Estimated Cost to Correct Brakes and Shifters on a new Mountain Bike
Quoted: 11 Post(s)
I just ordered a new mountain bike online and had an issue that I wanted to get some advice on estimated costs for a LBS to correct the installation of Shimano Brakes and Deore Shifters on my new mountain bike. These were installed backwards by the bike company that sells their bikes directly to the consumer. The left brake handle controls the rear brake and the right brake handle controls the front brake. The left shifter controls the rear derailleur and the right shifter controls the front derailleur. Its a 2 x 10 bike with internal cabling. The bike company has offered only $50 for me to have a LBS shop correct the issue. While it will be a few days before I get the bike to a local shop, I wanted to get an idea if $50 will cover the repair? I’m thinking no way but could be wrong. I know that I could live with it and get use to it, but if I let another family member use the bike then they could find it a safety challenge like I did with all backwards on their first ride. Thoughts on the estimated repairs costs would be most appreciated. Thanks
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
For a mountain bike, especially assuming external cabling, this is not a difficult job. It may not even require any new materials at all. Maybe only the rear inner cable (at worst). I'm guessing that this is a 30-to-45 minute job (for me) to swap, adjust and test. $50 is more than fair. Other "professionals" may disagree. PG
WALSTIB
Apparently there isn't any drug testing at that bike company. Interesting very interesting
Likes For hillyman:
Quoted: 1950 Post(s)
Liked 2,187 Times
I’m trying to envision the left trigger shifter/rear derailleur setup.
John
John
Clark W. Griswold
Quoted: 4415 Post(s)
Liked 4,060 Times
The bike could probably use a full tune up and assemble. If that is the one noticed issue on the bike there is likely many many more. These online brands have no interest in quality it is quantity and quickness, if there is one issue it is usually a whole host of them.
Tune up/assemblies can vary based on your market but probably good average price range can be $100-300. However again it depends on your market and the quality of work being done.
Left lever/rear brake is supposedly more common in England. That makes the right lever work the front brake, which matches what motorcycles use.
Likes For BlazingPedals:
Likes For alcjphil:
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
there's no way the left shifter was connected to the rear derailer. either you installed the handlebar backwards, or they REALLY screwed up. nothing would operate correctly in the bike stand if they did that.
right brake lever connected to the front brake is common in European markets where more people are familiar with motorcycles. most American riders put the rear brake on the right lever. it's just a personal preference in the end.
Unless I am missing something fundamental, like maybe if the bike box arrived with none of the cables attached.
n00b
Quoted: 428 Post(s)
Liked 466 Times
true story: I once watched a very experienced mechanic recable a road bike by connecting the shift cables to the brakes. He just brainfarted and joked about inventing "indexed braking." it happens sometimes.
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
I set my bicycles up with right front brake. I have a motorcycle license and don't want confusion about the front brake. There is really no downside to which side you assign your brakes as long as you are good with it.
Advanced Slacker
Quoted: 2763 Post(s)
Liked 2,537 Times
Maybe the handlebars were backwards.
