Ultra Comfortable - Performance Saddle for Long Fitness Rides
Bikes: Ridley X-Fire, Trek Domane, Ibis Ripley, Cannondale CAADX, Ibis Hakka, KickrBike
Quoted: 7 Post(s)
I'm looking for an incredibly comfortable saddle for performance long distance fitness training. Whats a saddle that won't slow me down after 30-50 mi riding? I plan to ride using traditional padded bike shorts. Thanks
everyone will tell you it depends, no one saddle can be comfortable for everyone.
riding position and bike fit will make a big impact.
Likes For plowmanjoe:
Quoted: 871 Post(s)
Liked 726 Times
There's too much variation in physique to give a general saddle recommendation. Your best bet is to buy from a store that allows free exchanges and has a decent range of shapes. Getting a bike fit can also help give you a good starting point, besides also making the entire bike more comfortable for you.
Also, spend as much as you can on the best shorts (aside: I'm bibs >> shorts) with the best chamois, because there is a noticeable improvement in materials to reduce chafing and multi-density foam to distribute weight without causing numbness with more expensive options. Doesn't mean cheaper options won't work for you, just that there's a better chance that the high-end ones will.
Likes For surak:
I have converted to ISM noseless saddles with zero regrets. PR 2.0 on my paved road bike, PR 3.0 on my rigid 29plus bike, which is for gravel roads and the occasional singletrack.
I don't use padded bike shorts anymore, as they are not needed. Compression boxers under some lightweight fishing/hiking shorts. My regular rides are in the low to high 40s (miles) and I frequently ride 55 or more on a good day.
Likes For DeadGrandpa:
Quoted: 139 Post(s)
Liked 136 Times
As for riding shorts, this item can make just as much of an improvement as the saddle itself. Good shorts with a well-made, durable chamois are well worth the $$$. I use the Assos H.mille_s7 shorts and absolutely love them. Wait for a clearance sale if possible (for whatever brand you ultimately purchase), as I'm sure you're already aware of how expensive good cycling shorts can be. I picked up the Assos H.mille_s7 shorts about a year ago for $58 per pair. Good luck! I wish you the best in your quest for comfort.
Quoted: 6177 Post(s)
Liked 4,794 Times
Doing long rides often will go further for making you comfortable with your saddle. Making an occasional long ride will leave you looking for that magical saddle.
Quoted: 4791 Post(s)
Liked 3,918 Times
As well as the saddle itself, the exact placement of the seat (height, fore and aft location and tilt (especially!) is very important. A big aid to getting those last two right is the 2-bolt seatpost. These have front and rear bolts in the clamp. Ride with the wrenches for your post and seat pin (and some tape so you can mark your settings before making changes). One can loosen the rear bolt, tweak the front (say 1/4 turn) then re-tighten the rear, Stop as needed to tweak the settings. See if you like it. If not you can go exactly back to where you started, half way, half again, etc. And you can do this out on the road with no fear of losing your basic reference. Nitto and Thompson make excellent 2-bolt posts.
I ride the Terry Fly. It is nearly the Selle Italia I raced and rode into my 40s until my body changed and the seat turned to torture. The Fly's cut out makes (for me) a huge difference and I get to ride the shape I love. BUt dialing them in is critical. (I am not promoting those seats. You have to find what works for you. I know a lot of people who love the leather Brooks. For me, those seats are torture or I have to give up riding my favorite positions.
Ben
Ben
Likes For 79pmooney:
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
One really has to test a saddle to see if it's going to work. The test really starts at 3 hours saddle time. That's a dividing line between sorts works and 12 hours would be OK. My best find so far in 25 years of trying is: Selle Italia SLR Boost Endurance Superflow Saddle Black Size L3. Yeah, really expensive, but it works for me and I think would work for a wide variety of butts. The Selle Italia MAN saddle is also very popular, less expensive, and works for a lot of people. I used Terry saddles many years ago, but found that the foam broke down quickly, Maybe they're better now.
I assume the OP is male. Yes, IME padded shorts are the right thing, ALTHOUGH it's a very good idea to test possible saddles in nylon gym shorts. Padded shorts can hide flaws in fit that won't become obvious for too many hours, whereas one feels every little thing in thin nylon.
Results matter
Results matter
Quoted: 94 Post(s)
Liked 151 Times
+1 because bicycle shops have been unable to get saddles since April due to COVID-19 it is unlikely you will find a good selection anywhere. As for the easy exchange programs that some shops had in the past it is unlikely bicycle shops will be able to do this because there is no inventory of saddles to sell. Hopefully the supply side will improve going into 2021 and saddles, tires, tubes and other basic bicycle parts will become available again.
