Problem with clip-in road pedals, looking for advice
Hi,
I did my first ride with road clip-in (look) pedals today, and I should say that it was helping especially when I was going uphill. But, I did not really felt safe. Although I loosened the locks as mush as possible, I was feeling that it would be hard to free my feet at the case of an accident, especially that I mostly ride in roads with heavy trafics.
So, at first place, I am looking for any helping advices and hints to better and safer use of clipless pedals.
Also, I am thinking about to use my flat pedals again, but am not sure if I could use them with my new road choses which are clip-in compatible.
Many thanks for sharing your experiences.
Expired Member
Quoted: 3654 Post(s)
Liked 5,392 Times
Plan ahead, practice and persevere.
Likes For shelbyfv:
Quoted: 5223 Post(s)
Liked 3,579 Times
I unclip as I approach stops & dangle that loose foot, so when I have to stop I'm ready. just have to remember which foot is out! :-)
Likes For rumrunn6:
The best advice I can offer is to practice in a safe place like an empty parking lot or a grassy area. Just ride, unclip, reclip, unclip, etc.. Once you're on the road, think ahead. I think it's obvious that it's better to unclip too early than too late. You'll likely fall once or twice but after a while, it becomes second nature.
Likes For MAK:
Quoted: 626 Post(s)
Liked 701 Times
Practice is the key. Early on, you might want to keep one foot out until you really get the hang of it.
For me, I did not use clipless pedals until I went recumbent, so I was learning several new things at the same time (riding a SWB recumbent can be a bit...challenging). Only one of the falls I had early on was due to not get unclipped quickly enough. I fell over ~6 times in the first 10 miles riding the bent, then every thing sorta clicked in my brain and just started working.
Here's the somewhat counter-intuitive part: Leave the foot you generally don't put down as the unclipped one. Then practice unclipping the foot you will generally put down. The other will be free in a pinch, but you get to practice more with the way you'll eventually ride.
Likes For Notso_fastLane:
Bikes: Norco search xr
Quoted: 198 Post(s)
Liked 146 Times
Don't worry. When you crash with the bike still attached then you can unclip after, realize you are unhurt, then look around embarrassed to see if anyone saw. If no one saw its all good.
Likes For Gconan:
Quoted: 10234 Post(s)
Liked 5,179 Times
the first time I clipped in, I rode about 15 miles without having to stop. I saw an old friend of mine and decided to say hello, came to a stop and in slow motion I fell over. Embarrassing but hopefully I’ll never do that again.
Likes For bampilot06:
52psi
Quoted: 790 Post(s)
Liked 801 Times
On my commute bike I still use flat pedals. Clipless just don't make sense to me in an environment where I'm constantly on and off the pedals. Beyond that, just know that you'll gain confidence with continued use; the fear of not being able to clip out in this or that situation will eventually disappear.
Likes For Fahrenheit531:
Registered User
Quoted: 188 Post(s)
Liked 276 Times
Practice the good old track stand. I never thought it was a benefit and just plain old showing off till I started using it.
I never have to unclip at stop signs and can usually stay up for nearly a minute at red lights till the light turns green. A little thinking ahead at stop LIGHTS makes it more effective. If the light is long like 3 minutes, then yes I unclip.
BTW, practicing the track stand may help you learn to unclip quicker as well.
Likes For TheDudeIsHere:
WGB
Bikes: Panasonic PT-4500
Quoted: 1794 Post(s)
Liked 2,328 Times
Start out with running shoe on one foot and get used to having the other locked in. After a ride switch and lock in other foot. Third ride all should be good.
Likes For WGB:
Quoted: 800 Post(s)
Liked 218 Times
Problem with clip-in road pedals, looking for advices
Just today, including a few minutes ago I posted to this thread,”SPD Pedals for Commuting”:
and
Otherwise, I learned by trial and error, though on this thread are a few suggested techniques I think are good.
Hi,
Also, I am thinking about to use my flat pedals again, but am not sure if I could use them with my new road choses [?shoes] which are clip-in compatible.
”Do you disregard traffic laws during your commute?”
...Almost all Stop signs I come to a complete stop at, because, where I ride, these are places motorists routinely blow through....
I don't like clipping out and in 5000 times on a two-hour ride. It seems unnecessary. But I do it. Am now very proficient at clipping in. It is a ton of starting and stopping in town. But it is required most of the time.
Indeed it is a pain to clip / unclip/ clip / unclip…
When I occasionally do a multimodal commute, bike ~ 2 miles to train in the city, train to an outlying suburban station, then cycle ~ 5 miles to work , I wear regular running shoes for the urban segment though the downtown, and bring my cycling shoes for the suburban segment.
Otherwise the full cycle commute of about 14 miles through MUP, residential, and early morning light commercial routes does not require many, sometime no stops.
BTW, I previously posted:
After a few early falls when learning to ride with clipless pedals, I now unclip the right foot when there is the least anticipation of stopping.
"Clipless pedals or not"'
On further reading, I noted the right vs left unclipping discussion. We have plenty of curbs and I unclip right. In fact, when I'm on the left side of the road, left foot unclipping seems awkward.
I first to thought about it when I started riding with a regular companion, and he always unclipped left.
...I’m not particularly conversant with all the pedal types discussed, but mine clip only on one side. Clipping in and out are easy with one foot only.
Sometimes though on an incline upwards, from a stop with both feet free and unclipped, it can be a problem to get enough forward momentum to rotate the pedal and clip in, and the cleat is slippery on the wrong side of the pedal. On a couple of occasions I banged my shin on the pedal.
I tried riding with cleat covers for traction on such short distances, but I’ve lost two separate cleat covers doing that, and I prefer the “old soft shoe” routine.
With a mighty wind
Quoted: 1086 Post(s)
Liked 858 Times
If you're worried about it, ride around on and empty grassy field for a while. You'll get the hang of it.
The only place I don't use clipless is on my way to work. It's 2.5 miles, not even worth the shoe change.
Quoted: 451 Post(s)
Liked 364 Times
For me, I did use clipless pedals until I went recumbent, so I was learning several new things at the same time (riding a SWB recumbent can be a bit...challenging). Only one of the falls I had early on was due to not get unclipped quickly enough. I fell over ~6 times in the first 10 miles riding the bent, then every thing sorta clicked in my brain and just started working.
When I was getting started, I found a wall where I could see the TV and still be stable. I would watch a game or the news or whatever and just sit there clipping and unclipping a zillion times. Eventually, like almost all skills, you won't have to think about it and it will just happen. But don't think you are going to get this down in 3 days. You aren't. Just keep after it. Put in the time. And you will be rewarded.
Personally, I just don't enjoy riding without being clipped in now, even in town. I feel naked riding any other way. Who woulda though this guy that could barely clip in now won't ride without his Sidi's on?
Likes For bpcyclist:
Macro Geek
I used clips for about 15 years. There were only two or three times I couldn't unclip in time, which resulted in falls, never with serious injury. (Bike gloves prevented scrapes on my hands.) Most of those falls happened during my first two or three seasons.
After a few close calls, I began to weigh the pros and cons of being clipped in:
Pros:
1. It feels good to be connected to the bike while pedaling.
2. There may be mechanical advantages.
Cons:
1. It feels safer to not have my feet "welded" to the pedals.
2. It's a nuisance to switch between bike shoes and regular shoes.
About two years ago, I decided to trade in my SPD pedals for flat pedals. I don't regret my decision.
I don't shy away from hills. I have climbed many hills, both before and after the change-over. I don't miss being clipped in, and don't really notice benefits of SPD. I still manage to get up hills.
Pros:
Cons:
Quoted: 3241 Post(s)
Liked 2,512 Times
If you have a trainer, use them on it. Or borrow a trainer. If you have access to a gym with a stationary bike, use that. Or find an area with soft ground and practice.
Likes For seypat:
For my, I did use clipless pedals until I went recumbent, so I was learning several new things at the same time (riding a SWB recumbent can be a bit...challenging). Only one of the falls I had early on was due to not get unclipped quickly enough. I fell over ~6 times in the first 10 miles riding the bent, then every thing sorta clicked in my brain and just started working.
I think I need to practice much more to get used to it.
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
They are slipperier than dog snot! Does Shimano make a road pedal with clips on both sides. I know some mountain pedals have them, but do any road pedals have them?
Thanks.
Glenn
Thanks.
Glenn
Quoted: 800 Post(s)
Liked 218 Times
Thank you for your message. Actually, I tried to keep my right foot unclipped, but when it is unclipped, it was not easy to pedal. The shoes are so slippery on the pedals when not clipped-in.
"SPD Pedals for Commuting"
I've tried several styles of pedals:
The single sided SPD pedals (A600) seemed about the best road-style SPD pedals out there. And I used them for years on my road bike. I don't prefer them for commuting. But for road cycling they're pretty easy to get into. ...but SPD-SL are more comfortable on long rides.
The SPD-SL pedals have won me over for road cycling. On long rides they do a better job at avoiding hot spots. They're pretty easy to get into. Sometimes they find the wrong-side up, but I'm pretty used to them now…
- SPD-A530 - Large but slippery platform on one side, clips on the other. Just ok.
- SPD-M324 - Smaller but thicker and still slipery platform on one side, clips on the other. Even worse…
I use these on my "commuter" bike, plus the metal caged one on my MTB. I use the single sided 234s (?) on my touring bike. I always ride in cleated shoes, however.
My thoughts exactly, SPD-SL for any performance-type road bike. I really like them…
As to the "butter on the wrong side", one only has to rotate the crank 180 degrees and meet that pedal in the new spot, and the cleat will be up. Easy.
Earlier on this thread I posted:
I tried riding with cleat covers for traction on such short distances, but I’ve lost two separate cleat covers doing that…
When I'm on an incline upwards my usual solution to proceed from a stopped completely unclipped position is to turn around and descend to engage the clips, then do a U-turn upwards, usually at the flat road surface before the hill.
BTWFYA, on the 50+ Cycling Forum is an honorary society for those learning clipless pedals, Club Tombay (link).
Registered User
Quoted: 188 Post(s)
Liked 276 Times
Also, I am not sure and not wanting to read through every post, but I think somebody brought up mountain bike pedals and mountain bike shoes. Many look like road shoes and many would not even know one was wearing them with the nifty styles that are out.
But the pedals are 2 sides so easy to engage after a stop. Better walking since the cleat of the shoe is recessed as well.
I've been using them for 23 straight years and love them. I tried LOOK pedals. Hated them, gave the pedals and cleats away. I like the spd system much better!
Old fart
Quoted: 3582 Post(s)
Liked 3,395 Times
Shimano's road pedals all seem to be single-sided. Speedplay and Crank Brothers "Eggbeater" road pedals allow clipping in from any side. If you really need to have a Shimano pedal, there's no reason why you couldn't use their off-road pedals on a road bike.
