Purple Loctite or alternatives?
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Here is my situation: I have a dropper seat-post that has an adjustment knob that screws down onto the top of a shaft. Think of a bottle cap, roughly 1" in diameter, but the threads are fine and everything is Al.
It needs to be adjustable by hand, but stay put when riding. In the past it did just that, but the after 15 years, the threads (Al on Al) must be wearing out, and it turns too freely, and goes out of adjustment from vibrations.
So I need something that will keep it put, but still let me turn it by hand on occasion. It does not need to be very tight, just a little.
Is purple Loctite (222) the ticket? I understand that it is a very light holding formula, but after I move the knob the first time, will there still be some grab to it?
I was thinking of putting something like a silicone caulk on the threads, but not sure if that would just end up a mess.
Thanks for any info.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 697 Times
I use the 222 on gunstock screws for spring powered pellet rifles. These are famous for vibrating screws loose. The 222 is nice because is stays a bit gummy and one can retorque on occasion. That being said, I’m not sure it would be ideal for an adjustable bolt that is moved often. I think I may have also read that it is for smaller screws. Might work though.
Quoted: 1438 Post(s)
Liked 1,092 Times
Try Vibra-Tite VC-3. It is intended to be adjustable but help hold threaded parts from vibrating loose. https://www.vibra-tite.com/threadloc...-3-threadmate/
Likes For dsbrantjr:
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
Would Teflon tape work? Like the stuff used for plumbing.
It might become a maintenance item. Maybe replace it when you live the chain. But not as often as you inflate the tires.
Could be too much of a hassle.
Advanced Slacker
Liked 2,537 Times
The problem is that tape is made for threads that are already rather tight fitting. It took a lot of wraps to get it thick enough to do anything, and at that point it would start shredding and bunching up when I threaded the knob on.
Likes For Kapusta:
Advanced Slacker
Liked 2,537 Times
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
The more I read dsbrantjr's stuff, the more I'm impressed. That Vibra stuff looks like your answer.
Likes For WizardOfBoz:
Quoted: 583 Post(s)
Liked 697 Times
I’ve also seen vibra tite praised, so it sounds like either would be good especially if seldom adjusted. I had to order online for the 222 as no one seems to carry it. I never use the blue loctite now just the purple. Good stuff
Advanced Slacker
Liked 2,537 Times
Liked 1,092 Times
How high is up? I have not done any comparative tests vs Loctite varieties, since they are intended for different purposes. The name kind of describes its function.
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
I'm the anecdote.
Liked 1,176 Times
Advanced Slacker
Liked 2,537 Times
Likes For leob1:
Advanced Slacker
Liked 2,537 Times
