Removable cork grips--any way to do that?
Old 05-21-07, 09:24 AM
Katzenjammer
Utility Cyclist
I'd like to use cork grips on my old tourer, for the snazz factor if nothing else. But the only installation methods I've seen involve permanently mounting them with spray adhesive. Which doesn't appeal--I'd like to be able to remove them without destroying them!
Any suggestions?
Katzenjammer is offline
Old 05-21-07, 10:31 AM
Little_T
Little_T's Avatar
Bikes: Tunturi F600 & Rigid MTB w/ custom components
Um... double sided tape? That's all I can think of. I've only helped friends put on grips on their bikes, and it's been the pre-glued kind (tape surface on back). With a good quality doulbe sided (and thin) tape you should be able to recover the cork-grips (in theory). Make sure the doulbe sided tape is not torn easily. If there isn't any doulbe sided-special tape for grips, you could probably find it at a local hardware store. I remember that I've used a double sided, thin tape, verry sticky, with integrated thread-like fibers to make it very durable.
Little_T is offline
Old 05-21-07, 01:45 PM
Katzenjammer
Utility Cyclist
Thanks for the thought. It's one I had too, but discarded on the grounds that, to be removeable, the stickiness would have to be temporarily suspended (I squirt alcohol with a hypodermic needle to get regular grips to slip). I'll give the idea another look.
Old 05-21-07, 02:03 PM
robo
robo's Avatar
Bikes: 1990 Burley Bossa Nova, 1992 Paramount PDG-70, 1993 Specialized Stumpjumper, 2005 Jamis Dakar XC Pro, 2007 Rivendell Bleriot
Quoted: 28 Post(s)
Liked 5 Times in 3 Posts
If you're talking about cork grips (not cork tape) i think the somewhat delicate nature of the material means than they're a 'one time use' thing...
robo is offline
Old 05-21-07, 02:32 PM
Katzenjammer
Utility Cyclist
Grips, yes. And you might well be right. There's no intrinsic reason (that I can think of) why they couldn't be adapted with an internal sleeve so as to be removeable, but maybe they have such inherent fragility that it's just not practical. In which case, I'll use cheesy rubberoid grips--14 bucks a pop for snazz is a bit rich for my blood!
Old 05-21-07, 08:01 PM
clancy98
don't be so angry
clancy98's Avatar
golf supply store has double sided tape that releases with solvent or they have a water based tape also. mebbe that?
clancy98 is offline
Old 05-21-07, 09:31 PM
robo
robo's Avatar
Quoted: 28 Post(s)
How often do you remove your grips anyway?
robo is offline
Old 05-21-07, 11:32 PM
Stiggermein
Grip stops and bar ends? Something like this, perhaps? You would have to deal with them twisting a bit, though.
Stiggermein is offline
Old 05-22-07, 04:57 AM
Katzenjammer
Utility Cyclist
I'll look into the golfing tape thing.
I don't remove the grips all that often, but it seems that if I have to do it once, I have to do it a dozen times. Recently, having fun and games with the twist-shifters has been favorite. But on that bike I have rubberoid grips, so the needle-and-alc trick makes it all easy.
Old 05-22-07, 06:18 AM
clancy98
don't be so angry
clancy98's Avatar
https://www.golfworks.com/product.asp...FTG1_A_cn_E_17
clancy98 is offline
Old 11-09-10, 01:35 AM
monkeyography
I had rubber cement all ready to go when this method came to me. I've flipped my albatross bars upside down, and back, and upside down again, and back, so this is pretty well tested. Been riding on them for 6 months.
Wrap a layer of masking tape around the metal where the grips will slide on. Go round and round like you're wrapping drop bars. While you press on the grips, do a bit of twisting to work them on. If it's not firm enough, wrap another layer of tape and try again. I couldn't get the grips on with 2 layers. But 1 layer, plus a bit more at the beginning and end, makes it nice and snug. You can still rotate them if you try, but they're not coming off without you working them off.
Not my bars: helped someone else do this with their grips.
File Type: jpg
monkeyography is offline
smontanaro
Classic & Vintage
1
11-13-16 09:36 AM
IANative
Road Cycling
14
07-06-15 06:27 PM
1989Pre
Bicycle Mechanics
8
01-08-14 05:31 PM
TromboneAl
Bicycle Mechanics
10
03-17-11 04:23 PM
chico1st
Bicycle Mechanics
25
01-21-10 08:28 PM
