Pedal removal 1987 Schwinn Tempo
Quoted: 211 Post(s)
Liked 199 Times
I am not sure how to remove these pedals
Do I use an allen wrench or pedal wrench ?
I still believe pedals loosen toward the rear of the bike
Please see pic.
Thank you
Appreciate any and all help
Please see pic.
Thank you
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3879 Post(s)
Liked 6,467 Times
Do I use an allen wrench or pedal wrench?
When they accept a 6mm allen key from the backside, I use both tools for removal. A pedal wrench to get it started, and then the allen key to finish the job.
When mounting, you only need to use the allen key unless the threads are super tight and more leverage is needed.
I still believe pedals loosen toward the rear of the bike.
Reverse thread on the nds!
Quoted: 211 Post(s)
Liked 199 Times
Would you hold the allen wrench at the back of the pedal and loosen with the pedal wrench ?
Or just use the pedal wrench ?
Seems simple, but I do not want to " strip" by mistake
Thank you for all the help !!
A pedal wrench is best, more leverage. And Allen wrench will work, may need a Cheater bar or something for more leverage. I have never used both. Be careful of where your hand and the wrench are positioned, so when it breaks free, you dont drive your hand into chainring tech or something similar
Quoted: 350 Post(s)
Liked 276 Times
SurferRosa is saying use the pedal wrench first for the leverage to break free, and then use the Allen wrench/hex key for speedy removal. I try to orient the wrench so that I can squeeze the wrench and crank arm towards each other to break free. Or you could loosen with a wrench and then grab the pedal and crank forward or reverse depending on the side being removed. This will back the threads out of the crank arm.
Likes For tyler_fred:
Quoted: 1627 Post(s)
Liked 630 Times
First step: Soak pedal threads with PB Blaster, then...
Quoted: 472 Post(s)
Liked 1,028 Times
Allen/hex keys are too long, even hex key sockets. The force you apply to the tool is partially applied to loosening the pedal and largely applied to caming the tool out of out of the pedal. As stated, get it loose with the pedal wrench and finish with the Allen key if you like. If I cannot squeeze the pedal wrench against a crank arm, I'll often lash the opposite crank arm to a chain stay to immobilize it, then force the pedal wrench.
Oh, and never loosen nor tighten a fitting with that ball end of the Allen key. In fact, cut those ball ends off and bin em. There's no place for them in a bike shop. ( how's that for an inflammatory remark?)
Quoted: 2362 Post(s)
Liked 1,749 Times
Of the dozen or so sets of clipless pedals I've had, I would guess one, maybe two, were allen wrench only. If most were allen wrench only, that would severely restrict choices for those with crank arms with closed-end pedal threads (which, granted, are rare).
Quoted: 656 Post(s)
Liked 468 Times
Back to OP‘s original question, I usually use just the allen wrench but an open end wrench is certainly better for pipe extensions and hammering if needed.
señor miembro
Liked 6,467 Times
Can we get a hilarious gif with this caption and the feller from the Park Tool videos? I would put that in my sig.
Seriously, I sorta love these simple, but profound aspects of wrenching and basic physics. I sometimes tell folks, "the way a bike works is two nuts can lock together on a bolt. That's how it's all able to work. "
