Newbaums Cushioned Cloth - Too thick to wrap from top down?
Quoted: 837 Post(s)
Liked 1,080 Times
I've always used Newbaum's cloth wrap, which is easy to wrap from the top down. Has anybody used their new cushioned wrap yet? Is it too thick for this method?
Bikes: a few that I can't recall
Quoted: 342 Post(s)
Liked 299 Times
Although I detest "bottom up" wrapping, (anything that requires more tape to finish is blasphemous), I think the NewNewbaums is so fat and contoured that you might have "peeling" if you wrap top down.
I bought some and haven't used it yet.
Likes For Reynolds 531:
Quoted: 1105 Post(s)
Liked 1,326 Times
Cut a 1" bit of innertube and roll it up the bars to the stem, wrap your tape, and unroll the bit of innertube over the free end.
The point of wrapping from the bottom is to prevent the free edge of the tape fraying from constant hand pressure. Wall-art bikes don't need this, of course, they instead need to show off the pretty little logos at the centre of the bars.
Likes For oneclick:
Quoted: 603 Post(s)
Liked 1,062 Times
Have yet to come across tape too thick to top down wrap. I too detest bottom up wrapping, but did buy a bigger rubber mallet to get the end plugs in.
Tim
Tim
Likes For tkamd73:
Quoted: 342 Post(s)
Liked 299 Times
Don't use "more tape".
That's a good idea.
Quoted: 837 Post(s)
Liked 1,080 Times
Well, I've received it, and it is indeed too thick to wrap top down. You get ridged layers. I started and had to give up a few wraps in and go bottom up with some electrical tape at the ends. It's thicker than I imagined it would be. I've just ordered two rolls of my trusty regular cloth wrap. It was worth a shot, and I will say it's comfy, but I'd rather wear gloves or do two rolls of regular cloth if vibrations etc. were an issue. But I've never had an issue with cloth except for on much longer rides.
Likes For polymorphself:
