Swapping out the small cog 11sp cassette
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
Forgive me if this is dumb question, but I had this thought about my 11sp Shimano cassette. I'm running a 12-28 cassette, and I'm happy with the 16T in lieu of the 11T in an 11-28 cassette, as I use it far more than I would an 11T. However, I wonder if it's possible to have the best of both cassettes, and swap out the end cog (12T) on the cassette with an 11T? Right now, it goes 12, 13, 14....so it would go 11, 13, 14 if I swapped. Since it's the end cog, both are properly machined to be the end, so I can't imagine that part of it would be a problem. May have to also go with a lockring suited to an 11T end cog, which I also have. The jump from 11T to 13T doesn't seem like it would be a problem, so are there any other reasons why this would not work?
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 647 Post(s)
Liked 136 Times
I hear you, that's why I like the 16 in the middle. It's one more cog in there with a single tooth jump, which is much more of a smooth transition. I'm way more often in that zone of the cassette than at the small end. The only real use I have for the 12 (or 11) is when I want to go fast on a descent. I don't have the power to push an 11 or 12 at a reasonable cadence on a flat road, so it's more or less there for downhills where I can push it for fun. So, the jump from a 13 to an 11 would not really be disruptive, again because I'm not really ever on those cogs for "normal" riding. But the question is can it be done or is there some mechanical reason why it can't?
Quoted: 1943 Post(s)
Liked 2,164 Times
Sure. No problem swapping out the 11t for a 12t. I’ve swapped out a lot of cogs to get gapping that works for me.
I’m not sure of your 16t question. If you want to swap out a 16t, it all depends on the cassette and whether it is spidered together.
What speed cassette are you using?
Can you get to the 16t?
There is one last concern and that is whether the 16t cog is designed for a 1t tooth change or 2t+ tooth change. It has to do with the number of years ramps.
John
John
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
No problem using 11t instead of 12t..... but you probably will need the lockring that goes with the 11t.... not the 12t lockring.
Likes For trailangel:
Really Old Senior Member
that’s an 18% increase from the 13 to the 11 - that’s a big jump at that end of the cassette. Maybe if you saved it for special occasions, like suddenly finding yourself drafting on a long downhill, but personally I would find a jump that big to be too disruptive for normal riding - it would throw my cadence off completely, with the result that I’d hardly ever use it. I’d rather a 12 that I might (and do) use regularly than an 11 that gets very little use. YMMV, of course
However, how long does it take to swap the 12T back in if it turns out it's really not what the OP desired.
An 11-13 jump is quite common on mountain bike cassettes.
The teeth are shaped for specific combinations so the new combo will shift definitely worse, but it will fit and may or may not feel acceptable.
Likes For cpach:
Quoted: 2026 Post(s)
Liked 1,096 Times
It will fit and work but, as cpac noted, the 11 to 13 shift will probably not be very good. If you are not rushed it will shift adequately but probably not under load. BTW, I'm also a big fan of the 16T cog but it's the first one to disappear when cassettes add an 11T cog or go larger than 27T or 28T.
Likes For HillRider:
Likes For tFUnK:
Quoted: 647 Post(s)
Liked 136 Times
OK, this is the kind of thing I was asking about. I didn't think of this but I get it. Thankfully it would be a shift at the end of the cassette and not used often, but at least now I know that's a possibility.
Quoted: 647 Post(s)
Liked 136 Times
John
John
Liked 2,164 Times
What speed cassette do you have?
John
John
Liked 2,164 Times
To backtrack a bit, if the 14t only has 1 tamp, it will shift slower going from a 12t to 14t than a 13t to 14t. If it has 2 ramps it will shift the same. Been there done that.
John
Quoted: 350 Post(s)
Liked 122 Times
If you look for the exploded EV drawings, you can check to see if part numbers of the cogs match with a different cassette that has 11,13 or 11,12,13 to the part numbers on your cassette. If they do match then there won't be problems with ramps. If not then it's a bit of chance on whether the shifting will be good.
i don't know about the 11 speed, but some Shimano 9 and 10 speed cassettes have the 12t cog designed to be in either first or second position, which means that the 11t can be placed on top of the 12t if desired. I can't remember if the 13t is then having a special built in spacer design with a counterbore recess for the 12t. The exploded drawings with the part numbers will give you a clue.
My 9 and 10 speed cassettes 12-34 are both custom built from 11-30. They have 11,12,13 and I just drop the 11 and put on the locking for 12t. Or else they were 12-30 and I put the 11t on top of the 12t. But that's because the 12t on those specific cassettes were designed to be in either first or second position and probably the 13t is designed to be in either second or third position.
Currently I have 10 speed 12,13,14,15,17,19,21,24,28,34.
If I had 11 speed then I would have either inserted a 16 or 11. The 16 would be nice for getting they 13.3% smaller. 11 would get me higher speed. Otherwise I could change the 24 to a 23 and get 11,12,13,14,15,16,18,20,23,28,34
The only way to get this custom built cassette in 11 speed is with Miche because the Shimano, SRAM, and sunrace have the 5 biggest cogs on spiders.
