What cause's rim tape to move?
Old 05-18-12, 06:36 PM
ben4345
Kitten Legion Master
Bikes: Fuji silhouette, Dawes SST-aL
Just fixed a flat, couldn't find any puncture, check the inner tube. Found a very small hole where it would lay against the inner rim. Checked my rim tape, and there is was, some of the spoke hole showing, probably just enough that it rubbed over time and cause my flat.
Does rim tape shift over time, or is just clumsy tire changing technique? Is this normal?
ben4345 is offline
Old 05-18-12, 08:34 PM
xenologer
Quoted: 237 Post(s)
adhesive velox rim tape shouldn't shift
rubber or nylon band style tapes can slide around when riding with underinflation
xenologer is offline
Old 05-18-12, 10:38 PM
ben4345
I always stay within 5 PSI (120 psi max), so I am a little unsure what happened.
But I am going to pick some velox rim tape when I got to my bike store.
ben4345 is offline
Old 05-19-12, 03:23 AM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 488 Post(s)
Liked 48 Times in 42 Posts
High pressure can cause narrow rim tape to lose an edge inside a spoke hole.
Kimmo is offline
driuseppe
Cyclocross Racing
6
06-21-08 10:32 PM
substructure
Road Cycling
22
06-28-07 10:43 AM
