Any Clydes Using Speedplay Pedals?
Hello all,
Im in the market to switch out my Shimano SPD pedals fo Speedplay. Speedplay is "double sided" so I wont have to fish for the right side of the pedal everytime I try to clip in. I not sure on the weight limit of the entry level steel version so i was wondering if any clydes are using them? Im 280lbs but never stand out of the seat and let all my weight rest on pedals - though I may want the option as I get lighter.
https://speedplay.com/
Thanks all.
Thanks all.
Bikes: Fuji
Quoted: 8 Post(s)
I have a pair of Light Action, I like them. I may switch as I feel they have a bit to much float as my heels clip the chainstays and tend to get rotational knee pain which I don't like.
The Light Actions don't take much to get out of them. I've stood up to go up a hill and unclipped...that was fun.
My major problem with them is I don't always get clipped in but that is probably just me trying to rush it and get out of the intersection.
Thanks snowman - the "light action" are the entry-level ones at around $120? Those are the ones Im looking at because my SPD pedals are a pain trying to "flick" them to the position that I can click into. At 280lbs I dont see the point in spending another $50 to save a few grams in weight.
As I say I never stand on climbs so Im more concerned with the pedal snapping due to me being a heavier rider. However, I cant find any evidence that that would be the case.
Shimano SPD pedals are also double-sided (and much cheaper than SpeedPlay). Perhaps you're thinking of SPD-SL road pedals? Have to admit, I've never tried SpeedPlay pedals. Couldn't get over the enormous size of their cleats...
SuperGimp
Which shimano pedals are double sided? Not the 105 SPDs I got my wife, that's for sure.
I have used X-2 pedals for 10 years and got light actions about 2 year ago at 240 lbs. No issues with weight, just steer clear of the top end speedplays - they have a 180 limit.
I find speedplays incredibly easy to clip in to and get out of as well. I have knee issues, so Speedplay solves that for me but they're great pedals (IMO)
Bikes: Fuji
Quoted: 8 Post(s)
Bikes: Reynolds 531P road bike, Rocky Mountain Metropolis, Rocky Mountain Sherpa 10, Look 566
I had double sided SPDs and found them actually harder to get into than the single sided.
I don't seem to have any problem finding the correct alignment with either single sided road pedals or double sided mtb pedals. But, I've been riding clipless for over twenty years. Mrs. Fred on the other hand has been riding clipless for less than 6 years and reports that she finds normal single sided road pedals (look, shimano spd-sl) to be easier to find. According to her, because, they always hang down in the same orientation. Opposed to mtb pedals (spd, egg beater, etc) where she has to first orient to a pedal that may be rotated to any orientation.
As I said, its not something I've noticed. But, I clip in for the most part without thinking about it. She seems to notice a difference. Not that any of this has anything to do with speedplays. The last time I tried speedplays was over 15 years ago.
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
Quoted: 10 Post(s)
I'm planning to switch to Zeroes for the road bike this season. I've been with Look and compatibles for over 25 years.
I've had X-2 (stainless) on two bikes for over 6 years - I'm usually between 230 and 250. The cleats can be a pain in the neck sometimes, but I'm happy with the performance.
Thanks guys - great feedback. It sounds as if speedplays will work for me , the basic ones. Another quick question: My shoes have SPD-SL cleats (non-recessed), Im assuming the cleats that come with speedplays just bolt right on with no hassle?
Thanks again.
Thanks again.
not as fat as I was
Bikes: Trek 7000, Trek 5500, Fuji Newest 1.0
They're expensive and look ridiculous. I tried a set and hated the float and how easy they unclipped. SPD for me from now on. If you're looking to spend some money on toys I'd look elsewhere. Little to no value here.
humans can be so....rude
If you want good retention, I suggest you look for some older Shimano SPD-R pedals. They were discontinued, more or less, because people found them so hard to get out of. If I tighten more DA models down tight, it takes all the leverage my size 51's can muster to get out of them.
Bikes: Fuji
Quoted: 8 Post(s)
They should come with an adapter. The cleats are 4 bolt pattern and most shoes are 3 bolt pattern. You may have to fiddle with your saddle height after installing them.
Quoted: 3375 Post(s)
Liked 5,512 Times
Thanks again all - I think I will pick up a pair of the "light action" speedplays this week. My wife has a pair of the pedals and she loves them. Ive witnessed first-hand her ease of clicking into the pedals from a standing start when Im still struggling to "flick" my pedal into the correct positon. My main concern was my weight - but it appears weight is only a factor on the higher end versions where the pedal is made of less friendly weight-bearing material.
Bikes: Specialized Hardrock and Secteur and a Cannondale Synapse 5
Same size as you, no problem with speedplays and I ride HARD!
Guest
Posts: n/a
Quoted: Post(s)
Hmm. My last attempt at clipless was Speedplays. Even after a call to their headquarters we never found a way to angle the cleat enough for my right leg. I might need to revist them when I'm riding again.
Not compatible with Shimano sandals..there are alternate wider axles,
but not thru cheap Mail-order-web sources for those who are interested...
these were the Frog ATB pedals..
Bikes: ParleeZ5/Parlee Chebacco/Trek Farley/Cannondale Slice/Burley Tandem
Quoted: 19 Post(s)
Liked 10 Times
My SS ones cost the same as ultegra pedals, have easier float adjustment which is great for my knees, easier to get in and out of, easier to walk in, these all seem to be benefits to me. Maybe not good for you but I sure love mine. Oh and as for looks they look awesome but maybe different looks ugly for you.
not as fat as I was
Bikes: Schlitter Encore, RANS Seavo tandem, Fisher HKEK, Spec. Roubaix
Speedplay Frogs! Love 'em and have used them for years on my MTB and old DF, and now on my Bacchetta. Wouldn't ride any other pedals. I need and love the float (2 knee surgeries), and the zero-tension unclipping. As for clipping the stays, or crank arms, you simply need to adjust the cleat position on the shoe.
Shredding Grandma!
Bikes: I don't own any bikes
Quoted: 46 Post(s)
I've used both the road pedals and the MTB (Frogs). Have to say won't go back to them. Both pedals are easy in and out but the size of the cleat on the road pedal is a nightmare. It's hard to walk around in, get just alittle dirt on the cleat and it won't engage in the pedal, the cleats wear down quickly so make sure you also purchase the Cafe covers. Plus the pedal/cleat caused permanent nerve damage to the ball of my foot. Worse hot spots ever! the X1 or X2 I think have no weight limit; stay away from the O's as they do.
But that was my experince and many people love them. Just not for me anymore. And yes SPD's also come two sided. In fact, there are lots of different SPD pedals. I personal like Time and use the system on my road and mountain bikes.
______________________________________________________________
Private docent led mountain bike rides through Limestone Canyon. Go to letsgooutside.org and register today! Also available: hikes, equestrian rides and family events as well as trail maintenance and science study.
