Winter internal gear hub bike
Merry Christmas, (hey I know, I'm a day early)
I have thought off and on about a 3 speed internal gear hub Mountain bike, Plus bike or cruiser (klunker) bike either with nobbie's or studded tires for a winter bike. Do any of you ride Internal Gear Hub bikes for your winter cruiser? If so what brand hub, how many gears, what type of brakes and on what style of bike? If you could share photos, that would be greatly appreciated, and again, have a Merry Christmas.
I built a winter bike with a 3 speed hub and drum brakes last year, then we didn't have winter in Chicago so I don't know how good of a winter bike it is yet. Short blogpost here. We're supposed to get snow today so I'll put my winter tires on and get some riding in after Christmas.
I use Schwalbe winters on a 700 c wheel with a 18 mm. rim. I currently have them on an old Centurion Accordo with one speed but sometimes I use them on a Surly Steamroller with a SA 3 speed from Somafab. Actually works a little better because I can drop gear inches for tougher pedaling. With a 18 tooth sprocket and a 42 tooth chain ring it works fine although the tires are good for a few inches of snow or sheet ice, not frozen ruts and deep snow. The SA hub works when the temps are very low quite well and doesn't get jammed up with ice like a derailleur can. I do run the hub on 5/20 synthetic motor oil instead of grease, though.
Jedi Master
Thanks. It's not very hilly where I live so the range on the 3 speed is fine. I've settled in on 34/20 gearing which gives me 35/46/62 Gear Inches. 3rd gear is my cruising gear and the other two are for climbing the small hills we have on the North Shore of Chicago. 35" is about the same as the 34/25 low gear I have on my road bike which will get me up anything I have encountered in the Midwest. Moving the range up or down is as easy as swapping out the sprocket.
The drum brakes are perfectly adequate for the way I use the bike. I don't ride very fast or aggressively so emergency stops aren't really an issue, and the brakes work fine for normal stops. My other winter bike has cantilevers which don't work at all when they ice up, so drums are a definite improvement over that. I went with drums instead of disks because I think they will be lower maintenance. I have BB7's on my touring bike and I am always fiddling with them to keep them from squealing.
I have several IGH bikes* I also have an old MTB with the Studded tires on it.
If I had as long a winter as you in the northern inland states did
I'd build a new wheel set with the recent S-A 4 or 5 speed drum brake hub , but as I'm on the NW Coast,
the drum brake freewheel hub is just fine , proven reliable over past 30 years..
* Rohloff Disc another with Magura Rim Brakes , 1 V, (Sram i-9) and the Brompton M3L, side pulls
Quoted: 980 Post(s)
Liked 582 Times
I'm using my old Dahon Mu XL as a dedicated "winter" bike. This bike has a Nexus 8-speed hub. The frame has 12,500 miles on it. When it was my "normal" commuting bike, I would use a "red band" hub-equipped wheel in the summer , and a "standard" hub in the winter. The winter hub has about 9,000 miles on it. I ditched the rim brakes and installed a roller brake after I wore out my second rim. Here's the bike defrosting in the Men's room at work.
Steve
EDIT: Studded tires, of course. @kingston: I commute from Mundelein to UIC by this bike and METRA. I bought my spare Nexus wheel from one of the mechanics at Kiddles. Small world!
EDIT2: Roller brake on rear only.
Steve
Jedi Master
My office is above Ogilvie so I just ride my coaster brake cruiser a mile-and-a-half to the train station and take the elevator up from the train station.
I bought a few bikes from Kiddles myself over the years.
Quoted: 980 Post(s)
Liked 582 Times
Another "how I built my first wheel" story: That spare wheel I bought was built by the mechanic at Kiddles. When I got home after picked it up, I noticed it had been built with spokes crossing over the valve hole making it difficult (at best) to inflate the tire. I took it back to the shop and was told I was S.O.L. because the mechanic no longer worked there. So I did it myself and have never looked back, and build all my own wheels.
Life/Lemon=>Lemonade!
Steve
Quoted: 7348 Post(s)
Liked 2,465 Times
IGH and drum brakes are good choices for winter riding. The Citi Bike fleet has thousands of bikes outfitted this way. Drum brakes need less frequent servicing than any other kind. Same for IGH.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Nice bikes. I've been off work since the 20th. Unfortunately, It has snowed steady since then and the roads seam too messed up to start riding again. The two bikes I though of are
https://https://westridgeoutdoors.com/collections/beach-cruisers/products/chatham-3-mens-beach-cruiser-bike?variant=1914614317086
https://https://www.sun.bike/bikes/revolutions/#3-SPEEDINTERNAL26
Seeing how I just bought a new bike last year, I will have to wait awhile to buy my bad weather bike.
Liked 2,465 Times
@JonathanGennick, what happened to the NuVinci? We have those hubs on the Citi Bike fleet in NYC.
Quoted: 685 Post(s)
Liked 55 Times
Quoted: 261 Post(s)
Liked 11 Times
The hub I use is the Nexus 3 without roller brake.
Quoted: 207 Post(s)
Liked 108 Times
A general question- do IGHs in general work down to -20 degrees Fahrenheit? I like the idea, since the dang derailleurs attract so much slush and dirt, but at least they will run to -20...
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If I ever came to my senses and built up a multi-speed bike for winter, an IGH would be my choice. Something that runs on oil instead of grease.
Quoted: 685 Post(s)
Liked 55 Times
I sometimes feel my Nexus IGH downshifts a bit sluggishly in the extreme cold, because it's relying upon a spring in the hub to pull back on the shifter wire. My NuVinci hub has wire pulling in both directions. Again though, I've not had any -20 F weather to experiment in. Coldest we've had lately has been maybe -5 or -6 F.
Nexus also is grease lubricated, inside, that thickening in the cold can be an issue..
Rohloff uses thin oil inside and has a pull-pull 2 cable grip shifter... disc brake option..
Quoted: 261 Post(s)
Liked 11 Times
I don't know anyone who rides in that kind of extreme temperature with an internal hub. It would not surprise me if it worked but you'll just have to pedal harder!
I love the 3 speed hub and have been riding them for over 25 years. However, today was so cold, it made riding any bike difficult. I still believe when the temperature drops below 20 degrees F, the internal grease of the hub starts to freeze making it more difficult to pedal. The hub is about 4 years old now but it amazes me how the weather effects the internal hub. The temperature was 8 degrees today so maybe I was asking too much.
I have ridden all sorts of internal gear hubs, Shimano 3, 7 and 8 and also Sturmey Archer 3 and 5 and Torpedo Duomatic.
The best in my opinion for speed, lack of drag, simplicity and great sound is the Nexus Inter 3 speed, with a coaster brake. This hub goes on any bike with any sized rim. It's just so versatile. And it makes a great ticking sound :-)
