Do you patch tubes?
#126
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I lost count on how many threads he has come in to sing his praises for Rema. It actually makes me want to try it, but I switched to tubeless and haven't had to patch a tube since.
It's like riding a bicycle
#127
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
From what cyccommute has said, it seems likely that the failures with other brands come down to the fact that Rema patches become (in effect) welded to the tube whereas other patches are merely glued on. (There may be other brands that have comparable chemistry, but whether that's the case is unclear.)
Glue can work, obviously, but co-op clients who are inexperienced at patching tubes and/or impatient to finish the job probably manage to screw up the patching procedure more easily with other patch kits.
#128
Quoted: 2604 Post(s)
Liked 1,934 Times
I can't say I agree with this characterization. I've used the same tube preparation for decades with glues from Rema, Slime, Park, no-name patch kits, and even Elmer's Rubber Cement. I've only had a couple fail. One failed because I missed the hole -- user error, not attributable to whatever glue I was using at the time. The other was a cut that was too big for the patch I had -- again, not a glue failure.
FWIW, missing that tiny hole was what led me to buy a couple silver Sharpies to mark the leak.
Likes For pdlamb:
#129
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Not from that, no. Several years of personal use along with several years of research on how cold vulcanization works and the chemistry behind it are what have lead me to use Rema exclusively. I have been using them exclusively for more than 30 years so the experience at the co-op was confirmation of what I already knew. By the way, I haven’t said the others don’t “work”, they just don’t work as well nor as permanently.
Stuart Black
Stuart Black
Likes For cyccommute:
#130
Liked 4,222 Times
Stuart Black
Stuart Black
#131
Liked 4,222 Times
These two comments do not agree with each other. If a patch peels, it failed. With the exception of the few patches I have botched, none of my "vulcanized" (glued) patches have ever peeled, not even after over a decade and with multiple patches all over. The patch lays so flat that I couldn't pick an edge with my fingernail if I tried. But I digress, Rema may well still be a better, easier to use product. It's just that the other patches aren't as bad as you make them seem.
Stuart Black
Stuart Black
#132
Quoted: 2333 Post(s)
Liked 2,097 Times
I did not get a single flat last year and not a single one this year until a 600k ride recently when I had two. The problem was my sealant had dried out in 3 weeks? Due to heat? Or heavy miles? I threw the tire away although the dynaplug worked fine.
#133
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
The comments completely agree with each other. I have tired different patch kits at various times including when I first started bicycling seriously 40+ years ago. Sometimes when I haven’t had a choice and especially early on in my bicycling experience when I didn’t know better. I’ll admit that I have botched my share of patch jobs even with Rema patches but if a patch is going to fail even when applied properly, it’s going to be the one that is not Rema, in my experience.
#134
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
#135
Liked 4,222 Times
That makes sense, and would indeed suggest Rema has a better, success ensured product. I just think it's disingenuous to claim that the other products are not "long lasting", especially seeing how many other people have patches that hold up for years. Just say it's harder to use properly and be done with it.
Stuart Black
Stuart Black
#136
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
Let me put it a different way. Would you suggest to someone that they just go and buy a bike a Walmart because the bike is just as good as the bike you purchase at a bike shop? Would you suggest people use Sunrace rear derailer instead of a Shimano because it works the same way and is just as good? Or even suggest that they buy a Shimano Tourney as a replacement for Dura Ace or XTR because they are both “just derailers”? The reason we use Shimano or SRAM or even MicroShift is because the companies have built reputations based on durability that make the extra cost worthwhile. Rema sits in a similar place. The patches work. The patches work well and consistently. They have build a reputation based on that. Other patch kits simply are as consistent.
#137
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
#138
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I had peel and stick ones fail after about a year of being fine on the bike, then someone on this forum mentioned that I wasn't burnishing them properly. That seemed to solve it for at least a couple of years before I stopped using tubes. Just to be safe though, I carry a brand new tube in my seat bag just to avoid any surprises should I need it.
#139
Quoted: 904 Post(s)
Liked 1,899 Times
I don't think it would be possible to peel this patch off without tearing the inner tube. could be wrong I guess.
Likes For jadmt:
#140
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
Likes For daviddavieboy:
#141
Quoted: 3958 Post(s)
Liked 7,312 Times
#142
Quoted: 2490 Post(s)
Liked 2,961 Times
Opinions on patch kit reliability from a guy who deals with a hundred or more patching jobs per year in a co-op are statistically meaningful. Opinions from people who patch tubes maybe five times a year, somewhat less so.
#143
Liked 7,312 Times
2. The total number of patches applied by all the other people also makes it statistically meaningful.
#144
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
FWIW I am at 5 months on Orange Seal Endurance after having regular Orange Seal dry up in about 4 weeks on my road bike.
#145
Liked 4,222 Times
If all bikes were like HellMart bikes and there was only one brand that was significantly better, your analogy would hold. But bikes aren’t like that so it doesn’t.
Stuart Black
Stuart Black
#146
Liked 7,312 Times
Likes For tomato coupe:
#147
Liked 4,222 Times
Additionally, a whole lot of people don’t patch tubes because they have had a high rate of failure of the patch. They feel that the process is a useless exercise. I haven’t looked at every single failure for the millions of punctures out there but I’m reasonable certain that the vast majority of people who have failed to get a tube patched properly aren’t using Rema’s system. They may have made other mistakes, of course, and Rema isn’t immune to that problem. However, the chances of success are vastly increased using Rema’s two part accelerator system.
Stuart Black
Stuart Black
#148
Liked 7,312 Times
#149
Liked 4,222 Times
So, I take it your silence on the chemistry speaks volumes. When you’ve done a little bit of study on the cold vulcanization, come back and we’ll talk. Right now all you are saying is “you are wrong because you are Cyccommute.”
Stuart Black
Stuart Black
#150
Liked 7,312 Times
I'm saying that I, like many others, have had very good success with many brands of patches. Accelerants may be useful, but I think you're obsessed with a detail that makes little practical difference.
