Inner Tube Presta Stem came out of tube.
Quoted: 24 Post(s)
While adding air with a portable pump the bike fell over and the tube stem popped out. I have not taken the tire off yet to check the tube but I see nothing torn on the stem.
What I see on the stem is what appears to be a rubber grommet, can this be put back into the tube or would you just get another tube.
I am assuming you mean the valve CORE came out of the tube. If that is the case, yes, the valve base(The base of the whole valve core) screws into the valve sheath or valve tube(Not sure of exact terminology). Then the top of the valve core screws down into the base to allow for sealing or opening to allow air to enter (or exit).
Quoted: 24 Post(s)
When the bike fell over I was still holding the pump in my hand and the stem was still locked into the pump head.
The only way for the whole stem to come out would be for it to tear loose from the tube. In which case the tube is ruined.
Quoted: 18415 Post(s)
Liked 15,545 Times
Quoted: 24 Post(s)
What came out looks kind of like this. The grommet is a little different in shape and it has a groove around it.
https://www.backcountry.com/stan-s-n...RoCPXgQAvD_BwE
Liked 15,545 Times
Are you trying to troll us? That's a stem for a tubeless rim. Either way, if a stem broke completely off a tube or you pulled a tubeless stem completely out of the rim, the tire would lose all air. In the case of a stem ripped from the tube, the tube would be toast. Simple as that.
Quoted: 24 Post(s)
It did lose air as the bike fell over and the stem tore out.
The rim is for a Schrader tube but have been using Presta with an adapter. It does seem I forgot to put the adapter in during the last tube change and the rotating ring was loose, that probably contributed in the stem comming out easier.
On the stem that came out of the rim I don't see any torn bits, just the the stem and a rubber grommet. I will know more when I take the tire and tube off tonight.
No troll going on at all.
Liked 15,545 Times
Quoted: 24 Post(s)
Quoted: 6193 Post(s)
Liked 4,809 Times
In all fairness to the OP, you should believe him. In fact I had a presta stem come completely out of an inner tube also and it was a very clean separation from the tube and had a little patch of rubber near the bottom that was similar to the stems for tubeless tires.
Mine came out because the locking head on my air hose had not been releasing fully and I had to yank it every time I filled it for over a year. After pulling it out I replaced the air hose on the pump with a replacement from Nashbar and now it works better than ever.
Trying to re-install the stem might be something that's possible, but probably not trustworthy and will likely need tender handling every time it's filled. Something one should only do when they want to prove the others wrong.
As tubes don't cost much, why bother with the trouble.
edit.....
Daay-anng ! just noticed the price of those stems. I can get four tubes for that.
edit.....
Quoted: 24 Post(s)
I was shocked when the stem showed no evidence of tearing so I thought others might have seen this before and may have been able to fix it successfully getting me back on a bike faster.
Liked 4,809 Times
You got a Walmart there in Ponca City. These are what I buy.... https://www.walmart.com/ip/Bell-Tube...Valve/34038251
And before someone says that's why my stem came out...... It came out of a Continental inner tube that I had at the time.
Quoted: 24 Post(s)
The last time I checked had no 700c tubes, it seemed everything had gone to smaller diameters. I will take a look but will still order some tubes as well.
The tube that lost the stem for me was Giant brand. I wonder of those are made by Continental.
Quoted: 2281 Post(s)
Liked 1,710 Times
I don't think I'd trust it at 80-90 PSI. With my luck it would shoot out at high speed as soon as I mounted the bike. Or wait until I'm 20 miles down the road.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I almost never see any 700c tubes in Walmarts around here either. I just skip the trip and internet order from your preferred vendor.
Quoted: 4806 Post(s)
Liked 3,928 Times
Not trying to troll at all, I also did state that the photo was of one for a tubeless set up but what came out of the tube was similar except it has a deep groove around it.
Ben
OK.
Logic. Using wrong tube.
Why not use Shrader tubes for shrader rims?
Yea
Interesting but logical
Operator error
I’ve been guilty of making stuff work ,
When necessary,
Knowing it could fail
Quoted: 24 Post(s)
I don't know if it contributed or not, I think the fact the locking ring was not tight was as much or more of a factor.
Quoted: 24 Post(s)
There is nothing wrong with using Presta Tubes on Schrader rims as long as you have an adapter. It if is worth it or not is a different question.
A lot of forum members also say the adapter isn't important. Quite a few people on the forum claim decades and thousands of miles of no problems running Presta on Schrader rims.
Doing what I have been doing is in no way unusual.
Bikes: 2007 Giant Cypress DX, Windsor Tourist 2011
Quoted: 24 Post(s)
I used to buy those also, and they work just fine, but now I have deeper dish rims and the valve is too short. An extension works fine as a temporary fix, but in the future I would prefer buying tubes that come with longer valves.
Quoted: 1819 Post(s)
Liked 1,693 Times
It was this forum that got me using Presta Tubes on Schrader rims. I have since found the Touring bike crowd do it a lot to have an easier time finding replacement tubes in small out of the way places.
Quoted: 18376 Post(s)
Liked 4,511 Times
Old tubes had the valves more or less bolted down. But, I haven't seen those for eons.
Nonetheless, I'd try the repair out. You can't be any worse off than you are now.
The outer lock ring is unnecessary, and should only be finger tight. Its main purpose is to help one push the pump on the valve, I think. But, the tube will work just fine without it.
As far as department store tubes... I've used them off and on. It is the oddest thing. They often have a shelf full of 20" tubes, but have the space, but no tubes of narrow 700c - 18/25 tubes, or perhaps even the next size up. My guess is that they sell out of those quickly, and nobody has bothered to try to get a better estimate of actual sales.
The other thing that likely happens is that they'll sell the 20" tubes in singles, but for the 700c tubes, an avid cyclist may come in and clean off the shelf.
Nonetheless, it never hurts to check.
Quoted: 24 Post(s)
