Fizik Aliante Sport or Ti or Carbon?
Will I notice a big diff between the Sport and the higher end models or is it simply weight?
Pretend Racer
I have the Sport (with Ti rails) on one bike and the Ti on the other. I don't notice much difference at all. Possibly the carbon shell on the Ti may prove more durable than the plastic shell on the Sport.
As for the carbon rails, I can't see the point to that...I would think Ti would give a better ride (I'm pretty happy with it).
It is fantastic.
Bikes: 05 Specialized Allez Elite; 06 Fuji Team Pro
Sport: Nylon, no Wing Flex insert in the base, manganese or titanium rails (different versions available)
Delta: Nylon, Wing Flex insert in the base, manganese or titanium rails (different versions available)
Gamma: Nylon, graphite Wing Flex insert in the base, titanium rails
Ti: Carbon(?), carbon(?) Wing Flex insert in the base, titanium rails
Ti: Carbon(?), carbon(?) Wing Flex insert in the base, carbon rails
Edited.
Edited.
SNARKY MEMBER
I have a Sport on one bike and a Gamma on the other. I love the Sport. I have done 2 centuries on it and several metrics. I really can't tell the difference between the 2. I have only had the Gamma for less than a month. I haven't racked up any serious mileage on it, yet. I don't think they make the Sport anymore, but you might be able to get one on Ebay. I got mine for $35.
Dirt-riding heretic
Bikes: Lynskey R230/Red, Blue Triad SL/Red, Cannondale Scalpel 3/X9
Quoted: 5 Post(s)
Liked 8 Times
The carbon-railed version is not recommended for the big boys by my n=1 experience. I broke the rails on my old Aliante.
"Unless he was racing there was no way he could match my speed."
if x=byh then x+1=byn
Bikes: See signature
I have an Aliante Ti, Aliante Delta and Aliante sport models. As opposed to what Voltman states, the Delta does have wing flex. I have also found no weight difference between the Mg and Ti rails. In any case, I have to agree with CardiacKid, even the Sport is a great saddle on long rides, and I don't think the higher end Aliante's are really worth the extra money. If you haven't tried an Aliante, buy one on Ebay for about $50 and try it out.
'00 TiSports Titanium - DA 9 speed------ '01 KHS Flite 800 - DA/Utegra 9 speed mix
02 Ellsworth Flight - Ultegra 10 speed -.'03 Basso Coral - Ultegra 10 speed
'03 Specialized Allez Pro - DA 10 speed .'04 Scattante CFR Limited - DA 9 speed
'05 KHS Flite 2000 - Ultegra 9 speed -... '06 Flyte SRS-3 - DA 9 speed-------
'05 Serotta Fierte - Utegra 10 speed--..-'07 Pedal Force RS - SRAM Force
It is fantastic.
Originally Posted by blandin
I have an Aliante Ti, Aliante Delta and Aliante sport models. As opposed to what Voltman states, the Delta does have wing flex. I have also found no weight difference between the Mg and Ti rails. In any case, I have to agree with CardiacKid, even the Sport is a great saddle on long rides, and I don't think the higher end Aliante's are really worth the extra money. If you haven't tried an Aliante, buy one on Eba for about $50 and try it out.
Nope - just the Delta and above.
It is fantastic.
The Delta has what appears to be a fiberglass, or something like it, shell and it has wing flex, the Sport is a solid plastic shell without wing flex. Since I don't have a Gamma, I can't speak to that model. The weight difference is negligible.
1/2 man,1/2 bear,1/2 pig
Bikes: .
This is an old thread, I know, but I was visually comparing the Gamma and the current "carbon' model (Ti rails w/carbon shell). I notice from underneath the Gamma has a white (I think fiberglass) woven relief section in the center, and the carbon has a yellow (Kevlar) relief section. The Kevlar relief section seems wider, and I am wondering if it would make it more cushy...perinneally speaking....
