Show us your Raleigh Super Course!
#1501
blahblahblah chrome moly
Quoted: 1172 Post(s)
Liked 2,567 Times
@BocaJr, That Nervar crankset is pretty cool. One of the very few steel square-taper cotterless cranks ever made.
Campy made one (late-'60s, early '70s), and that's about it AFAIK (not counting later ultra-cheap or kiddie cranks)
Gnutti before that ('50s I think) made a steel cotterless, but with a tapered spline interface, not square.
An Ashtabula crank is technically cotterless, so maybe I need to say cotterless 3-piece cranks?
Oh yeah Profile BMX cranks and Bullseye were steel too, with weird proprietary attachment systems, not square taper.
Back on-topic -- I did see one of those Super Courses with the steel cotterless Nervar where the swaged-on spider came loose from the right arm in a way that the cranks could turn without the spider and rings turning. Stationary bike! We sold lots of those SCs though and I only saw one that failed, probably a rare problem.
-Mark Bulgier, Seattle
#1502
Liked 2,567 Times
Flickr album with a few more and larger photos here: https://flic.kr/s/aHsma2ofjH
#1503
Liked 2,567 Times
Welcome to BF, @bulgie!
I haven't read this whole thread so apologies if this has been covered but...
Anyone here ever seen a circa 1970 SC Mixte? I know by maybe '74-'75 SC mixte was a thing, but have only seen one of the ~70 vintage.
We had one for a while years ago, sorry I didn't take pictures but it was a real Coffee SC with a Reynolds sticker, and the script Super Course TT decal on the little mixte stay near the HT. I'm thinking 1970 because it had the oval head badge, which I have heard called the "Jubilee" badge. And the parts matched the spec in the '70 catalog.
Laurie didn't really love it, and she has lots of other bikes, so we got rid of it maybe 10 years ago. Got it free, sold it cheap after putting a lot of work into overhauling and tuning.
The 1970 catalog says a "Ladies model" [sic] was available, but they don't show a picture. Lady's or Ladies' frames are usually a step-through design though (very low "top" tube with no additional stays), not a mixte. We sold lots of Record and Gran Prix Lady's bikes and they were all step-through, not Mixte, if I'm remembering it right
#1504
Quoted: 3808 Post(s)
Liked 6,681 Times
#1505
Liked 2,567 Times
Mark, I found '71 or '72 SuperCourse mixte at a dump in Deer Isle, ME, a few years ago. We were vacationing there and didn't have enough room to hall the whole bike home, so I just took the frame and a few bits. My wife already has a Raleigh mixte, so this one went off to a new home via eBay:
I just remembered one more thing about ours, it had a Weinmann brand h-bar stem, interesting design with a steel quill pressed into a cast Al alloy extension. Nice looking stem. I can't prove it was original, but everything seemed of one era, and all with the same patina -- I think the Weinmann stem was OEM.
#1506
Quoted: 1627 Post(s)
Liked 630 Times
Cool old bike with a lot of stuff we don't usually see here.
I think it deserves its own thread with lots of close up pics. I'm still trying to wrap my head around this part...
...especially the two speed arrangement?
Mid-'50s FW (wide range four-speed) alloy-shell rear hub that's been converted to be a 5-speed, with all the original '50s guts except for a couple parts from a later S5. Big sprocket for low gears because I'm old and slow!
The second shifter for the left side of the hub (high-low range) is a Cyclo of Birmingham, '50s vintage I think, on the toptube. I brazed on a second pivot for a pulley on the left, on the '50s pulley clamp under the seat lug.
#1507
Quoted: 7348 Post(s)
Liked 2,462 Times
@bulgie, I love it. So you have an old SA Dynohub™ and an FW hub, with four super low gears. More pictures, please!
My 1971 Super Course also has nothing original except for the headset, and I have to hope it never gives out. Luckily those headsets are well made.
#1508
Quoted: 152 Post(s)
Liked 237 Times
#1509
Liked 2,462 Times
Around which, the hubs or the headset?
#1511
Liked 6,681 Times
Mark Stonich/Bikesmithdesign.com has instructions on converting an FW into a 5-speed hub, starting on p. 7 of this document. I bought the parts needed from Mark and did convert one FW. It was reasonably successful though it was a bit temperamental about staying in gear. That bike got sold off, but I do have the parts to do another conversion at some point.
#1512
Liked 2,567 Times
But here are some basics for people who don't know about olde English 4- and 5-speed hubs.
Starting with a 3-speed for background: they have a sun gear fixed to the axle, with 4 planet gears that mesh with the sun and with an outer toothed ring, that just fits in that big hub "can" with the spoke flanges. Right here an animation might help, but you can probably imagine that within that constraint (the diameter of the ring gear), the designer can choose different combinations of sun and planet sizes -- a smaller sun with bigger planets, or vice-versa. The ratios of those sizes determines whether it is a close-ratio "racing" hub like the Sturmey "AC" (close-ratio), "AM" (medium) or "AW" (wide). The AW was so much more popular than the others that if you see an old SA 3-speed it is about 99.9% likely to be an AW, or the variants like coaster brake, drum brake or dynohub rears that also used the AW ratios.
This set of hub, planets and outer ring is called an epicyclic or planetary gear train. As most often used, they can increase the gear ratio or decrease it, compared to the Normal gear, which is just the front chainring teeth divided by the rear sprocket teeth. With an AW, the ratio is 3/4, so Low is 75% of Normal, and High gets the reciprocal of 3/4 -- it's 4/3 of Normal, or 133%. "Second gear" on a 3-speed is just Normal, no step up or down.
A Sturmey 4- or 5-speed hub still has a single epicyclic gear train, but you get to choose between two different sun/planet sets, so it' like getting to choose between a narrow-range 3-speed and a wide-range 3-speed.
The 5-speed is simpler to comprehend because the two functions are separated out to two different shift levers. Cables go down to both the right and left sides of the hub. A 4-speed does it all with one lever, cable on the Right only, with some clever trickery inside the hub to switch the sun/planets. Downside is you lose the extra-high high gear, so it's a 3-speed with a lower Low added..
On the 5-speed, the right-side lever is a normal SA 3-speed trigger. Other shifter styles are possible but the trigger is most popular by far. It gives you Low, Normal and High gears, on whichever set of sun and planets have been selected by the left lever. I.e. if you leave the left lever alone, the hub is a 3-speed.
The left-side lever selects whether you want a narrow or wide range. It slides the two suns sideways on the axle to change which one is fixed to the axle, and thus is being used. The unused sun just floats on the axle, unbound.
Since normal is still normal whichever sun is used, it is completely unaffected by the left lever position. What the left lever does is choose between your two available High gears and your two available Low gears. You follow? Two Lows and two Highs plus one normal gives you 5.
Now there's another complication in how the suns get slid sideways.
One way has the suns spring-loaded to go to the right, and an indicator chain pulls them to the left when you apply tension on the cable with the left lever. The indicator chain used is just like the familiar one that goes in the Right side on the ubiquitous AW 3-speed.
The other way has the suns spring-loaded to go to the Left, and a pusher rod that pushes them to the right. The pusher rod is actuated by a bell-crank to turn the cable tension into a pushing force. This is just like the old Shimano 3-speeds worked, if you've ever seen one of those -- they used a bell-crank and a pusher rod on the right side. In fact this is a popular "hack" for people converting 4-speed hubs to 5-speed -- the bell-crank conversion is easier, but real SA bell-cranks are rare nowadays, and expensive when they come up on eBay. So some people use a Shimano bell-crank on the left side of their SA 5-speed.
I might be getting too much into the details. I only meant to cover why there are two levers and how that makes for 5 gear ratios. Did I answer everyone's questions?
#1513
Liked 2,567 Times
#1514
Quoted: 741 Post(s)
Liked 818 Times
First of all, I'm on my second Super Course. My '73 has been on here several times. It was my first ever bike build from a found and trashed frame. It was great fun building it, and its a great ride. I was proud to do last year's Eroica CA on it. So when a gold '78 popped up on local CL for $20, I grabbed it. I've been ticking off the build issues as I go along. It came with no shifters, brake levers, derailleurs, crank or wheels. I've got all that worked out - except shifters. I love the Suntour bar ends on the green one, so I planned to install them on the gold one. No go. Turns out the wall thickness of the bars are so thick, I can't get the shifters to go into the bars. I see several bikes of similar vintage as mine here, many with Suntour bar end shifters. I'm thinking these bars are original, as is the Raleigh branded stem. I measure an o.d. of 24mm on these bars with an I.d. of 19.8mm. The Suntours I have are 20.6 mm diameter. Is it worth hogging them out a little, or are there any other bar end shifters that might fit these bars? The bars on the gold bike are much wider than the bars on my '73. You can almost fit the green bike's bars inside the span of the bars on the gold '78. Did they evolve into wider bars with a thicker wall thickness in the mid to late 70's. I'm confused... Anybody?
#1515
Bikes: 1977 Raleigh Record, 1987 Schwinn Prelude, 1971 Raleigh Record, 1988 Schwinn Traveler, 1967 (?) Carlton Super Course, 1959 Huffy Sportsman 3 speed, 1972 Raleigh Super Course, yet another 70-something Raleigh Record
Quoted: 50 Post(s)
Liked 18 Times
I just bought a Super Course frame a week or so ago, ('71 or '72), and I don't know what to do about the brazed-on rear brake cable stop. All the cable adjusters I am familiar with are 6 mm threaded, but this has a 4 mm unthreaded hole. Where do I find a 4 mm threaded cable adjuster, or do I just use a 5 mm to 4 mm step down cable end ferule?
#1516
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
#1517
Quoted: 50 Post(s)
Liked 18 Times
Thanks. I've got a ferrule that fits. That may be what I'll use. I don't understand why there's no threads in the hole, anyway.
#1518
Quoted: 323 Post(s)
Liked 690 Times
Likes For Pcampeau:
#1519
Quoted: 50 Post(s)
Liked 18 Times
Really nice. Is that the first year for the Raleigh Super Course?
#1520
Quoted: 323 Post(s)
Liked 690 Times
68 is the first appearance in the catalog, yes. But the serial number on mine seems to date it to late 67.
#1521
#1522
Quoted: 50 Post(s)
Liked 18 Times
Thanks. Another possibility.
#1523
70's Red Raleigh Super Course
I was admiring so many great SC bikes on this forum, and have come to the conclusion that
it's time to find a new home for my 1970's red Raleigh Super Course.
I haven't ridden in over 15 years and this beauty needs some TLC, overhaul, new tires, etc.
What great memories of rides around my home town of Rochester, NY
[I'm in the Boston area now, and like it or not, this bike is just taking up room in my kitchen]
If you know of someone who has a passion for these classic bikes, please let'em know.]
#1524
Quoted: 4510 Post(s)
Liked 6,377 Times
#1525
Liked 2,462 Times
