Priority Bikes launches folder
Bikes: 1999 Bike friday NWT, 2009 Bike Friday Tikit, 2023 silverock Dewy, 2008 Dahon Smooth Hound, 2023 Litepro Trifold
Quoted: 194 Post(s)
Liked 232 Times
Standard double folder with Shimano Nexus 7 speed IGH and carbon belt. What do you think?
https://www.prioritybicycles.com/pro...eid=bdd77dfbbb
Likes For jfouellette:
Looks like a solid commuter.
A bit boring though.
$800 bucks seems a bit of a steep price, but I guess a belt drive and internal gear hub add significantly to the cost. The quality of the finish and the welds look nice in the photo. More precise specs would be nice.
A bit "meh" from my point of view, but for someone looking for a dependable commute bike it might be a total delight. I've definitely seen much worse, but it's hardly anything to get excited about.
Quoted: 578 Post(s)
Liked 665 Times
$799 is a great price for a folding bike with a 7-speed IGH and a belt drive.
Is it valid only for a limited time?
Palmer
Quoted: 1677 Post(s)
Liked 1,837 Times
Roll when folded?
Palmer
Liked 1,837 Times
Odd they left off a front carrier block. That's like 3.7˘ production cost.
Straightforward enough with many bifolds, but not with the way Priority chose that skew-angle front wheel fold.
probably not like many folding bikes
Likes For tcs:
Disco Infiltrator
Quoted: 3130 Post(s)
Liked 2,111 Times
Prioritys thing is always low maintenance and ease of use, so familiar stuff from this forum about compactness or wheeling folded might not have been high on their list, compared to the belt drive and a really solid easy latch
Genesis 49:16-17
Genesis 49:16-17
Bikes: Surly Big Dummy, Priority Classic Plus Gotham-Edition
Quoted: 12 Post(s)
Liked 14 Times
I like the smaller frame tube compared to a lot of the bi-folds I see. It would need a CDX belt (rated to -4 Fahrenheit doesn't cut it in Wisconsin) and probably a dynamo hub to get me to bite. I'm also a little hesitant about their frame quality and finish (see for example the crooked rear fender in the promo shots), as well as how loose they are with the all-weather claims, which keeps me from wanting to spend $800 one of their bikes knowing that I'll be putting hundreds more into it right away. A Classic Plus Gotham Edition is my primary commuter. I got it for $380 used in 2020, and am happy with it for that price, but buying it new would be harder to swallow. I've had a rear rack, fenders, a front wheel built around a dynamo and studded tires in the winter. I also have a Start 20 we bought new for my eldest. On both bikes, I have a really hard time getting the rear wheel vertically centered in the sliding dropouts. Perhaps it's user error, but I feel like it shouldn't be so difficult. I am glad they went with rim brakes for the folder. That helps keep me interested. Based off my experience with the Nexus 3, I think the 7 is a good choice for this bike. I'm curious what the gear range looks like.
55+ Club,...
Bikes: 9+,...
Quoted: 1129 Post(s)
Liked 857 Times
Carbon Gates belt drive, 7 speed IGH, not too heavy, and currently $50 off ($749 I believe). It's not a bad deal for a commuter bike. Personally I'd have liked to see a higher weight capacity (only 230lbs), so it can handle some kit on it. Still, solid deal IMO.
Palmer
Liked 1,837 Times
Likes For tcs:
Quoted: 12 Post(s)
Liked 14 Times
Thanks! That looks plenty useful for me. I had it in my head that there that calculating things with the belt drives wasn't as straightforward as using sprocket teeth the same as a chain drive. Not sure where I got the idea, and it seems silly of me...
Thanks for posting this. My commuter is a Priority Continuum Onyx and, for the most part, I'm very happy with it. I cruise their offerings from time to time out of curiosity, but I had not seen this. For many years, this was exactly the configuration I wanted, yet I couldn't justify the cost for the available options. As a compromise, I had a Dahon Mu Uno for several years, briefly with a two-speed rear hub, but ultimately decided to part with it. I don't currently have as much need for a folder, but I hope this sticks around for a while because as soon as I do again, I will definitely get one of these -- it seems like a very good value to me given that it's pretty much everything I've been wanting (the Mu Uno cost almost as much, but that was a single speed and without fenders and a rack).
Palmer
Liked 1,837 Times
The fold is a hot mess.
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 137 Post(s)
Liked 309 Times
29 pounds for the current setup is not bad and the rack and fenders are removeable, saving maybe a pound. Belt drive is very nice.
55+ Club,...
Bikes: 9+,...
Liked 857 Times
Worth keeping an eye on, since Priority seems to expand their offerings with time and if this is successful, maybe they'll do an upmarket one, e.g., with Alfine hub and disk brakes.
Likes For tds101:
It is a little bit... However I have a folder like this. If you move the sandbar setup to the other side of the wheel, I can easily squeeze all the components in between the two tires. I strongly suspect that it can be done with this bike as well. It would make it more compact and easier to travel with. It looks like a good bike. For $800 I think you might be able to find something a couple of pounds lighter, but I love the internal gear and belt drive. I wish I could put a belt drive on my bike!
Palmer
Liked 1,837 Times
Priority didn't have to invent anything, just copy what others worked out years ago:
Wheels parallel, handlepost between wheels, cables tucked up, rollable when folded.
Stowing in an aircraft, boat, RV...or an apartment closet!...when centimeters count? Boarding crowded transit? Those intermediate distances one confronts with a folding bike when it's further than you want to carry, but not far enough to unfold? The Priority fold fails on all these.
I don't think they really did their folding bike market research. Priority's only design bullet seems to be 'fold to put in an Uber'.
55+ Club,...
Bikes: 9+,...
Liked 857 Times
I shared this earlier in the thread about the $50 off the pricing. The price is OK, considering it's a carbon gates belt drive, and folders are amazingly expensive after 2020.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 275 Post(s)
Liked 244 Times
It's just a standard "budget" folding bike like dahon mariner i7 or tern link d7i but has the advantage of a belt drive found on more expensive bike like tern verge S8i.
Personally I think that all "hub" and "coaster" bike should be belt driven as the "fan belt" and cleaner and do not require any maintenance; once it has stretched or cracked, change is and forget. perfect for commuters.
Palmer
Liked 1,837 Times
NY / New Haven biker
I saw one on the NYC Hudson River bike path and the stem and tube looked solid. The paint and the lines are also attractive.
The rider worked for Priority and confirmed that they are looking to over a low-maintenance product. He remarked that the bike fits lots of different heights, which could be useful for me or my family looking for a bike that works for my tall 9 year old, myself, and my wife. I can see the market.
