Road bike, 8 to 9 speed upgrade
I am trying to upgrade a cheap road bike with mixed mechanics for trainer use, in order to obtain a smoother shifting progression. I am wondering whether the changes below will work (as far as I know, everything is Shimano compatible):
Actual:
Crank set: Pro wheel triple, with Shimano Claris derailleur
Rear derailleur: Microshift 8 speed
Chain: Shimano 8 speed
Right shifter: Shimano Claris (8 speed)
Cassette: Sun Race 8 speed, 11-25
Upgraded:
Crank set: No change, Pro wheel triple, with Shimano Claris derailleur
Rear derailleur: No change, Microshift 8 speed
Chain: No change, Shimano 8 speed
Right shifter: New, Shimano Sora ST-R3000 STI, 9 speed
Cassette: New, Shimano CS-HG50-9, 9 speed, 12-25
So, will this upgrade work?
Actual:
Upgraded:
Likes For bboy314:
Likes For Crankycrank:
Mother Nature's Son
Quoted: 862 Post(s)
Liked 1,457 Times
Likes For delbiker1:
Quoted: 4581 Post(s)
Liked 1,729 Times
I would just go to a closer ratio cassette to get a better progression (12-23). Are you actually using your lowest gears on the trainer?
don't try this at home.
Quoted: 988 Post(s)
Liked 530 Times
I, too, am not sure of your question. Is it:
1. closer shifts, with smaller speed changes for the same cadence?
Do you want to change the slower small chainring speeds, or the faster big chainring speeds? For my road bike, I looked for closer shifts at fast-for-me speeds. Climbing could tolerate larger cadence jumps.
or
2. smoother, faster shifting performance?
Are you sure it's a Sunrace 11-25 8 speed? That seems to be unusual when I searched for cassettes online.
or
Quoted: 1634 Post(s)
Liked 1,829 Times
That R3000 right brifter will shift the 9 speed cassette perfectly fine. Just keep in mind that the R3000 brifter , although very similar in appearance as your current R2000 8 speed Claris brifter, is black in color. Your Claris is dark grey. Depending on your level of OCDness it might drive you nuts to see mismatched color brifters in front of you like that.
Likes For icemilkcoffee:
By the way, do you know how how CS-HG50-9 cassette is built? Does it have independent cogs, or is there a block of a few cogs? If independent, i assume that one could play later by mixing cogs from other Shimano cassette?
or
or
I have just noticed that Sun Race does not have 8 speed 11-25 on website (at least not now). Maybe they had in the past, or maybe my cassette is also a mix - it looks very similar with Shimano.
Liked 1,729 Times
Clark W. Griswold
Quoted: 4488 Post(s)
Liked 4,160 Times
I wouldn't put much money towards a claris equipped bike if it is functional I would just ride it especially if it is on trainer duty the only thing I would do is keep the bike clean and replace wear items as needed because they are worn. If you need something different gearing wise I would consider a closer range cassette.
If you are deadset on throwing money away make sure to also get a 9 speed chain as well however again I wouldn't put much towards the bike.
In the case of the things like Claris and Tourney just save the money and put it towards the bike you want and keep this one safely functional without spending too much on it. If you keep it well maintained it will last longer.
The actual 8s cassette is built from 11 to 25 with 2 teeth constant increment. I can’t find another optimal 8s cassette to assure an interval of 1 tooth and to preserve 25t for some climbing. I found that 9s 12-25 would give an interval of 1 tooth: 12-13-14-15, at the expense of 87 EUR and dismissal of actual 11 teeth which is rarely used. Plus 16 EUR for new chain (which should be anyway changed soon).
It would be interesting to know whether I can play with mixing any cog with (let’s say) 14-25 Shimano, for an even larger 1 tooth interval (and removing 25t), but this is just for curiosity, since further investment would be “overkill”.
Liked 1,729 Times
12-13-14-15-17-19-21-23-25T
Shimano 8 speed HG-50:
12-13-15-17-19-21-23-25
13-14-15-17-19-21-23-26
All of these are like $20. Are you sure you really need to change your shifter to get gears for the trainer? The 13-26 seems like the perfect solution.
Likes For Kontact:
Quoted: 1110 Post(s)
Liked 1,050 Times
Very rarely the smallest cog with big ring on descents, but I use the next ones, especially with the middle ring. I think that 25 would still be of use while climbing. Besides, 12-23 was only available from SRAM and I did not want to make a full mix.
Quoted: 988 Post(s)
Liked 530 Times
What are the tooth counts for the three triple rings?
The rings determine what speed ranges are usable for each chainring. And for your typical cadence.
For example, here's a Shimano 8 speed 12-21 with a 30, 39, 52 triple. And flat road spinning cadences, mid 80s to 90s rpm.
Mike Sherman's gear calculator link for this setup. Big chainring in blue, middle in black, small in red.
8 speed 12-21. The yellow highlight is at your target speed range for closer shifts. That's approx 17 to 22 mph -- right where I also want close shifts.
But you can't go much faster in the middle ring without a front shift, or much slower in the big ring without a front shift.
8 speed 13-26. This works pretty good for the 39 middle ring, but it can't go much faster without a shift to the big ring. Those speeds are right in the middle of the big ring, but the speed jumps per shift are larger.
Likes For rm -rf:
I played with the chart. 13-26 looks good for the speed range but has 2 drawbacks. One is the max speed: the crank set is 50/39/30 and the max. speed with 13t at 92 cadence would be 44km/h (too small for the trainer, where speeds are a little bigger than real life). The second is that the middle ring would be used long time with the smallest cog and with no much reserve for a short burst.
The 9 speed 12-25 seems to solve both topics.
Here's 12-25 9 speed Shimano HG-50:
