organic cleaning solvents for maintenance and disposal
commu*ist spy
I'd just like to get a quick overview of what people use for cleaning their bikes. I've realized at this point that detergents and/or soap water don't work nearly as well as organic solvents such as paint thinner or gasoline. So I'm wondering what people use, why, and how they dispose of the garbage.
thanks
thanks
Quoted: 5787 Post(s)
Liked 2,580 Times
I use petroleum solvents exclusively for this job, but there's no disposal issue, because I save and reuse the solvents. I have three storage jars; 1st wash which is fairly dirty, rinse, which is pretty clean, then final rinse which is just like new. The particle dirt settles over time, so I can always decant fresh solvent for use, then return it to the jars.
As the solvents get dirtier, I move them down toward the dirty end, and replenish the final rinse jar with new solvent.
So far, over 50 years, I've never had to dispose of any solvent because attrition and evaporation do that for me, though I have had to dump some solid crud from time to time. I pour off the solvent, dump the crud onto newspaper, let it dry and dispose with the household trash.
FB
Chain-L site
FB
Chain-L site
commu*ist spy
I've used simple green. but it doesn't seem to work on the crummy parts on the inner crevices of the chain unless you drown it in a bath or something, which I think would be more cost effective with solvents than detergent.
Quoted: 1438 Post(s)
Liked 1,092 Times
Please do not ever use gasoline for anything other than motor fuel. It is highly flammable, its vapors are explosive and will travel a long way to an ignition source. In addition it is toxic to breathe and by skin absorption. There are safer alternatives available.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
I dump it in my drain oil that goes to the dump for recycling
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
+ ...50/50
Bikes: 1993 Bridgestone RB-1, Bianchi M.U.S.S, 1992 GT Bravado
Quoted: 5 Post(s)
I like to use lemon juice for all of my stationary parts on my bike (levers, frame, seat post) and usually get everything else with either just water or sometimes water with just a hint of household cleaner (simple green, etc.). The lemon juice does a good job if you get any rust on your bike as well!
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
thanks
thanks
Odorless mineral spirits. I recycle and use it again. After cleaning the chain I pour it into a small jar. When the crud settles to the bottom, I transfer the clean OMS to a taller jar, and use the taller jar for the chain cleaning next time.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
My chain is the only part I clean with mineral spirits, and like Francis, I've never had to "dispose" of it -- you just store it in jars after using and let the crud settle out until you need to use it again. Everything else gets rubbing alcohol, water-based degreaser, soap and water, or whatever else is convenient. I don't put a high priority on having a shiny spotless bike.
I would imagine, however, that in NYC you are a net 0.0000001% of the total hydrocarbon emission problem. I wouldn't lose any sleep over it.
Liked 2,568 Times
Well you have disposed of the solvent, you've just done it by emission to atmosphere. Not the most environmentally friendly way of do so.
Liked 2,580 Times
I don't lose any sleep over it, since I'm still working with most of the 1 gallon I bought over 20 years ago. OTOH- folks who try to be environmentally friendly might wonder where their multiple gallons of dirty detergent/water mix goes.
FB
Chain-L site
FB
Chain-L site
Quoted: 29 Post(s)
Orange oil works well for me, smells good, isn't really toxic (can make skin light-sensitive for some people).
You have to make sure to buy pure citrus oils. Lots of stuff that claims to have orange oil either has only enough for the scent, the rest water, or the rest the regular organic solvents. I buy De-solv-it.
I've seen some stuff advertised as safe, Pedro's?, but never used it.
