Wrap Pump in Foil
Bikes: 1997 Specialized M2Pro
Wrap Pump in Foil
I figure my pump (Road Morph) will last longer if it is protected from the elements. I started doing this when I used to have the pump on the underside of my down tube. This pump tends to corrode, and I like to keep road grit out of the moving parts.
I usually wrap it in plastic wrap, using rubber bands to keep it in place. But the wrap tends to come undone.
This time, I tried wrapping it in foil:
Seems to work so far, and looks kind of interesting. Hopefully there will be no metal-metal interface issues that will cause corrosion.
Wrap your frame that way, then tell everyone you built the frame yourself.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
How about an old larger tyre tube? Slip the pump in fold down the ends, slip a rubber band on them and clamp it in place. On the other hand, couldn't you rinse the pump off with faucet water after the rides where salt was on the roads, Al?
Bill
Bill
Semper Fi, USMC, 1975-1977
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
I used to have a hat like that.
Jeepers! Where are you riding?
My Road Morphs go out in the salt and slush all winter, and in the other three seasons are routinely doused in the northeast's infamous acid rain. After six years, they have no corrosion.
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
This will probably keep the parts together when they fall off the pump. The morphs had a bit of a reputation for the head parts coming undone due to vibration and not being there when you needed them. You have been warned. Check for tightness every now and then.
Liked 6 Times
Al, is that a Sirrus or an Allez?
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Wrap pump in foil, sauté over Prolink and bake at 350 for one hour. Garnish with finely chopped cable housing.
Sounds pretty good, really. Definitely low carb.
Momento mori, amor fati.
It's a 1997 M2 Pro.
My road morph has been problematic. Something corroded (nut holding flip out foot thing on?), and parts have come loose. And while I'm *****ing, I can't see the gauge without stopping pumping, and putting my eye up close to it. Color coding for the different pressures would work well here. It's a love/hate thing.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Mountain Morph lives in a Fastback Pump Pack on our tandem. Along with patches and tire levers. Like-New-Condition after two seasons.
https://www.t-cycle.com/Merchant2/mer...y_Code=FB_Pump
Not as aesthetically pleasing as aluminum foil, though.
Quoted: 3242 Post(s)
Liked 2,089 Times
Well, OK, I forgot that I have a Morph and as it's on my commuter/tourer, I'll wrap it.
But never on my steel road bike. I won't. I'm sorry.
Though I might take a picture while it's on my carbon and post over on the Pro Cycling or Road forum. They'll have collective heart attacks.
You do realize that the term Fred isn't fred enough for this !
Bikes: '07 Specialized Roubaix Comp, '88 Trek 400T, '88 Diamondback Ascent EX, '56 Raleigh Superbe, '73/60 Raleigh Sports
Liked 7 Times
Hope Homeland Security does not see this.
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
Yeah a 26x3 tube would hold it. It wouldn't fit in his pump bracket. But it sure would last longer than aluminum foil.
"He who serves all, best serves himself" Jack London
Bikes: Trek Domane 4.5, Trek 1500
Quoted: 20 Post(s)
Al, how long do your RoadMorph's last? I had one go bad after 4 years or so. I have had the current one for about 2 years now.
Dharma Dog
Bikes: Rodriguez Shiftless street fixie with S&S couplers, Kuwahara tandem, Trek carbon, Dolan track
You don't need to wrap it in anything. Just invert it. The handle part should be at the bottom. Water tends to collect at the bottom of the pump, so it's best to have the handle down. Most of the road crud that splashes onto the bottom bracket will also spray onto whatever part of the pump you have closest to the bb
With the old plastic Silca pumps, you needed to tape the top of the aluminum handle portion so water didn't run into the head. Silca pumps just didn't look right inverted, and water would tend to collect inside the handle if you attached it upside-down.
Luis
Luis
Foil should only be used for it's intended purpose ......to keep pie fresh!
