Shimano 105 brake hoods
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times
My daughter in law has a bike with Shimano 105 brake levers. It's reasonably old and the hoods have deteriorated to the point where she'd like some new ones. She dropped in to the local Giant shop and was told her best bet was to go online and order some for Shimano S6CO 105 brakes. Naturally, being modern brake levers, internet searches result in all sorts of numbers EXCEPT the ones specified.
So, WTF do I search for? Where can I get them online that sells to Australia? A direct link is probably best.
Thanks.
Thanks.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
That part number brings up zero results related to bike brake hoods.
Which series of 105?
!050/1051 = forget it, easier to buy a decent used set of levers on eBay.
1055/56 = Look on eBay, they come up from time to time.
Later 5500/5600/5700 = look for HUDZ brand brifter replacements, they will be easier to find than stock ones.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
You want replacement rubber hoods or the whole brake lever? If the latter, Tektros are cheap, easy to find, and twice as comfortable as any non-STI Shimano levers I have ever tried.
Quoted: 2026 Post(s)
Liked 1,096 Times
Are these just brake lever or 105 STI brifters? What model are they. The model number should be engraved on the back of the lever.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Try Fair Wheel Bikes
https://fairwheelbikes.com/cockpit-s...e-grips-hoods/
You have to know what generation 105. Are they 5700, 5800, etc.?
-Tim-
-Tim-
Grumpy Old Bugga
Quoted: 370 Post(s)
Liked 8 Times
She wants the hoods.
They're 105 brifters from, we think, 2007.
That number was given to her by a mechanic and you'd assume he read it off the levers or would hope he knew what he was talking about.
Thanks for the help. I'll keep trying to find her something. It's going to be slow because I only see her once a fortnight or so.
Bikes: Cannondale CAAD10 Team, Giant TCR
If you say it's from 2007, it's probably a 5600.
Try ebay: Shimano 105 5600 replacement hoods
hüdz are a nice replacement, available in different colors if she doesn't want boring black.
Grumpy Old Bugga
Quoted: 370 Post(s)
Liked 8 Times
Thanks mate. That's what I'd narrowed it down to. I've asked her to count the rear cogs to make sure it's a 10 sp though I'm pretty sure it is.
Thanks for the tip on the hudz having different colours though she'll probably go for the basic black (black and white bike).
Licensed Bike Geek
If you peel the outside rear of the hood forward, the model number of the shifter is embossed on the plastic shifter body.
