1994 Marzocchi xc 500 -Steerer tube
vintage Bianchiist
Bikes: Bianchis, 84 Superleggera, 86 Giro, 87 SportSx, 87 Campd'Italia, 87 Limited, 88 Proto, 95 TSXChorus, 94 TSX105/DAax, 94 Super Grizzley RC, 94 Genius Record, 06 Pinella Boron, 18 Volpe Avanti, 00 Megapro ST Veloce00 EM Strada OS
Quoted: 35 Post(s)
Liked 13 Times
Hi
I am wondering, in regards to the 1994 Marzocchi xc 500, and steerer tube compatibility. I want to buy these vintage shocks for a specific build which requires a 1 inch steerer tube. So I found some forks with a 1 1/8 steerer, and a replacement steerer tube that is 1'. Though the listing states the steerer is for 1996-2001 bombers (bolt on same as the 500's), Does anybody know if they are compatible?
vintage Bianchiist
Quoted: 35 Post(s)
Liked 13 Times
Not sure if the older crown will take the newer steerer, but the correct shim for a 1" Marzocchi steerer is almost identical to this: https://www.amazon.com/RST-1-1-steer...ct_top?ie=UTF8
The RST steerer tubes and shim are really close to old Marzocchi spec, close but not perfect in my experience. I think I have an older Marzocchi crown in the parts bin to test the theory on, curious myself if that will work.
