Stem advice for LHT?
Bikes: 1978 Motobecane Le Champion Fixed Conversion, 2009 Surly Long Haul Trucker
I just got a new 56 LHT and my reach is a little long but my standover is just right. It has a 100 mm 17 degree rise stem. Is a step down to a 90mm short enough to notice a difference, OR should I go to an 80mm or 75mm. I just feel a little stretched right now and i dont want the stem to be higher because I like the position.
GO BIG RED
Bikes: 1996 Bianchi Veloce 1993 Bridgestone MB-3 1992 Trek 700 1992 Trek 820
FWIW The shorter you go in stem length on a 17 degree rise stem, the lower your bars will be. Unless you have available steer tube above the stem to move it up. I personally can't tell a huge difference within 10mm but I know some riders can.
My steerer tube is cut EXACTLY to the height I want it at with all spacers beneath the stem. I was thinking what if I went with a shorter stem with a 35 degree rise instead. I work in a shop so I'm going to try a few out tomorrow.
stem
Please post your results. I have a similar situation, different bike.
I'm using a 100mm, 5deg rise stem. I'm thinking of going to 90mm, 15 deg rise but I'm not sure if I'd notice a difference or not. I also bought a really cheap 80mm, 5 deg rise stem that I'm going to try for fit.
hello
You're lucky you work in a shop so you can experiment.
My experiments over the years have resulted in a parts box full of old and new stems, mostly cheap generics to determine size, before buying the "good" stem.
Likes For roadfix:
ok, SO FAR! I've tried a 90mm with adjustable rise and it wasn't that different. I couldn't notice much at all even though I set the rise super high to like 35 degrees.
Thomsons are high quality but that won't change my reach problem. One thing I have noticed is that when it gets colder out I am far less comfortable than I am during warm weather in my wrists and back. I'll let it warm up and see. MAYBE I need a winter and a summer stem.
Liked 5 Times
Pat: Try the shorter stems, try something high a higher rise to it, and if you haven't already, slide your saddle forward a bit. that helps, too.
-rob
-rob
Likes For Re-Cycle:
I understand the OP is from 11 years ago but I'm in a similar situation. 54cm LHT and looking for a shorter stem. Any suggestions? I think I'd like to try a 90mm x 17deg first (down from the stock 100mm by 17deg). I guess another option is a 70mm by 35deg.
Sunshine
Quoted: 10955 Post(s)
Liked 7,485 Times
If you dont know what to get, go to your local shop and ask to try a few stems on the bike, then buy one from them.
If you know what to get, either go to your local shop and buy it or order online.
A Kalloy 7 off ebay is one of the lightest stems around and also one of the cheapest name brand stems, but the 7 comes in 7 degree. Kalloy Uno comes in 17deg for sure. Or buy a $12 off Amazon- they come under different names and are all the same(i have received a Kalloy when the pic showed some generic name). The good thing about Amazon is you can buy 3 and most of the stems seem to be free return, so pack up the unused 2 and return em for free. I have 'Qikour' stems on 5 family bikes- 2 kids road bikes, 2 kids mtbs, and my wife's mtb. They are perfectly fine and one of them was delivered as Kalloy so its the same thing.
Stem Comparison Tool | yojimg.net use this to compare your current stem to potential new stems. You can then both read and see what the actual difference will be in height and reach.
Likes For mstateglfr:
I appreciate the reply - thank you! I'll have a look at that stem comparing website and see what I can find online.
I didn't know it was possible to bring your bike into a LBS and try on different stems? I might call a few shops to get some idea of what they have in stock, they are also all an hour drive from me.
One bit of advice for this guy is to eyeball stems at your shop, while not perfect it will give you a reasonable idea.
Also, take some measurements, distance from saddle or something, and height from floor, whatever works, just to have comparisons in numbers before and after.
and yes, I find in summer we tend to get more flexible and this and that, and slight changes are noticed.
Really not a lot of 26mm bar clamp diameter stems out there online.. At least in less than 100mm length.
Found one 65mm with 9deg, and another 70mm with 17deg.
Sunshine
Liked 7,485 Times
https://velo-orange.com/collections/...nt=53102317895 They have 17 degree stems in a lot of lengths.
You can also shim your 25.4/26.0 mm bar to a 31.8mm stem with suitable adapter. You can get them in silver or black finish:
https://www.amazon.com/Wheels-Manufa.../dp/B000AO5FME
I find these tools indispensable in making stem / posture change decisions:
Stack and reach calculator <-- more work but great for comparing different geometry bikes, provided you have adequate manufacturer's geometry specification to plug into calculation
I have used these inexpensive Dimension (QBP) stems, they are offered in a wide variety of sizes, black or silver, at relatively low cost. Better quality than you would expect for the price:
https://www.dimensionbikeproducts.com/products/stems
Likes For seeker333:
dont know about you folks, but inexpensive stems have for me, always been fine. I cant see how the very small weight difference would be worth spending 100 bucks on a stem (or more) when a 20 25 dollar one works fine for me.
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Go as short as you think you need to. Don't hesitate to try shorter than 80mm if need be. If the stem you are trying doesn't have a rise, you'll need to compensate further.
I like the 0-60 degree adjustable stems because you can raise it up to 60 degree tilt if you want the bars a bit higher without using spacers
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Because I want my stem to also be attractive not just what works.
Sunshine
Liked 7,485 Times
Drip, Drip.
Liked 193 Times
Aesthetics is totally useless when you have functionality and performance to consider first.
A cheap stem might seem "fine", but once you try a better quality stem (doesn't need to be hundreds of dollars) you'll be amazed how a stem which otherwise looks the same dimension wise can totally change the handling of your bike.
