I want to put a 26" rim I have lying around on my Moto Track...
I go I go I go I go I go
I want to put this 26" rim (from my Raleigh hybrid) onto my Moto Track-
And am wondering if these tires will fit the rim?
https://cgi.ebay.com/BRAND-NEW-WHITE-...#ht_500wt_1154
https://cgi.ebay.com/BICYCLE-TIRES-WH...0#ht_676wt_911
https://cgi.ebay.com/26X1-3-8-COLOR-W...ht_2994wt_1137
The rim used to have a 26x1.95 tire on it but I slayed it.
Or if anyone has another place I could get a 26x1" tire for cheap ($20-$30ish) please post. My LBS has one for 50 but that's more than I wanna spend on one tire, just for messing around with the look of my bike. Although I don't mind spending $50 for a pair.
I think the (stock) fork could take a 1.25" wide tire, but I'm not sure if it can take something wider than that with the 26" rim on it.
Last edited by Cglenny; 08-22-10 at 03:23 AM. Reason: Err, fixed some grammar so's easier to read.
inb4 criticism on barspins, saddle to bar drop, drop bar positioning.
just want to say that its funny that all those tires you linked dont even have brands, except for the last one, but theyre still pricey.
26" tires are apparently rare and pricey when it comes to thinner sizes like 1". I'm just looking for something cheap right now as the budget allows.
What u mean? I don't comprende.
Liked 6 Times
They won't fit. The rim used for 26 x 1.95 is the MTB standard 559mm. The tires you are looking at are for the old 26 x 1 3/8 standard, which was 590mm. Not even close.
However, there ARE lots of other tires specially intended to fit MTB rims and offer lower resistance...several threads on "slicks for MTB", "slicks for knobbies" etc.
Here are a few I found on Amazon in just a few minutes browsing which will fit your rims:
https://www.amazon.com/Cheng-Shin-C78...2471245&sr=8-1
https://www.amazon.com/Kenda-Kwest-ti...f=pd_sbs_sg_18
https://www.amazon.com/Avenir-Streets...f=pd_sbs_sg_22
But the real reason: SLOPING TT!!!!!!
Actually, it's the same answer you get when you answer the question "What is the meaning of life?"
The answer being: Happiness!
Or, for those people with a glass of water that is half empty sitting on their desk, the exact point is to annoy them!
But I think it's a combination of all of them.
But the real reason is because I like changing things.
(Sloping TT...)
Ok, so I need 559mm, so this tire should fit right?
https://www.sears.com/shc/s/p_10153_1...&blockType=G20
See, but I like the forward sloping tt like the Merlin. Looks better. More aggressive. More faster!!!
Backward slope reminds me of the look of my Raleigh Venture 3.0, which was uncomfortable, slow and heavy and goony imo.
A slight backward slope isn't a big deal, I like the look of my bike stock, but I think flat/forward slope looks better.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 763 Times
To each his own, but to put a 26" wheel in a fork designed for a 700c wheel with a huge gap between the top of the tire and the fork crown looks even goofier. Not to mention how this will affect handling / steering.
Your cog is slipping.
Bikes: Pake,Shogun,Nishiki,Motobecane
Or you could keep this one functional and search e-bay for a funny bike.All the sloping a person can handle.
Walmart carries tires/tubes for old 26" road wheels. I don't know if they will have any that are skinny enough and they probably suck pretty hard, but they are there.
Constant tinkerer
You could get a 26" rigid fork from a MTB. Then you know it'll fit. Or a suspension fork... And have yourself a sloping TT-fixed-mountain-road bike with drops. Haha.
nubcake
Bikes: Surly Steamroller '10 53cm, Kink Gap bmx '09
If your not looking to spend a lot of money because your on a budget, just put the original front wheel back on and deal with the sloping tt. Now with the money you saved you can buy yourself a front brake.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,645 Times
I wouldn't do what you're doing, but hey, I have put too short rigid forks on suspension ready MTB frames before. The pedalstrike is exhilarating! It ain't so bad since I put a 2.1 on front and a 1.5 on the back, though.
Here are some local options (over by Portland Airport)
Tom Slick 1"
https://www.biketiresdirect.com/produ...lick-comp-tire
Conti Sport Contact 1.3"
https://www.biketiresdirect.com/produ...6-inch?ss=3090
Or the grandaddy! Strait pimpin gold tires that'll prolly only last 100 miles on pavement. You'll probably be looking for shorter cranks, smaller pedals or will have put your other wheel back on by then, anyways, tho.
Conti Ultra Sport Hometrainer (1.75" tho, might not fit yer fork)
https://www.biketiresdirect.com/produ...-inch?ss=16884
Oh, and the Pasela you linked from Sears should fit, too.
Tom Slick 1"
