Semi-autonomous BMW forces close pass of cyclists
Don't make me sing!
Bikes: 2013 Specialized Crosstrail Elite, 1986 Centurion Elite RS, Diamondback hardtail MTB, '70s Fuji Special Road Racer, 2012 Raleigh Revenio 2.0, 1992 Trek 1000
Quoted: 308 Post(s)
lol.
I'll grant that your memory may be a bit fuzzy. There were no actual cyclists in the subject article, nor a reference to a related video. Perhaps you read a completely different article?
I don't know the YT posts to which you refer, so it's not helpful to even bring them into the discussion, unless you're going to provide relevant links. My position is that the article does not contain a reference to a situation in which blame could be ascribed for the death of a cyclist.
You said, "I suspect that sometimes cyclists die due to accidents that could be avoided if cars didn't pass cyclists that closely." Now, you're suggesting that speed and physical size are more important than proximity? I guess I still don't understand what you meant by "that closely". If it's all relative, then, "that closely" doesn't really have any meaning, does it?
The point was, there was no cyclist, and no "close pass", in the article, thus there was no possible way to ascribe any blame. Perhaps you've ignored the context of my original post, and that's what's upsetting you?
You can manufacture a scenario, and then try to ascribe liability, based on your fantasy, but that doesn't change the fact that the subject of the thread: the article, does not contain a scenario from which we can extrapolate culpability. As much fun as it may be to go tripping down the yellow brick road, it's not relevant to the discussion at hand.
I don't care. It's not relevant. "Clipped by the mirror" is not a "close pass". And, since you've determined that "that closely" is an arbitrary standard, there is no scenario you can present that can produce a consistent outcome. I can simply say that the pass wasn't "that closely", and we can argue 'round and 'round, 'til the court locks both of us up for wasting its time.
Firs of all, your question is ill posted because I did read the article, and the articles linked inside the article, and I saw the video referenced in the article of a semi-autonomous car doing a close pass during a test drive. But I'll admit that my memory of the article is a bit fuzzy and I didn't pay too much attention when answering your rhetorical questions. Because what I wanted to do is get an answer.
Consider the following hypothetical scenario. A driver tries to move away from a cyclist while passing without signaling, but the cars semi-autonomous driving systems prevent the driving from allowing sufficient space. The cyclist is clipped by the mirror, falls down and is seriously injured. How should liability be assigned? Is the driver completely liable? Or does BMW share some of the liability?
Lol this is getting too long and childish.
I still think your initial post was completely misguided, and your defensive response to it was simply ridiculous. I think the problem originated because you miss-understood them meaning of the phrase "in this case" in the context of the original question which was "So who would be liable to death of a cyclists in this case? BMW the company or owner of the BMW?"
But I guess I'm being childish too. At some point we need to stop this and move on with our lives.
someones wrong on the internet
Quoted: 959 Post(s)
Not sure about BMW, but Tesla makes it abundantly clear that it accepts no responsibility when the driver chooses to engage their Level 2 Autopilot. Doesn't make it immune from being sued, of course, but they have pretty good protection, I think.
Quoted: 1858 Post(s)
Liked 664 Times
I'll play.
The question is nonsensical. The car in question was a Level 2 AV. No way would a Level 2 prevent the driver from allowing sufficient space. There is no point about speculating about an impossible hypothetical. Same with Level 3.
Only with Level 4 is it possible that the car would override the driver's steering inputs. Realistically, I can't imagine anyone will release a Level 4 that will close-pass cyclists, so practically speaking this is probably an impossible hypothetical too.
But if something like that does happen (and there is actually a crash and injury) with a Level 4 or 5 car, certainly the manufacturer would be liable.
Reference: Levels of driving automation
On this point, there is a trade-off to requiring passes of cyclists to be wide, isn't there? If the passing car goes across the double-yellow line, it encroaches on the traffic going in the opposing direction. Ok for the cyclist, but it imposes a new hazard, unless mitigated. And if the cyclist is not as far right as practicable or there is a lot of damage and debris on the right side of the road there will either be no passing of cycles or drivers will take chances, either encroaching on the cyclist or encroaching on the opposing traffic.
Bikes: Brompton, Time, Bianchi, Jan Janssen, Peugeot
Quoted: 598 Post(s)
Liked 5 Times
I'll play.
Quoted: 959 Post(s)
Quoted: 959 Post(s)
Quoted: 598 Post(s)
Liked 5 Times
That’s the definition, now try to understand it. Your response above to the hypothetical scenario lacked that.
Quoted: 959 Post(s)
In other words, if the hypothetical scenario is unrealistic, what's the point in speculating that it might happen?
How is that misunderstanding "hypothetical"?
Quoted: 18378 Post(s)
Liked 4,512 Times
As far as danger to cyclists... I consider any close pass where I don't get hit safe enough.
However, laws vary from state to state, often defining 3 to 5 feet minimum passing distance. Did BMW forget to program that into their cars? Especially considering laws vary from state to state.
Hopefully they did program in automatic brakes, so if I'm "taking the lane" at 3 MPH with my cargo bike, I'll get a long line of BMW's patiently following me.
Part of the reason for a buffer is that it is awfully easy to swerve just a little bit with a bike. Pedestrians, of course, can be unpredictable too. However, two things occur with bicycles. First of all, they're subject to many road obstructions that are often unseen by drivers. Second, a small swerve is often amplified. So one can accidentally swerve by 3 feet or so, perhaps even more. That may be in part due to essentially counter-steering to recover.
This, however, seems to be a HUGE OVERSIGHT by BMW. Mom's Prius has beepers for lane drifting. They can be most annoying. And, if one gets too many reminders, it pops up with a Coffee Cup suggestion. Nonetheless, annoying or not, the subtle reminders to hold one's lane can be a good thing.
What I've decided, however, is that not all "drifting" is in fact bad.
Obviously it should be done safely. But, there are instances where one may slightly cut a corner.
The bicycle might be one instance where one would at least put one's left wheel on the center line.
If it is a multi-lane road, then all other vehicles (either direction) should also naturally compensate some. And doing so becomes very natural for drivers. So, oncoming traffic might put their right tire on the fog line, or even cross the fog line slightly.
Drive with the flow of traffic, not based on little white lines painted on the road.
Hopefully if a Semi Truck starts drifting towards a BMW, it will get out of the way, rather than insisting it is RIGHT to stay in its own lane. Stand one's ground!!
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Lane assist is not autonomous driving. It is drivers assistance. It is there to keep the driver from drifting out of lane causing a wreck.
Use the blinker, or turn the system off. I'd be shocked if the system allowed a close pass at any sort of speed anyhow, collision avoidance shouldn't allow it.
Liked 4,512 Times
Forcing a single solution in all driving situations is incorrect.
Quoted: 980 Post(s)
Liked 582 Times
I wonder if autonomous or semi-autonomous systems are designed with this in mind.
Steve
Quoted: 959 Post(s)
It would seem prudent to allow a little extra room for the cyclist possibly needing to veer to avoid a road hazard. In Illinois, State law requires motorists to give at least three feet of clearance when passing in recognition of this possibility.
Steve
Steve
Quoted: 980 Post(s)
Liked 582 Times
@CliffordK said it better (#38) than I did.
Steve
Steve
Quoted: 2281 Post(s)
Liked 1,710 Times
Dallas, TX is like that. You use your turn signal to change lanes and other drivers see it as a challenge.
Quoted: 1062 Post(s)
Liked 665 Times
Modern cars have sophisticated controls built into the vehicular computer. The manufacturer has to choose which settings should be the defaults when the vehicle is delivered to the customer. The BMW is shipped with settings that emulate the "classic BMW driving experience." This includes both the "buzz cyclists" and "frighten your passengers" modes. To disable these, you have to go into the Control Panel, "Advanced Settings," and "Driver Entitlement Modes."
genec
Quoted: 13658 Post(s)
Liked 4,532 Times
Blinkers at least signal intent... lane drift without intention is a collision about to happen.
Randomhead
Liked 3,699 Times
My car has what's called "lane keeper assistant" if you change lanes, it will fight you unless you have the blinker on. But it lets you change lanes.
Nissan autonomous car recognizes cyclist and still doesn't give enough room
That's why the autonomous car motto should be "autonomous cars, u gonna die"
Quoted: 959 Post(s)
I saw a case of instant karma on this score. I had plenty of room to merge in front of someone and they sped up to keep me from doing it, but I had already gotten in front of them. So on the next block, the driver tried to put me on the sidewalk. Unfortunately for him, the car behind me was a cop.
Nissan autonomous car recognizes cyclist and still doesn't give enough room https://twitter.com/Korben/status/837990377097428992
"Tetsuya Iijima, global head of autonomous drive development at Nissan, is behind the wheel, but fails to over-ride the car and move out either" Video: Nissan driverless car in cyclist close pass | road.cc
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
Don't you do the same hyping routine with every optimistic (only optimistic!) press release you can find on the Internet that you can spin into your fanciful predictions about the imminent arrival of inexpensive driver less vehicles available for safely transporting passengers at bargain prices, presumably all the while making profits for the organizations producing, owning and/or operating these miracle vehicles?
Quoted: 959 Post(s)
Why not?
And even if I did...
