Did EvapoRust change?
Bikes: many
Quoted: 1444 Post(s)
Liked 1,390 Times
I purchased a new jug of EvapoRust from Amazon and went to use it today. Previously, it had a yellow tint when coming out of the bottle. This time it was colorless, like water. Has anybody else gotten a jug recently with no color?
Bikes: many
Liked 1,390 Times
I also sent an email to Evapo-Rust. They replied very quickly:
So, it's all good.
No, it's the same formula. The solution is basically clear when it is produced. It changes color with age. The clearer the solution, the fresher the batch.
So, it's all good.
Quoted: 809 Post(s)
Liked 1,022 Times
Thanks for that. Now we all know.
Quoted: 3808 Post(s)
Liked 6,678 Times
Ah, good to know that I won’t get it mixed up with the mason jars of urine I keep stored in the basement.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
Liked 6,678 Times
Likes For nlerner:
Quoted: 2363 Post(s)
Liked 1,749 Times
^^^^ From the Department of Too Much Information....
Liked 2,180 Times
Quoted: 837 Post(s)
Liked 1,080 Times
Just wanna say I love EvapoRust. Also, just tried the gel for the firs time for some hard to reach spots on components I didn't want to remove and soak, works just as well.
Likes For polymorphself:
Quoted: 887 Post(s)
Liked 335 Times
I have read on the internet that @nlerner uses urine to remove rust. It must be true.
Fillet-Brazed Member
I've read EvapoRust works via something called chelation, which you might also find somewhat interesting:
How does Evapo-Rust work?
Unlike other rust removers that use some type of acid to remove rust, Evapo-Rust works without acid. It will not attack the base metal, and it is safe to use. Evapo-Rust works through selective chelation. This is a process in which a large synthetic molecule forms a bond with metals and holds them in solution. Most chelating agents bind many different metals. The active ingredient in Evapo-Rust bonds to exclusively to iron. It will remove iron from iron oxide but is too weak to remove iron from steel where the iron is held much more strongly. Once the chelating agent has removed the iron, a sulfur bearing organic molecule pulls the iron away from the chelator and forms a ferric sulfate complex which remains water soluble. This frees the chelating agent to remove more iron from rust.
Liked 6,678 Times
Quoted: 887 Post(s)
Liked 335 Times
Oh, I just use it to toughen up my hands after reading about it on the internet.
Likes For dweenk:
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,059 Times
speaking of chelates/chelation, I recently tried a blackstrap molasses solution (maybe a 1:9 dissolved in warm water) and soaked some badly rusted brake parts for 2 days (AFTER a 2 or 3 day soak in white vinegar which had not given me desired results).MUCH happier with what the molasses did, MIGHT be it was helped by having vinegar soak first but I think this will now be my go-to. I also had used Evaporust on a few bolts before the white vinegar and even tho had been pleased enough with Evapo, now I'm a molasses convert! It is Said to work by chelation, maybe so....in any case YMMV
Liked 1,749 Times
^^^^^^ Hmmm, I wonder what a 10% solution of blackstrap molasses in vinegar would do.
Bikes: Numerous
Quoted: 1676 Post(s)
Liked 3,089 Times
When the worms show up in the urine jars, you have problems on several levels.
Liked 6,678 Times
Likes For nlerner:
Likes For smontanaro:
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
There are three products that would crash my world if they change the formulas from their current iteration...they are perfect as is...
1. Simple Green...
2. Mothers aluminum polish...
3. Evaporust...
I can't take too much more change in the world.
1. Simple Green...
3. Evaporust...
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
You're not wrong.
Commence to jigglin’ huh?!?!
Edumacator
Liked 3,119 Times
Liked 1,749 Times
Quoted: 288 Post(s)
Liked 329 Times
I've found that the best way to remove rust is vinegar and whiskey. First I pour some whiskey into a glass and then I drink it. Before long I can't remember what the vinegar was for.
Likes For jethin:
