Toes go numb....whats the deal?
Bikes: Madone 5.2
No matter how I arrange my seat height or level I can't seem to get rid of this issue. Is it the seat itself or are my measurements just off? I feel my toes going numb after about 10-12 miles into my ride. Any one else experience this? What did you do?
Dart Board
Bikes: 13 Super Six EVO Red, 2005 Six13, 2015 CAADX
Your foot may be too far forward on the pedal axel and you are pedaling on your arches. Check foot alignment with the axel
Velocity
Velocity
Bikes: Madone 5.2
It seems to go away after I get up out of the saddle for a climb. I don't know if it has something to do with the saddle height, or the saddle itself. I think my shoes are correct, but at this point I'm searching for straws........
Guest
Posts: n/a
Quoted: Post(s)
Take your bike and shoes to your LBS and get a proper fit. Numb feet is mostly caused by cleat misalignment, and sometimes because shoes just don't fit properly.
You're searching for straws, but this is a good place to start, even if you don't think we're right.
Koffee
Koffee
Quoted: 77 Post(s)
Liked 19 Times
Shoes too small or too narrow?
Loosen up straps/laces on shoes?
Riding with feet pointed down?
Bikes: Road, MTB, Folding, Commuting bikes...
Is it all the toes or just a few? Just on 1 foot? Anything else go numb? Butt hurt, too? Hows your seat? Have any other foot problems?
I'd check:
1. seat adjustment, your position on the seat itself
2. shoe size/tightness
3. cleat position
4. your form
5. your foot type (flat footed, etc)
My guess based on what you've stated is that a nerve is getting stretched or pinched somewhere. It could be high up near your butt (probably unlikely), around your knee (again, probably unlikely), around your ankle (possible), in your foot (probable), trauma, infection, tumor (sorry I had to add those or certain other physicians on this board would probably make me go study ).
I'd check:
3. cleat position
4. your form
Bikes: Madone 5.2
Thanks for all the feedback. My shoes are actually a bit on the big side. I tried a ride with the shoe straps a little looser and it didn't really seem to make a lot of difference. I've never really paid attention to whether or not I ride with my toes down or level. I'll try to be more conscious about that and see if it makes any difference.
I have had the same problem with my big toes going numb after about 30 minutes.
What did the trick for me is to pull up on the pedals more. In other words, try to put some power into the upstroke and not just on the downstroke. It takes some pressure off of the bottoms of your feet.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
Another thing to check would be your socks. I had numb toes problems until one day I showed up at a riding spot and discovered that I forgot my socks. I made a quick trip to a closeby REI and as I was browsing the sock display, realised that all along, I was wearing socks a size too small. After switching to medium sized socks (gave the smalls to my wife), I no longer get numb toes.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
DEADBEEF
Liked 6 Times
Originally Posted by aikigreg
So if you've got wide hips and toes that point out, how would you adjust your cleats to alleviate numbness in the last two toes?
Koffee
Koffee
Dart Board
If you ride too far forward on your feet's arches you could also get numbness in the calves and if you ride too far back on the toes you can get aching/cramping calves (like you just did 1000 calve raises) If your shoes are too large that says that you could have a probable missalignment with the metarscels not being over the pedal's axcel.- shoes should fit ... well like a glove.
Like carpal tunnel syndrome there is a night time problem that you could feel too. Does your feet feel numb at anytime after the rides? If this is the case it could be a flexability problem.The numbness also could be a fallen arches thing but that I think you checked with the specialized arch supports. Kind of wonder about the dorsiflection of your foot like there is too much heel drop in your pedal stroke like the seat is too low. Someone asked if it were just one side or both that is giving you the problem. Some group exercise instructors get what is know as plantarfacitis (tendonitis in the Plantar facia) which would result in cronic repetitive motion injury and is somewhat deabilitating. But I am not a doctor and a visit to one if this numbness keeps up after adjustments suggested from the above threads is probably the best thing to do.
Velocity
Velocity
There are a couple of nerves that run between the 3rd and 4th toes (your big toe is #1) that can be pinched from improperly fitting shoes and cause numbness. Also look up Metatarsalgia - it is a problem with the metatarsals (ball of foot area) that can cause soreness and numbness. It can come on slowly and be caused by several things - even tight Achilles tendon can pull on the metatarsals, which happened to me. Generally there are ways to strengthen the foot and adjust fit to eliminate problems.
Bikes: Puch Luzern, Puch Mistral SLE, Bianchi Pista, Motobecane Grand Touring, Austro-Daimler Ultima, Legnano, Raleigh MountainTour, Cannondale SM600
Try dropping your heel a bit throughout the pedal stroke. Worked for me.
mtnroads - You are correct re: metatarsalgia. In the medical literature a looong time ago it was described as such. Recently it is described as a neuroma but if you look at the pathophysiology and histology of the neuroma you might be inclined to call it something else like a schwannoma, etc..
Anyway..
