Does anyone actually know how to remove the freehub from a Vision Team 30 rear wheel?
Quoted: 24 Post(s)
I think mine needs servicing, and I've been trying to get it off for a few weeks, and I cannot work out how to do it, and I think I may have damaged the axle trying. There is basically no information out there about how to do it,. The only stuff I can find seems to relate to a different, earlier, design. I've had to resort to booking an appointment at Halfords to get it fixed, since the only independent bike shop nearby doesn't actually fix wheels themselves (despite their website trumpeting about how great they are and about how many spares they have access to). The only thing I've managed to do is remove the bolt from the non-drive side, but that wasn't much help.
Quoted: 18376 Post(s)
Liked 4,511 Times
I don't think I have one of those hubs. But, how much have you done?
Have you removed the axle?
It looks to me as if it is probably a typical sealed bearing rear hub. Remove the endcaps on the axle using an Allen Wrench (or two). Then the whole thing should just slide apart.
Quoted: 24 Post(s)
As I say, all I've manged to do is get the non-drive side cap off, and that didn't do anything. I can't get the drive side one off.
Edit; It's doing that that I've damaged the axel. I've stripped the flats in the hole in end trying to use an allen key on it.
Quoted: 24 Post(s)
Apparently they changed the design from the 2017 model (I bought mine in 2016 so I'm guessing that is what I have). The previous version used a sealed unit freehub, that doesn't look like it can be serviced. Where as the one I have (from what I've gathered) has a more standard style of freehub where the pawls are exposed. At least that's what it looks like from what I've seen, because, of course, I haven't been able to get mine apart
Liked 4,511 Times
On some axles, one one endcap easily comes off. Others have a second set of flats for the allen wrench to engage in the middle of the axle.
Stripping or bending stuff is never good.
Have you tried gently driving the axle out... gently...
Hmmm... here are some instructions for a similar hub.
https://www.tehava.com/Perfion/File....5-0f3c36cae1a7
I don't think I've encountered left hand threads on a hub. They really don't make a lot of sense...
But, could that be a reason why you've been having issues?
1.Unscrew the fixing nut by turning it CLOCKWISE with a 17 mm wrench while holding the axle steady with by a 5 mm Allen key.
Quoted: 1572 Post(s)
Liked 643 Times
That's what I like best about Shimano. I know how to take them apart and I know I can get replacement parts to fix them. I've never found a free hub that I couldn't get apart, but I sometimes I haven't been able to find the parts I needed to fix them.
What size rim?
What size rim?
Quoted: 24 Post(s)
Don't Vision make their own hubs then?
What size rim?
Quoted: 24 Post(s)
I think I'm best off leaving Halfords to sort it out. Maybe I can ask them how to do it so I'll know next time. It's annoying because I usually do all my own maintenance. The only other time I got something done in a shop (which has since closed down) was to get a wheel trued.
Quoted: 24 Post(s)
I just sent off three emails asking for help: one to Vision, one to the place that my LBS sends their wheel work to, and one to the company I bought the bike from (although technically it's a different company). Once I actually get it off it should be an easy job, that's another reason why I was loathe to take it somewhere to be done.
Quoted: 24 Post(s)
The reply to my email to Vision came from FSA so they are obviously the same people. It said "Thanks for your e-mail, please send me a photo of the hub showing the U code as attached and one of the free hub so I can check the model for you and best advice?"
WTF is the "U code" , and how do I find it?
Edit: Never mind. He sent me a pic.
Quoted: 24 Post(s)
Originally Posted by Some bloke from FSA
Thanks for the photos, this free hub can be removed once the drive side cone nut has been removed with a 17mm cone spanner and 5mm hex wrench in the axle end
Quoted: 24 Post(s)
Something's not right here. It just won't undo the way they tell you to undo it in their video. That's how I was trying to do it in the first place and ended up stripping the axle! This pisses me off because it's supposed to be something simple to do, but now I've got to pay money for someone else to do it for me.
Quoted: 24 Post(s)
FSA guy says it's supposed to be undone anticlockwise! So why don't they tell people that then instead of telling everyone to undo all their wheels clockwise?? /facepalm
Quoted: 24 Post(s)
I did one not too long ago, and yes.. there is no info out there. The only thing that helped was an exploded diagram of the assembly. If yours is the same model i worked on, after removing the non-drive side ‘cap’, i applied heat to the drve side cap and it then screwed off (right-hand thread). I got stuck as after first removing the non-drive side the axle appears to be one piece.. but it isn’t.. and the drive side is extremely tight, and waaaay over-engineered. anyhoo.. i hope it helps
If you dont post high rez pics with good lighting we will not be able to help you.
the hub from both sides, at an angle. like the first pic in this thread.
no one in this thread is a mind reader so we have no idea how your hub looks like.
