Cadence vs pedal smoothness
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
We suspect there's a correlation between smoothness and crank inertial load which causes riders to be smoother on a climb than on the flat though climbing at a lower cadence than they used on the flat.
Results matter
Results matter
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
What I have observed with Garmin Vector 2 is that the transient response with the Garmin 800 and 810 head unit is very slow. Cadence is slow to respond for fast cadence changes at the track. However, I will post up a file if I can make my stuff work. We can then revisit the validity of the graph.
Liked 1,938 Times
A challenge. This winter do all of your first 2000 miles on a fix gear, Don't even get the geared bike out. Work up to 100 miles. Start on a 42-18. Dopn't get bigger than 44-17.
Come back to this thread in June and tell us this didn't work, that you aren't any smoother.
Ben
Ben
The other thing that's a bit difficult for a freewheel-only rider is to start riding fixed and not get hurt by simply doing what's instinctive for a freewheel rider. So what you say about not switching between bikes is a good idea. The fixed bike should have normal brakes too, so as not to wind up under a cement truck as has happened here. You maybe should post a little how-to-do-it along with the suggestion.
Results matter
Results matter
Version 7.0
Bikes: Too Many
Liked 2,482 Times
As promised, here is data from last night's track workout at Velo Sports Center in Carson, CA on the 250 meter indoor wooden track. I used my Garmin Vector 2 power pedals and my Garmin 820 head unit with 1 second recording mounted on my track bike - fixed gear no brakes. When I set up the pedals on my track bike the Garmin asked to set angles, set crank length and calibrate which I did. I clicked on power sensor details and turned on smoothing.
The session included a 60 lap warmup with the last 20 laps a motor burnout and then 2x20 minute motor paced efforts in a 15 rider pace line with each rider taking 2 laps on the motor before pulling up and going to the end. However, in set one, when a rider got to the end of the line, we were supposed to launch an attack from the back and gain 1/2 lap on the motor before swinging up. We each did that twice. Speed was approximately 25 mph. The next set was the same without the attacks but the speed was 26.5 mph.
HR is blue, cadence is light blue and power is brown on the first two graphs.
Overview of the workout from Cycling Analytics
I added the second interval to show how variant power is on the track.
Left right balance
Torque Effectiveness.
Pedal Smoothness
Platform Centre Offset
Power Phase
Peak Power Phase
Left right balance
Pedal Smoothness
Power Phase
Peak Power Phase
Gravel Rocks
Is smoothing an option on the app or from your Garmin? I haven't seen that option yet for the Vector 3s, maybe looking in the wrong spot?
Version 7.0
Bikes: Too Many
Liked 2,482 Times
Liked 1,938 Times
@Hermes - that's all very cool. Since you were on the track, we know that power and cadence are directly related, so more cadence is smoother, right? Thus the OP is answered, at least in the case of one rider. That was my conjecture from my experiences with very fast pedaling, but of course no data.
Results matter
Results matter
Version 7.0
Bikes: Too Many
Liked 2,482 Times
As one rides higher on the track, there is an increase in elevation change into the turns that increases progressively the higher one rides such that riding at the top in the turns is very hard. When we did the drills, our coach sets the motor at 26.5 mph but half way up the track. So in the pace line, I rode constant cadence and speed but changes in elevation and increased frictional forces plus surges in the pace line after an exchange causes power fluctuations. For me, there is a 125 watt power difference between the straight and the turns at the same speed and cadence. And there are the attacks and exchanges which require more power.
Our lap times were 21 seconds, so every lap, I would get two power spikes from the turns and many times had to float on the straights. My average cadence was 101 rpm for the interval and constant.
I do not know how to interpret the data other than to say gee whiz that is pretty cool. So I do not know if OP got the answer to his question. Let's see what he thinks.
Quoted: 1975 Post(s)
Liked 232 Times
Left right balance
Left right balance
Version 7.0
Bikes: Too Many
Liked 2,482 Times
interesting to see how biased your L/R balance is, have you ever noticed this in practice and have you every tried to adjust for it? I'm left leg dominant from an old knee injury on my right side. I can ride closer to 50:50 if I really focus on it but it seems harder to produce a given power especially above Z4.
Here is an expanded graph of my first acceleration that was intended to be a breakaway. The goal was to accelerate hard so as not to allow other racers to jump on my wheel. Inspecting the L/R balance, it is 49/51 at 550 watts and 112 rpm at 92.6 gear inches. BTW, the speed on the graph is wrong. It is more like 30 mph. If you look at the other new metrics, I blew the doors off of torque effectiveness and etc.
So high power seems okay but I still am suspicious of the data. I do not have a left right power issue.
Let's say I did. Right before our session, the para olympic guys were on the track. Did you ever see a one leg olympian cycle? He is effing fast. All the O2 in his blood is available to his remaining leg. And we know that it does not take a lot of strength to make a lot of power. Of course steady state and accelerations are two different matters.
Bikes: S-WORKS
Quoted: 16 Post(s)
It can take a long time to pedal smoothly, as in equal force over the whole revolution of the crank. May even take years.
I found several distinct stages of development. Each one seemed to be what I thought was 'smooth'. But later I experience an improvement, which then becomes my new understanding of smooth pedaling. In any case, each leg constantly has equal forces applying throughout the whole revolution of the crank arm, like stirring a large bowl of cream with a wooden spoon. Once the cadence, of equal forces, increases, one finds themselves floating on their saddle (not bouncing).
