Should I "Hoard" Mechanical High End Parts?
#51
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 179 Post(s)
Liked 169 Times
As far as hoarding. I say not! But it's your money and your family will have to deal with disposal when you are gone. I don't hoard, but I do try to keep well stocked in nearly all things. Cables, bar tape, tires, tubes, and co2 cartridges. When I build a wheel I get a couple extra spokes of each length.
Sir Mark, Knight of Sufferlandria
Likes For Black wallnut:
#52
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
I can certainly see the point to buying brifters (STI levers for the squeamish) and derailleurs, but past that, I cannot see where parts should become hard to find. I am sure there will be firms buying up old Shimano patents or just making knock-offs of old parts when Shimano is full wireless electronic and riders wear halos with electrodes into their scalps for shifting and braking.
#53
Klaatu..Verata..Necktie?
Quoted: 10445 Post(s)
Liked 11,930 Times
#54
Liked 11,930 Times
Just think - you could get the telekinesis version of shifting the rider you're passing into a higher gear, a la Team Cinzano in "Breaking Away".
Likes For genejockey:
#55
Quoted: 539 Post(s)
Liked 466 Times
The maintenance of mechanical shifting is not with the components themselves, it's with the cables.
If you only ride your bike on weekends and in good weather, they can last a long time. For people riding high mileage in all weather, cables have to be replaced annually at the minimum, sometimes more. Yes, even with high end cable kits. And when you replace the cables, you have to rewrap the bars, even if the tape is still ok.
After years upon years of doing this, it gets old. I'm in the gradual process of transitioning my bikes to electronic shifting, and I don't think I'll buy another cable system in my life.
Likes For RH Clark:
#56
Quoted: 4427 Post(s)
Liked 4,879 Times
Electronics are proving to be pretty reliable. Replacement batteries are probably the only ongoing cost and they should last a few years at least. It’s not a very demanding power application.
Likes For PeteHski:
#57
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2593 Post(s)
Liked 5,664 Times
I was thinking Shimano should offer a CVT (continuously variable transmission) like in some Subarus. Whenever your RPM drops below, or above, a certain predetermined number it automagically down or up shifts. Could get crazy on steep climbs though.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#59
Grupetto Bob
Liked 5,664 Times
#60
Liked 4,879 Times
CVT on a bike doesn't appeal to me at all. The last thing I want is to be pedalling the same monotonous cadence for hours on end.
Likes For PeteHski:
#62
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 220 Post(s)
Liked 863 Times
It isn't as extreme as all-out hoarding, but I do like to save spare parts, old components,etc. It's worked out, as I've been able to cannibalize broken components to keep another on the road. I even recently built up another road bike on a frame I repaired, using Ultegra 6800(from a previous bike) that had been sitting on the shelf for years.
Most of my bikes are fairly modern, so they usually don't require much out of basic maintenance, but I do like to "tinker" on them. I find it relaxing and is my way to unwind, instead of plopping down in front of a TV. I have a metal lathe and a mill, so I can and do occasionally make small parts for them. My latest venture has been making things out of carbon fiber.
As far as cables wearing out, I replace the shift cables on my Shimano bikes annually. I've had the aforementioned 6800 snap a cable inside the shifter before. It was in the middle of a long day in the mountains, luckily it was for the front, so I still had useful climbing gears. The rear cable for Ultegra 8000 on my main ride, almost failed earlier this year. Shifting performance was degrading during a ride...when I finally took it apart, the cable was being held together by a couple of strands.
Likes For Sierra_rider:
#63
Grupetto Bob
Liked 5,664 Times
Completely agree, but it might work for the ‘unwashed masses’. All it would need is a strain/Wattage gauge. Think there is already a bike or bikes out there with something similar. On second thought, with the popularity of e-bikes, it would not work.
#64
Quoted: 3958 Post(s)
Liked 7,312 Times
I want to see "erg" mode on bikes.
#65
bocobiking
When I need to shop for parts for any of my 6 bikes, I shop in my garage, where I’ve stored enough of my beloved first-generation shimano 10-speed parts to outlast all the “newest and best” crap. Bike shops and online sites no longer have anything for me. And eBay is quickly running dry of 6600/5600/7800 parts.
Likes For bocobiking:
#66
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1953 Post(s)
Liked 1,475 Times
Likes For SoSmellyAir:
#67
Liked 11,930 Times
The other day I forgot that I'd swapped wheels on my bike, so the chain was on Biggie Smalls when I tried to start riding. I'm pretty sure I said "Erg!", as well as few saltier words/sounds.
#68
Liked 11,930 Times
The 7800 STIs and RD on my Ritchey just shift better than the R7000s on my Canyon or the R8000s on my Litespeed. Plus the Canyon needed a new RD cable before it got to 5000 miles. The STIs where the cable DOESN'T come out the side are somewhat notorious for short cable lifespan.
#69
Liked 7,312 Times
Likes For tomato coupe:
#70
bocobiking
First generation shifts better/smoother than second (I've tried both). Cable routing for the first generation is much easier to work on, and much, much easier than on the r7000 and r8000s (my wife has these). Plus, there are no triple cranksets when you get to 11-speed, and I love triples.
#71
I tried one for all of 40 yards down my street and had to fall to stop. No way. I bought it cheap just to try it and donated it to the local charity recycle a bike immediately. Good riddance.
If you look at my posts though I do enjoy riding single speed I have a Salsa Stormchaser that I absolutely enjoy. The 34/17 gearing is also acceptable for most mild to moderate hills but when it gets to more than 6-7% for more than say a 1/4 mile I can't do it.
#73
We got a base model forester with CVT it gets great gas mileage if you drive easy with it but no fun at all. I miss the manual transmission. If I had the money 10-20 years ago I would have bought a bunch of cars with manuals to collect and enjoy. If you ride them like 2-3k miles a year I would have had cars for life and never had to bother with hybrids, CVTs, electric or any of that baloney. Yes electric is like 3x as fast but its just one noted. You can power to 120mph in a straight line instantly but it gets old quick. It has too much torque to start rotating the rear end under power early in a curve so you feel the electronic nanny kickcing in and there's no way you can fully disable the stability control. Not that you'd want to with that much power its like driving on ice and you'd die. Wish I had an unmolested, low mileage Honda S2000 or an 80s/90's european sub 2000lb hot hatch a la Renault Clio Williams or Peugeot 205 1.9 GTI. As Colin Chapman the guy who started Lotus there's that quintessential performance ingredient that is no longer added to cars that improves *ALL* performance elements equally: adding lightness.
Likes For Attilio:
#74
Liked 4,879 Times
The problem with those lightweight 80s hot hatches is when you crash into a modern car. You die while they walk away with a bit of air bag rash.
Life moves on and when new things start to seem pointless it probably just means you are getting jaded with life. But I agree that a CVT Forester is never going to be fun to drive!
#75
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 980 Times
Perhaps quality of manufacturing of Shimano's first-gen 10-speed (5600/6600/7800) components is better than the its second-gen 10-speed (5700/6700/7900) or its subsequent two generations of 11-speed mechanical components. Dura Ace 7800 cranks didn't break and DA 7800 shifters barely encountered issues they weren't cable eating shifters because the ****ing cable were external not internal unlike their followers. I only buy Dura Ace 7800 for all my bike projects because it is fully reliable light and not finnicky. Dura Ace 7800 isn't cheap regarding spare parts yes, but quality wise it is stellar , I prefer to spend my money on DA 7800 High End parts than on DA7900, 9000,9100 and 9200 High End parts
