Just clear coat?
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
Just clear coat?
I have some pix attached. I disassembled a 2001 Lemond tourmalet to the frame and fork, and then stripped them to bare metal. I was planning on having them powder coated. However, today I was wet sanding, 800 grit, and I like the looks with the bare metal. There are some obvious dents and scratches/imperfections that will not be fixed or hidden with just the clear coat, but I think they will just show the many miles and hard use the bike has endured, and preserve some character. The components the bike came with; mix of Tiagra, Sora and Ultegra, can be cleaned and polished to look better, but are still going to have the well used look. My plans for the bike are to ride it a lot and have it as a traveling bike. So, I am looking for any thoughts, comments or ideas you all would like to throw out here. You can see the dent on the seat tube above the braze ons, and also one on the drive side seat stay. A couple other small ones elsewhere along with minor scratches.
Quoted: 714 Post(s)
Liked 800 Times
It will rust under the clear. It's been tried many times and it may last a few years before the rust starts, but there will eventually be rust spidering under the clear. It's one of the more common requests that people make of framebuilders. I built a frame for a close friend that wanted to clear coat it. I was able to talk him out of the clear coat and coated the bare frame with a light coat of Frame Saver. He doesn't take it out in the rain and it still looks very nice 5 years later. He told me that it occasionally gets a spot of rust and he just cleans it with scotch brite and applies more wax.
If you decide to go with powder coating, The guy I use for my frames is experienced with bike frames and his prices are reasonable. It's not too far from you in South Jersey..
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Powdercoat and paint get around this with primer, which is unfortunately opaque. The primer contains a chemical that etches or stabilizes the steel. It works because it forms a film over the steel and removes or converts the microscopic rust molecules.
I'd imagine that there's a method to apply a clear durable rust preventive coating, but it's likely not clear coat as we'd know it.
Likes For Unca_Sam:
Quoted: 714 Post(s)
Liked 800 Times
My understanding is that it will rust the same under colored powder coat, if no primer is used. The rust is not enough to cause damage to the metal, but is unattractive under the clear. If a color coat is being applied, various rust preventative coatings can be applied under the color.
Likes For dsaul:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
It's a matter of bonding. Steel wants to rust, all it needs is oxygen. Applying a clear coat without primer actually traps air under the paint, right against the steel. The supply is limited, so it's a slow process. Once the clear is breached by the rust, it can spread through the paths of least resistance under.
Pennylane Splitter
Bikes: Yes
Quoted: 1799 Post(s)
Liked 1,439 Times
I believe there's a 'clear coat' powdercoat available now, ask at your local powdercoating shop. It goes on white, but comes out of the oven as a 'clear' finish (slightly opaque). There are also some metallic finishes that look like bare steel/aluminum, also some that look like the frame has been anodized.
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
This pic of my Langster doesn't clearly show the "raw look" of the frame but whatever Specialized did....it looks good!
Op....if it can be done....do it!
Quoted: 18413 Post(s)
Liked 15,536 Times
Might want to check out what Cerakote has to offer. I know they make several clear coatings, but I don’t know if they are for use in steel.
My ti frame has a colored Cerakote finish.
Sr Member on Sr bikes
As mentioned above...there is the possibility of clear powder coating. Link: https://www.fullblowncoatings.com/wh...owder-coating/
Dan
Dan
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
If you decide to go with powder coating, The guy use for my frames is experienced with bike frames and his prices are reasonable. It's not too far from you in South Jersey..
Quoted: 714 Post(s)
Liked 800 Times
how do you use JP Weigle Frame Saver on the outside of the frame on the metal exposed surfaces? that stuff is a sticky oil type of substance, not unlike linseed oil, and all matter of dirt and bugs will become attached to the frame as you ride, so please explain how you coated the external frame and had it stay without being tacky.
Quoted: 4227 Post(s)
Liked 2,488 Times
Quoted: 714 Post(s)
Liked 800 Times
The outside of the frame is already protected by primer and paint and chemical pre-treatment which is used before painting...Rust starts on the inside and then it spreads outside. The best way to rustproof a frame is to spray some rustproofing oil on the inside of the frame. If you notice most frames and forks have very small vent holes. You can spray rustproofing oil into those vent holes and also remove the seatpost and spray some oil inside there... You don't even have to rustproof your frame, as most frames will outlast you and it takes extremely long time for a frame to completely rust out and become unusable.
Tragically Ignorant
Liked 9,098 Times
Semi-related question: Has there ever been a production bicycle with a stainless steel frame?
Why are stainless steel frames pretty much just a novelty?
The dropped
Liked 1,014 Times
Can't answer the first question, though I suspect no, because of the answer to the second question. Stainless frames cost a good bit. Though modern alloys (Reynolds 953, Columbus OCX, KVA MS3) supposedly surpass the lightness and strength of titanium and aluminum, a frame built with stainless costs around as much as a titanium frame. Metallurgy is an ever-evolving technical field, and I wouldn't be surprised that relatively lightweight high tensile stainless alloys are relatively recent, compared to aluminum and titanium. (Don't forget to say thanks to the Military-Industrial complex for your titanium and aluminum frames!)
The dropped
Liked 1,014 Times
Quoted: 7652 Post(s)
Liked 3,473 Times
I actually tried this, after doing a bunch of research---all of which said it wouldn't work, because it was impossible, in anything but a vacuum, to get all the oxygen out of the equation.
Unfortunately, they skeptics were right.
That clear powder coat is probably your best bet. it won't leave the look of raw steel, but you won't have ugly (but harmless) rust blooms under your clear coat.
Quoted: 671 Post(s)
Liked 49 Times
Crescent (Swedish) used to sell production stainless-steel frame bikes in the 70's. IIRC the price was not super-high but they weren't lighter than 531 or Columbus frames so the brand didn't get popular in the US. Nowadays not much point in a production stainless-steel bike...aluminum frames can be cheap & quite light; carbon is lighter than stainless.
Tragically Ignorant
Liked 9,098 Times
Quoted: 714 Post(s)
Liked 800 Times
One of the local Professional Framebuilders was working on coming up with a full stainless TIG welded frame and decided to go with Titanium instead. Basically the stainless required similar welding procedures to Ti, such as additional weld prep and back purging, with no real benefit over Ti. I did a quick price check and found that Columbus XCR stainless tubes are more expensive than similar sized Dedacciai Titanium tubes.
Likes For dsaul:
Liked 2,488 Times
You could also get that bare metal look with brushed aluminum which has been clear coated with powder...
Likes For wolfchild:
Quoted: 671 Post(s)
Liked 49 Times
Personally I think 'bare' metal frames look a bit plain but taste varies of course.
Quoted: 321 Post(s)
Liked 263 Times
Genesis for one will sell you a Reynolds 931 frame (complete with no paint) off the peg and Cinelli sell Columbus XCr frames, which I'm pretty sure are also available as complete bikes. 931 is about the same strength as 853 and only a little bit more expensive so the main reason for picking it would be for the actual stainlessness. They're all pretty high end though and this is why they aren't more widespread.
