SCT trailhead addresses???
Looking for the street addresses for the trailheads. Something i can enter into a gps, i looked at the SC/CL map website but i don't see any street addresses.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
You can plot your own using Google Maps. Just right-click on the point on the map that you want to plot and then choose "What's here?". A small window will pop up with the GPS coordinates. This is what I usually do when planning a ride on a new-to-me trail.
Have fun on your ride.
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
Go to Google Maps and type in Silver Comet Trail. Use the menu to select "bicycling". The trail will now be defined as a green solid line.
As you navigate across the map you will see trailheads marked with a "pin" along with address and plus code.
Thanks punkn, but i know where the trail is, driving to the trailheads is the issue. i've taken to using the street address of nearby businesses on the map. It just surprises me that i can't find actual street addresses listed anywhere. Putting in at the same location was growing repetitive, but now i have a few to choose from. Thanks for the help.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
In post number 3 @Juan Foote explained how to find the addresses.
All you have to do is click on the pin for each trailhead on google maps and the address is right there.
Likes For TimothyH:
