Is Cold Setting Frames for wider hubs a Hack?
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Prying frames open with levers to allow wider hubs always seemed like a hack to me, so I've never done it. I suppose with an "expert" set up it might work out perfect, but most aren't going to have this... One side will end up bent more than the other, stays bent in different locations, miss aligned dropouts, chainring to hub chainline less than ideal, etc. I'm curious as to what the expert frame builders say about the practice of cold setting older frames for wider hubs? Can it be done properly? Is it usually?
its 'not like brazing it, in a frame jig, aligned to be be like that .. to be as desired, in the first place..
if that is your question.
pay for a new frame solves that.
Quoted: 4399 Post(s)
Liked 1,556 Times
All that is necessary is firm grip on both dropouts and pulling them apart with your hands. Because it is just even pressure applied simultaneously, it opens the sides evenly with no marring. After both sides have moved the necessary 2mm, you can confirm that they spread evenly and then square the dropouts. Pull, measure, pull, measure.
I can't remember how many steel frames I've done, they always came out symmetrical without requiring correction. People make it sound like this very small alteration is complex or dangerous - but it is less of tweak than correcting the derailleur hanger.
Randomhead
Liked 3,696 Times
if you are talking a vintage frame, then I almost guarantee the rear triangle has been moved around for alignment purposes. I prefer clamping the bb and bending the stays one at a time, although I have done it by standing on one dropout and pulling on the other.
Liked 1,556 Times
If you clamp things down you create more opportunity for an asymmetric result. If you apply symmetrical force to a symmetrical frame you'll get symmetrical results.
It requires some force to spread the stays with a opening-the-chips motion, but I'm not a body builder.
Quoted: 4201 Post(s)
Liked 3,861 Times
Like Eric I prefer to clamp the BB faces and work one side at a time. I have seen, and done, asymmetrical widening when using only one's hands/arms to spread the drop outs. Most times I can point to the heavily dimpled driveside chain stay and it's reduced cross section as to why that side was the one that moved more. Cheap bikes suffer from this more often then well made ones do.
I don't consider the well done realignment a hack but sadly it can be easily done in a wrong way. Andy
Quoted: 2338 Post(s)
Liked 2,822 Times
Sheldon covers this pretty well. i did this once and had good results
https://www.sheldonbrown.com/frame-spacing.html
Quoted: 1074 Post(s)
Liked 295 Times
I put the frame on a workbench with the rear stays overhanging the edge.
Then I insert the board from the front.
By pushing down on the board I push the top stay up, while the bottom stay is left unaffected.
Once sufficient displacement is achieved, I flip the bike over and do the other side.
Quoted: 5781 Post(s)
Liked 2,578 Times
Prying frames open with levers to allow wider hubs always seemed like a hack to me,..... One side will end up bent more than the other, stays bent in different locations, miss aligned dropouts, chainring to hub chainline less than ideal, etc. .... Can it be done properly? Is it usually?
FB
Chain-L site
FB
Chain-L site
Quoted: 49 Post(s)
Liked 13 Times
As mentioned old steel frames were routinely wrestled into shape. It's really nowhere near as complex or dangerous as you may think.
Get an old disposable steel frame and practice manipulating it precisely. You're barely moving things. It's not like bending a paper clip back and forth until it breaks.
Quoted: 103 Post(s)
Liked 144 Times
This is not a hack and I performed this many many times successfully on all sorts of bikes as we went from 126mm rear spacing to 130mm for road bikes. Often times after someone stuck a 130mm rear wheel in and broke their axle because the dropouts were splayed and bowing the axle.
A vice is your friend. You might get it evenly spaced going freestyle but you take chances. Use a vice, go slowly, you aren't moving it much and then use a string to measure.
Obviously has to be steel and the alignment of the dropouts has to be done after the stays are wider. Park makes a tool that makes the job very quick, accurate and easy.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Randomhead
Liked 3,696 Times
Of course, it does require the ability to measure, but this is the framebuilding forum, you can't make something if you can't measure it.
Liked 1,556 Times
that makes no sense. And untold thousands of steel frames have been aligned using this same method. Bend one at a time, measure. Tweak until you get that side right. Bend the other one. By pulling them apart, you have no idea.
When someone on a forum asks about doing something, I'm going to assume I'm not addressing either a shop mechanic or a frame builder, but someone doing it for themselves without a frame alignment table. So when I picture the kind of ham-fisted mistakes levers and clamps can do, I recommend a method which generally works very well because it is self aligning and doesn't involve putting levers on paint and thin tubing.
So what is it that doesn't make sense, exactly?
Liked 2,578 Times
What dosn't make sense to me is the assumption that the stays will magically move the same amount.
First of all they're rarely identical with the right typically having more crimping which can affect it's flex and bending properties.
The other issue I see relates to how steel flexes and then bends. As each stay flexes the resistance increases, and there'll be decent symmetry. However when the first reaches it's yield point, the flex property changes, so it'll start to take a set, while the other is still flexing. The fact that it's now yielding may prevent it's stiffer companion from ever reaching it's yield limit.
There are ways to manage this, but blind faith in symmetry isn't one of them. It may work well, or at least good enough, but there's no assurance that it will.
For those reasons, I'm a proponent of the one leg at a time approach, even for home mechanics. With minimum though and effort, the forces can be applied so only one side moves, leaving the other as a reference point. Them the roles can be reversed and the 2nd side bent, using the new position of the 1st as the reference. This offers 100% reliable control of the process without reliance on blind faith.
FB
Chain-L site
FB
Chain-L site
Liked 1,556 Times
You say that the two sides are unlikely to hit yield at the same time and that means that one will bend more than the other. That really isn't how it works - when the steel begins to yield it still takes increasing force - more than the force to bend below yield. So the resistance to further bending is sufficient to make the other stay move beyond yield. Your post appears to suggests that the force required goes down after yield.
If frames didn't like to flex symmetrically they would not be much fun to ride.
Anyway, despite all the outrage, it is easier to just pull the stays apart without all the levers and clamps. Should you get so unlucky that your stays end up bending asymmetrically, then break out the tools. But I don't understand making something more complicated than it needs to be "just in case" when there is no unilateral outcome. We're moving each stay 2mm, after all. No need to go Rube Golderberg on it right away.
How many of you objectors have ever tried this to report a problem with it?
Liked 2,578 Times
Where is this blind faith stuff coming from? Check your work.
You say that the two sides are unlikely to hit yield at the same time and that means that one will bend more than the other. That really isn't how it works - when the steel begins to yield it still takes increasing force - more than the force to bend below yield. So the resistance to further bending is sufficient to make the other stay move beyond yield. Your post appears to suggests that the force required goes down after yield.......
As for the question of flex symmetry, it doesn't really matter because the rear triangle is tied together by the axle, so it doesn't matter if the stays would flex equally if they weren't married. In this way they can be comparable to two unmatched solo riders riding a tandem.
And yes, what I disparage as blind faith can often work, and I said that. What I said is that it isn't reliable, and it isn't.
FB
Chain-L site
FB
Chain-L site
Liked 1,556 Times
Liked 2,578 Times
Way back when, back in the Bronze Age, I did it the way you describe, and generally had good luck. But as things evolved and everybody started measuring stuff to the last micron, I was forced to change and moved to my current method because, even though I would be OK with minor errors, others weren't anymore.
FB
Chain-L site
FB
Chain-L site
Liked 1,556 Times
Liked 2,578 Times
It doesn't really matter how far off the bike ends up, first because it's easily corrected when checked, and secondly because small errors don't matter. The issue isn't being functionally OK, it's a question of appearance and image because folks fret over this nonsense. I don't want to be in a position of defending work that a client (wrongly) believes is not good enough.
There's also what I've learned in my 40 years manufacturing stuff. I'm not a believer in inspect and correct, and prefer inspect and confirm. By that I mean I try to use methods that reliably ensure that the results will pass QC, rather than need to be reworked.
Something like 50 years ago someone gave me a pencil with an eraser at both ends. On it was "If you don't have time to do it right, where will you find the time to do it over?" I've kept it for decades, and adopted the philosophy in my manufacturing operations, and by extension on bike work.
FB
Chain-L site
FB
Chain-L site
Liked 1,556 Times
You're reading more into what i say than what I put into it. First of all, I said (3 times now) that the simultaneous method often works, so interpreting that to mean that every bike is off at all is extremely selective reading.
If the first measure was not centered, then I would apply leverage to one side. I just have never had to do that in 10 or more of these I have done for myself or customers. The results were always symmetrical to the limits of a Park frame alignment tool to measure and right on 130mm.
Liked 295 Times
Never gotten it good enough to be content with the result from spreading both simultaneously.
Particularly dimpled chainstays can be very obviously different in characteristics.
A workbench or sturdy table, a plank and some blocks. Or a pair of thick books.
Not really things that are hard to come by.
Oh, and perhaps a strap to protect the brake bridge.
Randomhead
Liked 3,696 Times
what didn't make sense to me was that doing this in a controlled fashion bending one stay at a time was somehow worse than pulling them apart. But I'm sure the OP has walked away in horror at this point.
Liked 1,556 Times
With the right tools (alignment table), anything is possible. When you are using ad hoc tools the risk of messing something up increases with every additional tool applied to the frame.
Some people are very natural mechanics - they have a good feel for the kind of force that needs to be applied and the potential for tools slipping and stress risers. Most people do not have that sort of sense for things and half the threads in the mechanic section demonstrates this.
Spreading the frame with a minimum of tools decreases the chance of crushed tubes, scuffed paint and applying too much force. It is a very gentle method, and the only downside is that it might require going back to a lever if it isn't opening symmetrically - which in both my and FBinNY's experience is actually rare.
It is the most conservative and safe approach.
Randomhead
Liked 3,696 Times
you can put something soft between the dropout and your lever. Like a rag
