair that I am using.
Quoted: 77 Post(s)
Liked 19 Times
Put over 100,000 mileson a set; transferred them from one of our tandems to the next one.
Excellent even when I took 'em off index shifting so I could use a extra cogs.
I've had at least two dozen sets. Never had one fail.
+1 Lock nuts disappear. I would probably just use a stainless nylon lock nut instead.
And for a long tour, I'd probably use lined SIS housings and stainless cables. There was a thread earlier that the original SS wound housings do not like SS cables. They seem to shift better with galvanized cables.
Thanks for the feedback. I knew they were good. But it seems they are REAL GOOD!
Quoted: 3803 Post(s)
Liked 6,639 Times
I've been using SunTour barcons since 1987, and the only problem I've had was losing one of those round outside nuts on a ride and enduring plenty of ghost shifting as a result.
Question: how much cable can they pull? Meaning, will they pull enough cable to move a derailleur through a 10-speed cassette?
Bikes: Miyata 610 , Schwinn circuit, Bianchi C2C, Quattro Assi , 87 Trek 1500, Felt F1X, Burley duet, LHT and a few more
Quoted: 10 Post(s)
I know I used them with a 9 spd setup. Wasn'tsure it would work but it did.
Quoted: 786 Post(s)
Liked 517 Times
That's the only bit I've ever seen break. And only due to rust/neglect on bikes I've bought for parts.
I've had the same set of SunTour barcons on my trusty old Fuji since late 1976, and closing in on 50,000 miles. I've only lost one of the tiny screws (item 11 on the diagram below) that hold the ratchet cover in all that time.
The shifter still worked fine, just rattles/buzzes while riding. It had been that way for 15 years before I found a replacement screw.
I've installed used sets of SunTour barcons on all of my other road bikes. Well, the last set will be getting installed going on my recently acquired Miyata 710 that I keep in Phoenix when I go out there again in a couple of months. I'm so used to riding with barcons that I don't feel comfortable riding anything else.
...and here they are in real life: Suntour Barcons - courtesy of Stronglight. I've used this more than once when doing repairs. Between this and the schematic posted above, I think we've got it covered.
Still learning
I've had one I had to replace as it would not stay at the gear I wanted, not matter how tight the lock nut was.
Bikes: Too many to list, all titanium or steel.
Quoted: 7 Post(s)
Liked 8 Times
I've got them set-up on 6, 7, and 8 speed clusters and found 8 speed to work, but had to make sure that I had the limit screws on the derailleur just right, and no slack in the cable at all on the small cog.
Quoted: 786 Post(s)
Liked 517 Times
