Specialized Enduro 29er chainstay
Quoted: 33 Post(s)
I bought a second hand Spesh, but under the chainstay protector is a large crack. Where can I get a replacement aluminium chainstay? Thanks. Its a 2015 Specialized Enduro Comp
Quoted: 4208 Post(s)
Liked 3,874 Times
From Specialized via one of their dealers? Good luck. Andy
AndrewRStewart
AndrewRStewart
It's an Antique now. Best bet look for a used one. Or get your money back?
Liked 3,874 Times
Just the same if the frame is not repairable then perhaps approach the Specialized dealer about a crash replacement deal. Of course the second hand status likely makes this option moot. Andy
AndrewRStewart
AndrewRStewart
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
I had thought this bike had rear suspension, thus a bolt on potential stay replacement.
Quoted: 33 Post(s)
Update, I have just found a donor frame which is a different size to mine (shouldn't matter) but the seller states that there is a bad rub mark on the chainstay. Does it look large enough to affect its strength? The seller states that "the rub mark just breaks the metal surface, don't think it would effect strength but would always reccomend having a welder run a small bead of ali over the top to be safe"
Quoted: 33 Post(s)
Quoted: 33 Post(s)
I'm a bit worried about the front triangle of my frame now, considering how badly cracked the rear triangle was. The seller claimed that it was squeezed in a tight spot during transport. How can I properly check the front triangle for cracks?
Quoted: 2026 Post(s)
Liked 1,096 Times
I think you are throwing good money after bad. If the chainstay is cracked and the rest of the frame questionable, I recommend getting an entirely different bike.
Quoted: 33 Post(s)
Liked 3,874 Times
That "rub mark" on the possible second frame looks to be into the tube wall. Knowing it's compromised why buy it. The first frame should have taught you that, had you known of it's crack you likely wouldn't have bought it to begin with.
It's uncommon for a frame to have cracks in more then one location, but not impossible. Without metallurgical scanning devices the most lay people can usually do is a VERY THOROUGH look over. Andy
AndrewRStewart
AndrewRStewart
If it's been ridden enough to crack a chainstay look forward to likely necessary pivot and suspension service. These are very frequently neglected by most MTB riders.
Quoted: 33 Post(s)
I haven't worked at a Spec dealer, but most manufacturers keep rear triangle parts for FS bikes around for a few years. Seriously, have you contacted a dealer? Specialized dealers aren't exactly few and far between. Rear end parts seem to break more often than main triangles. If the front looks OK, I wouldn't worry about it too much.
