Why are Modern Bikes So Expensive?
#326
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 570 Post(s)
Liked 773 Times
Dave, since you ignored my post a few threads ago, I expect you to ignore this as well…
Why is Pogs using deep aero wheels on pure mountain stages? Stages where he flat dominates everyone? Stages where he is displaying his early season form for the cycling world to worry about? On mountains where he is blowing all the ascent records to pieces… on an aero bike with aero wheels…
#327
Quoted: 1248 Post(s)
Liked 1,323 Times
Sigh.. has anyone here been on fast group rides? Or raced? On the flats weight doesn't matter obviously. Aero doesn't matter either because you're sheltered in the pack 90+% of the time coasting along at 100 watts. I suppose if you were some disposable domestique on some pro team, required to lead the team until you were spent and shelled off of the back like a soiled Kleenex, then aero would matter. Or it might help you if your thing is pointless breakaways 50 miles from the finish, but you're going to get caught eventually anyway.
The thing that shells you off the back are the hard climbs and repeated fast accelerations out of corners. There aero doesn't matter either, whereas weight, particularly wheel rotating weight is everything. How much weight matters - you tell me. When you desperately clinging onto a wheel giving it everything you have, then grams can make all the difference. Everyone here should know the panic of seeing the wheel ahead of you slowly drift away, with the knowledge that if the gap grows to 10 feet, you're done for the day.
If the arbitrary UCI weight limit were to be lifted, pro disc brake road bikes would disappear overnight.
Your tomes read like you have read "The Rider" by Tim Krabbe one too many times. Even in the Tour de France peloton, it is not the life and death struggle that you constantly refer to.
#328
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
Dave doesn't answer direct questions, or involve himself in discussions. He pontificates.
Likes For Eric F:
#329
Quoted: 8287 Post(s)
Liked 9,064 Times
What I was referring to was your absurd obsession with grams. Are you really unable to hang with your group if your bike is a little heavier? How much weight are you talking about? How much difference does a little weight make in your position in the pecking order of your group?
35 years of doing thousands of group ride with hundreds (at least) of riders has shown me that the best climbers will be the first to the top of long climbs, the fastest sprinters will be at the front of any sprints, and the riders who put in huge miles will do the long, brutal group rides better than most of the rest. Minor changes in equipment, wheels, or gear will make little difference in any of that.
Most of my club riding has been at 220 pounds. When I get dropped, it's not because my wheels are 400 grams heavier than yours.
Likes For big john:
#330
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
#331
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
If æro didn't matter, taking shelter in the pack would be meaningless.
Car dependency is a tax.
#332
Quoted: 4420 Post(s)
Liked 4,873 Times
For acceleration out of corners, 400g on a wheel set barely registers on a stopwatch. A few hundredths of a sec at most. Crit racers and sprinters are all using aero wheels for a reason. You won’t be seeing competitive sprinters on super lightweight climbing wheels.
For climbing, 400g is worth around 20 secs per hour on a mountain climb, offset by any sailing effects in the wind. Super light wheels may offer a slight advantage depending on the gradient and wind conditions. But they may also be considerably slower in the wind.
If you take your head out of the sand and look around you might learn something new. But I know that isn’t going to happen.
Likes For PeteHski:
#333
Sunshine
Quoted: 10971 Post(s)
Liked 7,498 Times
Likes For mstateglfr:
#334
Liked 4,873 Times
https://www.bikeradar.com/features/p...e-bike-weights
#335
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Times over that period have increased at the MOST by 5.1 seconds per mile. And again, we are comparing the old fashioned skinny tubed steel bike - which they started with - to the most modern AERO bike you can make now. Surprisingly, the whole race times are not that much different either - so it has not lead people to be "fresher" and able to "run" faster - at least not by a lot!
I would argue and firmly believe that for most everyone riding, all the changes on road bikes over the last 20 years have had a modest impact upon speed at best. Just ride what you like and be happy.
If you want to spend 15K on a bike, do it and be happy. If you don't, you can get a bike just as good, for much less and be just as fast and I would argue, just as happy!
#336
Liked 4,873 Times
I have been looking a lot at the Iron Man Kona as that is a race that has had the same basic bike route (with some exceptions) over 40 years. Bikes of course have evolved significantly and a full aero Tri-bike - as raced by the vast majority of the top 10 finishers are vastly more aero and more advanced than any "road" bike, even a specialized ICI TT bike.
If you want to spend 15K on a bike, do it and by happy. If you don't, you can get a bike just as good for much less and be just as fast and I would argue, just as happy!
There is certainly no point in whining about the additional weight of disc brakes or wider aero wheels like some do as if it makes them less competitive on their group ride!
Likes For PeteHski:
#337
Habitual User
Liked 8,100 Times
Yes, and yes. You aren't the only one here with racing experience, or experience being stretched out in a thin line in the gutter at 30+mph, or experience watching the wheel in front of you creep away and there's nothing more to give to hold on to it. I've done all of that. I did it for years.
It's time to wake up, and climb out of your stubborn little box. Your conclusions are backwards, science proves it, and we see it in action with the racers who have the most to win and lose from it.
Nonsense. If bike weight were that much of a concern, every pro rider's bike would be at the allowable minimum, for every race. Fact: They aren't
Likes For Eric F:
#338
Administrator
Quoted: 11975 Post(s)
Liked 6,655 Times
Please don't bring dirty laundry (arguments, feuds, accusations) from one thread into another, especially involving the same individual(s). That can easily be interpreted as harassment. Thanks.
#339
The pros adopt high-performance gear as quickly as possible. They are not traditionalists; they take advantage of every second, watt and gram wherever possible within and often outside of the rules. Example: carbon frames, in which the pros like Lemond were on carbon well before the tech was ready for the market. Or the Vitus Carbone, which needed a few more iterations of development and larger tube sizes before it was fully cooked. Electronic shifting was adopted quickly as well.
However, when the pros drag their feet as long as possible on some tech, you know that the gear is sub-optimal and actually detracts from race results. Clearly discs are an example here, where the most competitive teams were the last to adopt discs, and then only on inconsequential flat stages. And the team leaders and climbers held out on rim brakes until the manufacturer pressure was impossible to overcome. But again, the entire industry and the pro tour itself exists to sell stuff.
Clinchers, and especially hookless is an even more glaring example. The pros absolutely don't want this, as their organization has publicly stated. Some lucky teams, who have the premium tire and wheel sponsors are still on tubulars, despite the impossibility of selling this to the gold-card weekend warrior. Doing the last-second wheel switcheroo or the hot label trick may fool or placate your wheel and tire sponsor.
And don't confuse the PR announcements on team gear choices with what gear is actually used on race day, particularly on the hilly stages. When placings are at stake, the pros pay out of their own pockets for Obermayer's (tubulars of course) thumb their noses at their official sponsors, and go for the win.
BTW: I'm going out for a ride on a carbon road bike with clinchers and hydraulic discs and 32mm GP5000 tires. But I would never be as deluded enough to think that this bike was as high performance as the same bike and model made 10 years earlier.
Likes For Dave Mayer:
#340
Habitual User
Liked 8,100 Times
EDIT: I have yet to see any indication that your experience or knowledge is superior to everyone else's. It's fine to have opinions and preferences, even if they're wildly different than everyone else, but making statements as if their irrefutable facts, without any references to support your claims, isn't going to get you very far.
#341
Liked 4,873 Times
#342
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,924 Times
#343
Habitual User
Liked 8,100 Times
#344
Liked 11,924 Times
#345
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 414 Post(s)
Liked 927 Times
From listening to the podcast, it does seem like modern SOTA bikes are more expensive to design, test, and manufacture, alright. Lots of costs mentioned. Also interesting is Factor's marketing strategy of racing sponsorship and racing performance, which is hardly something I wish to complain about.
Very interesting perspective in the podcast, thanks for posting it.
#346
Quoted: 406 Post(s)
Liked 389 Times
Some bike prices from 2001.
What I find interesting is not that the bike frame prices are cheap - the highest one is about $3200 today -but the weight of the bike frames and the overall weight of the bikes. Frames have gotten much lighter but components must have gotten much heavier to make up for the weight difference we see today.
Likes For vespasianus:
#347
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
It's like riding a bicycle
Likes For urbanknight:
#348
Quoted: 570 Post(s)
Liked 773 Times
Todays top of the line Trek = 13k+/-.
The Look and Pinarello have an even bigger delta... way out pacing standard inflation.
And you could probably say that the CF manufacturing process back then was more expensive - new design and development, probably less automated... the Trek was probably hand made in the USA,, the Pinarello hand made in Italy... Look bikes hand crafted in France... not anymore.
Likes For Jughed:
#349
Liked 4,873 Times
That $4700 top of the line Trek in todays dollars = 8k.
Asian labour is cheaper, but there is lot more involved in producing monocoque cf layups vs bonded carbon tube. If they were manufactured in the US today then they would be even more expensive.
$8k today still buys you a bike technically well in advance of what was on the market back then.
#350
Quoted: 3515 Post(s)
Liked 2,929 Times
Likes For smd4:
