74mm front axle and disc brakes?
Hi,
does anyone know a complete folding bike that comes with 74mm (or up to 86mm) front axle and disc brake? Or a 20" fork / 74mm disc hub combo?
I've seen plenty of 74mm disc hubs for sale but not a single instance of a bike fitted with one. I wonder if it even can be done?
Greets, Tim
Greets, Tim
Quoted: 573 Post(s)
Liked 118 Times
https://www.google.com/search?q=daho...brake&tbm=isch
Likes For Ron Damon:
Quoted: 463 Post(s)
Liked 567 Times
The fantastic FSIR folders are no longer being made or sold. A few of us, though, managed to snag a specimen or two before they expired. 😉
...sorry, had to pull it out from hibernation. Bike looks disfigured - has 47-305 tires on it for ergonomic tests - standard is 406. Hub in pic i made myself from 100mm hub, because i bought the bike and built the wheelsets i wanted long before 74mm disc hubs were widely available.
Likes For splithub:
..it's the rims stretching the tires out to 60mm. Was looking for a lightweight voluminous slick but didn't find (in 305), tried to make my own by shaving knobby veetire crown gem in 2.25 and a chaoyang sparrow in 2.6 but they both came out too sticky of the material - too much rolling resistance. So i found these 40mm rims in the parts range of a bike trailer manufacturer. They fit the bill making comfortable volume and being lightweight, cheap and of acceptable quality and stability so far.
Quoted: 463 Post(s)
Liked 567 Times
It's playing, only 10% of the things i try actually work
To get back on track, there is no real problems with 74mm hubs and disc brakes since the spoke flange distance can be smaller on smaller wheels. If 50mm is enough for 622 wheels, 35mm is fine for 406. It makes the fold narrower. I would plead for a narrower standard in the back also. The only limitation i ever heard of is that the TRP double actuated mechanical brakes don't fit, i have Tektro Lyra on it.
Quoted: 350 Post(s)
Liked 122 Times
I remember seeing a website that was selling replacement front forks for Dahon bikes that could fit 100mm hubs with disc brakes. They were selling also on ebay.
Here it is on ebay:
https://www.ebay.co.uk/itm/134225217381
you'll need to check if it has the threads for the type of headset nut that Dahon uses. It looks like this uses a star nut / expander with a compression ring. Hopefully it may fit.
Here it is on ebay:
Quoted: 350 Post(s)
Liked 122 Times
Also, I thought the steerer tube length was longer on Tern compared to Dahon, so I'm not sure how this fork they're selling is supposed to be compatible with both.
Palmer
Quoted: 1671 Post(s)
Liked 1,827 Times
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
