1996 Marin Eldridge Grade suspension fork recomendation w/ canti brakes
Old 07-04-11, 11:17 AM
upstairsdave
Greetings,
I am looking for a NOS suspension fork for my 1996 Marin Eldridge Grade bike, The brakes are cantilever brakes. The suspension travel is an 80mm fork for this bike.
I read where someone suggested a 1997 Manitou Pro-C fork. Has anyone iinstalled a suspension for on their Eldgride and what fork did you use? The Headset is 1 1/8" threadless Dia-Tech alloy.
Thanks
Dave
upstairsdave is offline
Old 07-04-11, 11:36 AM
mechBgon
mechBgon's Avatar
Liked 6 Times in 5 Posts
If you crank the travel down to minimum, one of these shouldn't upset the geometry too radically: https://aebike.com/product/rockshox-t...k6076-qc30.htm Slap on a $15 Acera V-brake and a compatible brake lever if necessary.
mechBgon is offline
Old 07-04-11, 11:51 AM
jimc101
Quoted: 453 Post(s)
Liked 104 Times in 87 Posts
If you read through the recent post's, this exact question was asked a few days ago https://www.bikeforums.net/showthread...n-Fork-Upgrade
For an answer, the fork you have suggested is long OOP, just get a 80-100mm travel current fork, you will probably need discs, unless you can find a fork with rim brake mounts, if you go for rim brakes, ditch the Marin brakes they were useless in '96, as mechBgon any Shimano v-type brake will do.
jimc101 is offline
J.Higgins
Bicycle Mechanics
10
07-31-19 12:51 PM
snuggiebear
Hybrid Bicycles
22
06-05-17 12:41 PM
Telly
Bicycle Mechanics
16
11-14-13 08:58 PM
upstairsdave
Bicycle Mechanics
8
07-04-11 10:56 AM
Glottis
Bicycle Mechanics
2
04-13-10 05:43 AM
