Front end "suddenly" sways from right to left
Quoted: 12 Post(s)
Another simple possibility: Too much weight on the rear, not enough weight on the front. Such an imbalance can cause the front to wander. The corrective action of trail is not able to be put to good use as it could be.
It can be un-nerving to have two totally different bikes depending if the rack/panniers are full or not. The same effect can be caused by rider position. It's the center of gravity being too far aft at fault.
Try moving your seat forward or using your hoods/drops or get a longer stem. Or a combination to move the CG to a more central location on the bike. A loaded front basket would work too if that's how you use your bike anyway and don't want to adjust fit.
With a light front end, you may also be feeling the effect of literally levering the front end around from the torque generated between the seat that is in line with the frame centerline and the contact point on the pedals that are off set from the frame centerline.
Quoted: 12 Post(s)
It's easy to overthink these things. Before tearing things apart, check all the "easy" things you can first. To me, checking frame alignment is pretty quick and easy, just to tick that off so you don't have to worry about it. Same with examining for cracks (I do this whenever I clean my bikes).
Another simple thing: are the wheels aligned in the dropouts properly? How easy is it to get the wheel cocked after fixing a flat or swapping a cassette! Or maybe a QR slipped a little. It's the easiest fix in the world, and only takes a few seconds to check - and it's a lot easier than taking the headset apart.
I'm really curious now to see how this turns out
In the weekend I've dismantled the headset (it was a quick affair being it of the tapered and internal variety) found some crud on the lower bearing, cleaned and reassembled. Took me 20 minutes tops. This specific issue won't arise anytime soon, two months ago I've installed full mudguards.
I've also checked for cracks, there is none.
Now, there are good and bad news.
The bike now WANTS to go straight, but there is still a slight instabiility: it is like the front wheel was not straight, but when spinned on the forks she definetely is well within tolerances.
The front wheel seems to have some play though (going left and straight slightly while I am pedalling), not more than a couple of millimeters per side.
The front wheel also seem somehow "soft" when I pull it sideways, moving by maybe a couple of mm side-to-side (the rear wheel seems to be firmer)
The (slight) play does not seem to be due to loose bearings (I've repacked them two months ago) but to spokes tension...or maybe it is irrelevant.
The only thing I did not check is the rear wheel, but it seemed dead straight in the chain stays. Will check it later along with quick release tension
The problem is clearly manyfold, and the headset is just one part of the puzzle.
Quoted: 12 Post(s)
Now that you mention it, I've got a flat rear tyre a month or two ago, so this definetely needs to be checked.
The rear is a disc wheel on vertical dropouts, not so easy to drop in...especially when hastily done on a Parisian sidewalk in chilly winter.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 175 Times
Any recent change in tires? I’ve noticed that low quality tires can create the effects you’ve described. I’ve also noticed changes in handling when switching from one width of tire to another.
Quoted: 12 Post(s)
They are foldable 120 TPI tyres.
But maybe I did not remount the rear tyre properly...Even if this seems somehow unlikely.
Quoted: 2482 Post(s)
Liked 2,952 Times
While you had the headset apart, I hope you inspected the fork crown race and the upper and (especially) lower headset races for indentations. Seems to happen less on modern bikes, but it's still a possibility.
Quoted: 345 Post(s)
Liked 175 Times
Quoted: 12 Post(s)
All suggestions are welcome.
The only thing I have not checked thoroughly yet is the rear wheel, so maybe the tyre didn't seat completely inside the rim, or it is deformed, or the QR is loose, or it is not well centred in the dropouts...
Will check and report back.
Quoted: 2363 Post(s)
Liked 1,749 Times
Is the front wheel QR or nutted? Are the fork blades and dropouts aligned? Is the wheel centered (rim walls to relative to locknuts)?
Quoted: 12 Post(s)
the bearing seats were flawless : this is a recessed headset, so the "races" will correspond to the bearings. They were fine
Quoted: 12 Post(s)
2mm might as well be a light-year in this case. You'll never come close to a stable ride with this much play. To determine whether it's the axle/hub bearings or the spokes, put the bike on a stand and induce the movement with your hand. You should be able to tell quickly enough, when you move the rim, whether it moves relative to the hub, or whether the rim and hub move together relative to the axle.
The fork is a carbon fork (it seemed aligned to me)
The front is a disc wheel, with an Allen key QR.
I have another set of wheels, I will give them another go since the headset is now sorted.
I will check and report back on Wednesday.
Quoted: 12 Post(s)
Shimmy
Bottom bracket it's fine, I've checked it for cracks and there's none.
It's shimmy, speed wobble, whatever you want to call it.
After cleaning and readjusting the headset, the handling changed, going from very, very annoying to.... just annoying.
I've tried to ride no hands and voilà : Front end start to wobble, putting a leg on the top tube stops it.
I already experienced shimmy so I can recognize it for what it is.
IMHO Wheels and/or tyres are to blame, that's the only thing that has changed recently (since when shimmy started)
Apparently unevenly tensioneds spokes, fat or worn tyres can cause shimmy
Rding position/weight distribution* did not really change (and moving more weight forward did not seem to stop the issue).
Will swap wheelsest (one that never gave me issues) in the WE and report back.
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
Some motorcycles are very sensitive to tire changes, and some front-rear tire combinations have caused a shimmy in the handlebars as soon as they are mounted. Rotational balance doesn't appear to be a factor, but in some extreme cases it progresses to a full-blown tankslapper which is almost impossible to overcome. In some cases, changing the tire pressure has helped to mitigate the behavior.
For reference, I'm talking about a Goldwing here, which is a 900 pound motorcycle with a fairly relaxed headtube angle. it is generally quite stable with predictable handling, but some front-rear tire combinations seem to resonate and cause oscillation.
If I were a betting man, I suspect that swapping for a different wheelset will make a dramatic difference. For curiosity's sake, I would try swapping front, rear, and then both to see if you can isolate the issue to front or rear.
Dale, NL4T
Dale, NL4T
Quoted: 12 Post(s)
Beforehand I will pump up the tyres to see if a higher pressue reduces the issue.
Quoted: 12 Post(s)
How I currently install my disc calipers :
— First i loosely screw them on their support
— Then I install the wheel without closing the QR
— Secondly I depress the brake lever
— Then I screw the calipers
— and Finally I close the QR
I can Imagine that a bent rotor could place the front wheel not exactly centered in the dropouts, but mine seems dead straight...
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Not on the topic of solving the shimmy, but there is a flaw in your brake setup strategy. You should have your quick release clamped shut when adjusting your brakes. The wheel should be firmly in place with the axle firmly seated against the dropout. Having the wheel detached from the bike when you adjust the brake caliper will have no positive effects.
Quoted: 12 Post(s)
Quoted: 294 Post(s)
Liked 137 Times
Having said that, the other responses are correct. The QR should be properly closed before you tighten up the caliper bolts.
Dale, NL4T
Dale, NL4T
Quoted: 12 Post(s)
I don't recall you mentioning that the shimmy only happened during braking. Whether the disc caliper is properly centered or not should not impact riding while not braking, unless it is so far off that you're getting rub on the disk without applying the brakes. I'm fairly sure you would have noticed that in the first 10 feet of riding or the first couple of revolutions in the workstand, so I doubt that this is the issue.
Quoted: 4201 Post(s)
Liked 3,857 Times
So is the wheel now centered between the blades, or is the axle fully seated in the depth of the drop outs, or both? We see a LOT of forks that have one blade slightly longer then the other so a wheel install that relies on gravity to settle the position means that the rim is off center within the tops of the fork blades. Carbon forks are not immune to this is the slightest. Andy
AndrewRStewart
AndrewRStewart
Quoted: 12 Post(s)
Anyways, after swapping the front wheel for a different one, the problem persits, albeit to a different degree.
Will try to so swap the rear wheel during the weekend
Quoted: 6963 Post(s)
Liked 10,962 Times
Liked 3,857 Times
You align the fork best possible. Part of the process is to check splay (hub/axle not being on center WRT the steering axis) and blade lengths being the same (wheel sits fully up in slots and is centered between blades AFTER splay is corrected).
Carbon forks don't lend themselves to the bending (Oh, I mean cold setting) to correct splay but any fork I have seen will allow filing of a drop out slot deeper (or taller to shorten that blade effective length).
It is a false assumption that a molded fork (carbon) is going to be straight and well aligned. We hope it will be. We hope that the cost to create the mold convinces the maker to also take care about the mold's alignment and that the actual production is done in a competent way so that every fork pulled from that mold is also straight. But my experience with production bikes having carbon forks tells me otherwise.
Just because a fork is not straight does not meant that the bike will have shimmy. just because the fork is straight does not mean the bike won't have shimmy. Andy
AndrewRStewart
AndrewRStewart
