Replacing rear derailleur
Old 09-23-18, 12:36 PM
cjones109
I need to replace a Shimano Deore XT M759 9 speed. Unable to find that model online or in storess. Need help finding alternative.
cjones109 is offline
Old 09-23-18, 01:17 PM
noobinsf
noobinsf's Avatar
Quoted: 606 Post(s)
Liked 330 Times in 231 Posts
Take a look at Microshift 9-speed mountain derailleurs. Inexpensive and good quality, and can be found from many sources on eBay. They are compatible with Shimano pull ratios for indexing.
noobinsf is offline
Old 09-23-18, 01:44 PM
woodcraft
woodcraft's Avatar
Quoted: 1465 Post(s)
Liked 508 Times in 299 Posts
Is that a 'rapid rise' model?
I have #760 one that you can have- I hate that dyslexic POS.
Any 9 speed mtn bike RD should work fine- long or med cage to match what you have.
woodcraft is offline
Old 09-23-18, 02:41 PM
nfmisso
Nigel
nfmisso's Avatar
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 383 Post(s)
I like this one: https://www.amazon.com/MicroShift-Ma.../dp/B00FSRUOUQ
nfmisso is offline
Old 09-23-18, 10:43 PM
Eggman84
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 199 Post(s)
Liked 25 Times in 22 Posts
You can replace it with a new Shimano 9 speed MTB derailleur. Shimano changed the cable pull when they went designed the 10 speed MTB derailleurs (labeled as Dyna-Sys) so only a 9 speed (or earlier) will work with the shifters you are probably using (I assume indexed) . You can use either the
Shimano RD-M771 XT 9 speed Rear Derailleur - which has what I think of as a classic look
OR
Shimano RD-M772 XT 9 Speed Rear Derailleur - which has the "Shadow" lower profile body with direct cable routing
They are about $60 to $70 new. Both have the traditional "top normal" return spring (i.e., the derailleur moves to a smaller cog when you loosen the cable tension). Make sure you get the correct length (GS medium cage or SGS long cage). If in doubt go with SGS.
Eggman84 is offline
Old 09-23-18, 11:40 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1078 Post(s)
Liked 271 Times in 213 Posts
Even a 9 speed Acera or Alivio RDER will do the job fine.
Bill Kapaun is offline
yellowlebron
Bicycle Mechanics
5
01-31-14 10:40 AM
Intial35
Bicycle Mechanics
4
01-23-14 02:15 AM
sniderfunt
Bicycle Mechanics
7
08-04-12 03:30 AM
db339
Bicycle Mechanics
5
11-23-11 07:51 AM
urbanknight
Bicycle Mechanics
12
12-31-09 08:49 PM
