Unbelievably tight KMC 10sp quick link!
Came to give my bike the once over before setting out for a ride on Sunday. Brand new KMC X10.93 chain fitted (now called simply X10, the new black/silver type in the hard plastic case) and quick link that came with the chain in the box. Lubed chain, cleaned off excess, checked brakes, gears etc. All good. Came to wipe off chain once again to see if there was any more excess last night and noticed that I couldn't open the quick link. I tried absolutely everything, no joy. I have always been able to remove KMC quick links using only my fingers, even if they've been a little tough sometimes. I flexed the chain, added more lube to the quick link, tried GT85, tried the wire around the link trick, tried the needle nose pliers trick. Nothing! In the end, I had to cut the quick link through with a hacksaw, this way I able to remove the chain from the bike, and then get some pliers to get the left over pieces off the chain. Maybe I should have just left the quick link on the chain, until it had worn a little bit, but I doubt that I would have been able to release it even then.
I've never known anything like it. Has anyone had any hassle with new chains/quicklinks from KMC? I'm quite reluctant to add another.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Buy the tool.
The link is only "unbelievably tight" if the proper tool can't remove it.
I used to mess with needlenose pliers, etc., until I bought the tool two years ago. Wish I had done it two decades ago.
Even with the tool, some links take lots of force.
-Tim-
-Tim-
Likes For TimothyH:
Expired Member
Quoted: 3665 Post(s)
Liked 5,412 Times
Not to mention why did you want to remove a "brand new" chain?
Likes For shelbyfv:
Quoted: 645 Post(s)
Liked 797 Times
Was likely a “single use” link - they lock closed and need a tool to remove. As I understand it, the only difference between these and reusable links is the tiny metal nubs that lock the link closed. File these down and, hey presto, you have a reusable link. My past batch of SRAM 10sp chains had single use links. After they had their single use I replaced them with Connexs. This might be the way things are going, as my previous batch of the same chain model all contained reusable links. Why sell you a reusable link when they can force you to continue buying new single-use links?
Likes For Litespud:
Quoted: 3375 Post(s)
Liked 5,513 Times
KMC has long had 2 types of links: "reusable" (non-latching), and "non-reusable" (latching).
And in my experience, you can find either type in the box with a KMC chain.
Just get the Park MLP-1 and it is trivial to open either kind.
https://www.parktool.com/product/mas...pliers-mlp-1-2
Likes For Shimagnolo:
Non omnino gravis
Likes For DrIsotope:
Quoted: 836 Post(s)
Liked 1,061 Times
Another vote for getting the quick link pliers or if out on the road you can use this trick.
Even a rock will do to knock the link loose.
Likes For Crankycrank:
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Why remove if you don't have to? New chains wear fast, so just leave it and add lube. Clean chain on the bike.
I don't hit my chain plate with rocks. Now I carry this lightweight wolf tool.. a bit pricey, but when you do other peoples bikes more than yours it comes in handy.
https://www.universalcycles.com/shop...s.php?id=93762
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
YEP....the tool is great. I have the tool from Park and one of the best tools I own for home bike maintenance!
Likes For sdmc530:
- Soli Deo Gloria -
Liked 736 Times
-Tim-
Expired Member
Liked 5,412 Times
The Wolf tool looks nice. Valve core removal as well.
Quoted: 1438 Post(s)
Liked 1,092 Times
I consider "single use" to mean "use on a single chain". IIRC the single use thing is a patent workaround.
Likes For dsbrantjr:
Another vote for getting the quick link pliers or if out on the road you can use this trick. https://www.youtube.com/watch?v=85Uednr4zFI Even a rock will do to knock the link loose.
Yep. I've put off buying the tool for far too long.
Likes For migrantwing:
Quoted: 152 Post(s)
Liked 173 Times
On my old 8 & 9 spd. bikes I was always able to remove the quick links by hand too. But, with 10 & 11 spd. drivetrains things changed as the links are now very tight. Like everybody says, by the tool. It will save you a lot of grief. Luckily, they aren't very expensive.
Park Master Link Pliers
I once had a KMC link that wouldn't close. I tried everything. Got so peed-off, I emailed KMC. They asked me to send them the link. I did and they sent a new one back to me.
Most quick links are single use, just like the Shimano joining pin. If you want to remove the chain with your hands get a whipperman chain link or get chain link pliers as suggested by others.
Likes For Racing Dan:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Same here. I use one set of quick links on the same chain. when chain wears out I throw out the quick links too. I remove my chain numerous times during its life using the same quick links and have never had an issue with KMC or Shimano.
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
I had no other links around and had to scramble for one. I emailed KMC and asked for a new chain for my hassle, They wanted me to fill out a form and send in the chain. I did not.
In both your case and mine, KMC could have made lifelong friends by saying "Jeez, we're sorry, that shouldn't have happened! We're sending you a new whatever for your trouble. So sorry!"
But no, you have to return the link, so KMC can be sure you're not scamming them to get a free $5 item that costs them pennies to manufacture. What a great company (not).
To the OP, I agree with other posters who recommend a tool for the job, but I too did it for many years without one and could always get the link off. Maybe you too got a bum link from KMC.
Likes For BCDrums:
