Raleigh Sprite
Mid 70s Raleigh Sprite Derailleur Replacement
Hi, All.
I'd like to upgrade the derailleur on a mid-70 Raleigh Sprite. Can someone recommend a derailleur to replace the Huret 5 speed?
thanks
thanks
Really Old Senior Member
Shimano Tourney is probably your best bet. Anything "fancier" will be "more speeds" and a narrower cage.
Thanks, Bill. I appreciate the quick reply. Do you know how to adjust these Huret's? Here's the issue I'm having: When the down tube shifter is all the way up, it's not moving the chain down to the smallest cog on the cassette. When I pull it back it goes way above the largest cog (and slips off). How do I fix that? . Does the cable need to be adjusted? Any help would be much appreciated.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Quoted: 4201 Post(s)
Liked 3,857 Times
The Sprite likely has the Huret Alvet. A wonderful production of blacksmithy level abilities. Every pivot can be taken apart, cleaned, lubed and reassembled with adjustments to the slop/friction balance point. Even the pulleys rebuildable with their cup and cone bearing. Rugged and trustworthy but not quick to service if you're fumble thumbed.
Like any der when looking at the shift to the small cog issues one first confirms that the der, sans chain and cable, moves through it's range freely. If not then likely one or more of the link pivots is binding. They are simple screw and lock nutted set. One limit screw controls the outward travel and the other the inner, just like modern ones although in more viewable locations.
Next up isn shifting ease is cable friction. Since these ders were made when cables and casing were metal on metal contacts and rust/grime collects over the years replacing with modern lined casing and redrawn cables goes a long way to reducing cable friction. BTW if the shift levers are also Huret then the common "shimano" ended cables might not fit. Not too many shops stock compatible cables these days. (we have three types on hand if you're local to Rochester).
Like all ders the alignment WRT the wheel.cog set is needed but less so the modern indexed ones. Today my co worker did this alignment on an old Motobacane with a 10" adjustable wrench. Andy
AndrewRStewart
AndrewRStewart
I can’t post photos or links bc I’m new, but if you google this:
an ebay hit comes up. The photos for that item are identical to the one I have.
Vintage Huret Raleigh rear derailleur L'Eroica
Thanks, Andrew. I checked the link pivots. They seem to be freely moving. The cable is pretty nasty so I'm going to replace that. However, the shifters are Huret so is there a specific cable I should be looking for? Thanks dedhed for the diagram. That's really helpful too.
SE Wis
Liked 3,390 Times
You'll have to look at your existing cable to see what end it has on it at the shifter.Given the vintage it may be the flat disc rather than the round barrel.
https://www.bikeforums.net/classic-v...le-source.html
Here's a link to a good picture of the differences.
https://hollandbikeshop.com/en-gb/bi...-simplex-6446/
OK. I got it all back together and put in a new cable and it's shifting good. Something is weird though. With lever shifters, doesnt the chain move down to the smallest cog on the cassette when you push the lever away from you towards the front? And when you pull it to you, it should go up to the largest, right? Right now mine is doing the exact opposite. How did I manage that? And how to I fix it?
SE Wis
Liked 3,390 Times
Likes For alcjphil:
I think I did a few things wrong so I took the derailleur off and put it on again (the right way) and also realized the shifter was on wrong too. I fixed that and it’s moving the chain as expected. It’s shifting pretty good with one exception. When it’s on the largest cog, it won’t shift down. However, from any other gear, it shifts down great and up to the first cog too. It takes a few tries to get off the largest cog. Any ideas?
Posting for future Sprite questions. I found my derailleur here: Huret Accessoires Cycles Cyclomoteurs Motos - 1976 page 7. It's the Alvitt Safety from 1976.
