Elite Quick Motion Rollers
Hi...Just purchased the Elite Quick Motion rollers. Love them for the compact fold up capability...but....
Just want to check my expectations against actual experience. On the minimum resistance setting I imagined the ride to be similar to riding on the flat or closer to a spin but I still seem to have a strong level of resistance. It's like going up a hill so after a short while you're getting fatigued with no respite in sight. Is this normal?
Thanks
Thanks
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Thanks
Thanks
You'll notice that resistance on rollers is more sensitive to tire pressure than out on the road. More pressure = less resistance.
You'll find that rollers will tire you more quickly than riding outdoors because there are no descents, stop signs, or traffic lights. That steady effort is the whole idea. I figure it takes about 75% of the time to get the same effect on rollers as it does outdoors. Maybe only 50%.
Results matter
Results matter
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The product data sheet for the Elite Quick Motion rollers shows a power vs speed graph.It doesn't look like these are as free spinning as some other rollers on the market. For example, Sportcrafter specs their Cadence rollers at about 140 watts at 30 kmph (18.6 mph) while the graph for the Elite Quick Motion Rollers show almost 200 watts at the same speed.
I'm open to correction.
-Tim-
-Tim-
Liked 1,938 Times
-Tim-
-Tim-
Results matter
Results matter
- Soli Deo Gloria -
Liked 736 Times
Your Sportscrafters Overdrive Pro has a similar principle in their mag resistance unit, though probably not the identical resistance, noting that the OP's Elites have 3 resistance settings and Sportcrafters aren't adjustable AFAIK. In any case, the Sportcrafters OP unit needs about 400 watts to achieve 30 mph, while the Elite tech data shows 420 watts at 40 kph or 25 mph, probably on its max setting. For sure not free spinning but should be fine on the lowest setting for easy workouts. My guess. Does that seem reasonable to you, 400 at 30?
I was not referencing the Sportcrafters Overdrive drum but their standard, non-resistance "Cadence" drum.
Sportcrafter claims the Cadence roller is a little over 200 watts at 30 MPH. The data sheet for the OP's Elite rollers claim almost 350 watts for the same speed at the lowest setting. That's 75% more resistance.
Sportcrafter Overdrive (resistance) drum is a completely different animal and this isn't what I was talking about. To answer your question however, Sportcrafter has a video which shows a power meter used on the Overdrive rollers and it is in excess of 400 watts at 30 MPH. I don't use a power meter so that's all I can go by.
Back to the OP's rollers, I was just comparing them to what I have and if the manufacturer's graphs are to be believed then they are not as free spinning as the Sportcrafter Cadence rollers.
-Tim-
Liked 1,938 Times
-Tim-
-Tim-
Results matter
Results matter
Elite Power Curve
Got this from an Elite cite
Speed mph 0 3.1 6.21 9.32 12.42 15.53 18.64 21.74 24.85 27.96 31.068 34.17 37.28
Speed kph 0 5 10 15 20 25 30 35 40 45 50 55 60
Level 1 0 26 53 83 112 145 180 218 260 307 354 406 462 watts
Level 2 0 30 62 99 139 183 229 279 332 386 444 505 566
Level 3 0 38 82 132 185 242 302 364 426 491 559 627 695
I will try to put in chart and line up the speed to watts but so far no luck.
