Tips & tricks thread?
Born Again Pagan
Bikes: Schwinn hybrid, Raleigh MTB
Dont forget to regularly lube your parts in the winter.
-Repack your bottom bracket, headset, and hubs in the fall.
-Lube your cables weekly, after lubing, dab a glob of grease at each cable housing end.
-Dont forget to lube your gear shifters and brake levers.
-Lightly spray lube on the outside of your derailers, hubs, bottom bracket, seat post, quick release levers and any other exposed metal before each ride.
Bikes: 2010 Davinci JointVenture, 1994 Specialized Epic Comp, 2007 Steelhead custom road bike, Surly CrossCheck, 1999 Kona MuniMula MtB, Wife:Civia commuter, Steelhead custom road, 1993 Marin Mtb Extracycle , Kids:Trek tag-along, Jet20, Trek830
For shifters and cables (not drivetrain) I use silicone spray for winter lube. It doesn't gum up in the very cold.
Socrates Johnson
I've had a problem with frozen thumbs at below-freezing temps. I wear Saucony running gloves as liners under ski mittens, and usually my hands are fine. But, we've been having windy 0 degree nights (I ride home from work at 11pm), and by the time I make it home (6 miles) my thumbs are painfully cold.
To solve this wind issue, I cut a hole in the bottom corner of a couple 1 gallon plastic ziplock bags and slipped them over my handlebars. The bar ends on the mountain bike help keep the baggies in the right position since I have those bar ends that make an almost 90 degree angle out in front of the brakes.
Essentially, this is a poor mans poggie and REALLY cuts down on wind chill on your hands! I'll take a few pictures when I get home tonight.
Bikes: 96 gary fisher 'utopia' : 99 Softride 'Norwester'(for sale), 1972 Raleigh Twenty. Surly 1x1 converted to 1x8, 96 Turner Burner
Quoted: 9 Post(s)
Put a few drops of cycling oil in the cable housing going into your rear derailluer. Do this occasionally. It will work itself down quickly. It will help you shift in frigid temps.
If your riding in frigid temperatures. Get good gear. It's worth the comfort.
Okay, here are some pics of the frostbite fightin' baggies, as promised! And obviously I would be wearing gloves when my hand is in the baggie.
nw commuter
Bikes: trek antelope, trek 3900
+1 ziplock pogies
+1 ziplock pogies
I find that when it warms up, the pogies trap moisture, so if you're riding without gloves they give you a clammy feeling when they stick to back of your hands. Wearing a light glove works great. They're good for rain, because soggy wet gloves are no fun, either. I wrapped packing tape over the hole where the cabling passes thru, and that keeps the bag from continuing to rip open wider. I roll up the mouth of the bag to make it easier to place my hands on the bars and it helps shape them open.
Wanderlust
Bikes: Specialized Stumpjumper for MTB and a specialized hardrock for touring
Another tip, dont try to wash your bike when its below freezing... Or just after it warmed up from a below freezing night and the metal on the bike is really cold. I tried to clean the dirt off my bike the other day with soap and water, I couldnt dry it quick enough, it kept freezing to the metal.
Does anyone have a tip to keep freezing fog from collecting on your glasses?
i like using a 5 speed 20" rear rim during winter so i can keep my feet on the ground on the really icy days. plus it moves your weight back. i also make sure my tires are at least 35psi because if they get too low i end up just spinning my tires more than i move.
nw commuter
Good howto on winterizing an extracycle: https://www.webikeeugene.org/index.ph...our-xtracycle/
Bikes: -1973 Motobecane Mirage -197? Velosolex L'Etoile -'71 Raleigh Super Course
On really sloppy days, I spray the underside of the downtube, BB and chainstays with Pam cooking spray. I give the underside of the fenders a good spritz, too, helps keep them from icing up and rubbing on the tire. It's just vegetable oil so it's biodegradable, unlike WD40. Won't displace water at all, but the schmutz just wipes right off. Especially handy if you keep your bike locked up outside.
Bikes: Workcycles FR8, 2016 Jamis Coda Comp, 2008 Surly Long Haul Trucker
Liked 6 Times
Check out your local salvation army for clothing. Spent $3.50 and came home with a pair of gloves, 2 hats, neck gaiter, and ear warmers.
Bikes: Lemond Alpe d´Huez, Scott Sub 10, homemade mtb, Radlbauer adler (old city bike), Dahon impulse (folder with 20 inch wheels), haibike eq xduro
if you have disc brakes and particularly avid elixir crs take out the brake pad retaining bolts occasionally and lightly smear with grease to stop them seizing in the caliper. Alternatively (as I had did) just throw them away and replace with split pins. If the bolts seize in the caliper (which one of mine did) you might have to throw the brake away because drilling them out is not so easy as the caliper body is soft aluminium while the bolt is very hard steel. In my case I managed to cut the bolt up with a dremel and slot the head to get the bolt out but it was a close thing.
only the dead have seen the end of mass motorized stupidity
Plato
(well if he was alive today he would have written it)
Plato
I was referring to the brake pad retaining bolt- this doesn´t exert any clamping force at least on my avid elixirs- it just goes through the hole in the brake pads and stops them exiting the brake- some brakes, e.g. at least one model of Shimano LX, have a split pin here as standard (albeit usually the lower end brakes).
Plato
Plato
Single-serving poster
Dough Mestique
Here area few things I've learned:
1. Carry an extra layer to put on in case of a mechanical, yours or someone else's
2. Keeping your legs warm is key to keeping your feet warm
3. Metal cleats conduct heat away from the bottom of your feet, the hardest part to keep warm. Plastic cleats conduct less and are noticably more comfortable.
Bikes: 2008 Gary Fisher Tassajara
I am not sure if this has been mentioned, probably has, but I saw someone the other day sporting zip ties to ride through the snow..
Bikes: giant revel 1
+1 to the cheap bag idea I plan on do that myself after reading your post. I really needed something over the weekend when it rained a crap ton. I also get off work at 11 at night and I also have a fun and interesting 7 mile ride home.
If you lock your bike up outside bring a lighter with you so you can get your bike unlocked. Instead of haveing to cut the lock or break a key off inside the lock.
Fat man in a little coat
Bikes: Trek 7.3 FX, Trek 1.2T
Plasti Dip your cycling shoes to keep your feet toasty and dry! Removal is easy as you can peal it off, or rub your thumb over it until it starts to fall apart. A good coating will last a while before you need to remove it and redo it. It is only like a few dollars at your local hardware store and comes in many different colors.
