take out a spacer or longer stem
I have just recently started riding again after a 6 month layoff. I am finding myself more comfortable in the drops then on the hoods. I feel like I am pushing back when I am on the hoods but still feel a little cramped in the drops. Not sure if I should go with a long stem or take out a spacer. Any advice helps. Thank you in advance
Quoted: 663 Post(s)
Liked 496 Times
My guess, judging from my own going back and forth with the same question, is to try moving the seat back a cm or so. It the hoods then continue to feel better, drop a spacer.
It is hard to recommend that you move the saddle anywhere without seeing you on the bike. I would recommend dropping a spacer or two like berner said only because it has a 1/3 chance of helping you and a 100% chance of not costing you any money. The other 2/3 chance would be either moving the saddle in some way (either fore/aft, up/down, or even the tilt can cause this problem if its tiled too far down) or lengthening the stem.
Nick Zema
Bought A Bike Online? I Come To You Build & Fit It. Road Mountain Tri
Nick Zema
See if this gives you and idea. PS my wife took these pics so they are not exactly lined up or on level with me.
just another gosling
Quoted: 3873 Post(s)
Liked 1,920 Times
You look good. For reach, I like to see a 90° angle between the upper arm and torso. Your angle is a little less than that, so I think you could go with a longer stem. You notice how your angle doesn't change between hoods and drops. That's good.
Results matter
Results matter
NYC
Quoted: 1169 Post(s)
Liked 107 Times
your elbows are locked which tells me you should not go for more reach, if anything 1cm shorter stem, but probably. not necesary as your fit is good if you work on body position.
remove the spacers.
practice bending the elbows all the time, lowering your torso, and supporting most of your weight with your core.
remove the spacers.
Liked 1,920 Times
remove the spacers.
remove the spacers.
Results matter
Results matter
