Remove Residue From Cork Tape
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
I put some new tape on my bars, but didn't wind it loosely-enough, so I didn't have enough when I got to the end, and had to remove it and start again. The only problem is that some of the adhesive stuck to the tape and now, when I put my hands on the bar, it feels sticky and is attracting dirt.
So, I need to know how to get the adhesive off of cork (ITM) without damaging it.
I tried dish soap, but it did not seem optimum.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
3M makes adhesive solvents as well as adhesives .
there is another kind for Medical adhesive tape, too.
Quoted: 83 Post(s)
I'd turn to solvents as a last resort. As you dissolve the adhesive, the absorbent cork will likely just soak it in deeper. I've found that packing tape can be a good way to get sticky adhesive off. Loop a piece of tape around your fingers sticky-side out and then touch it to the sticky spots and lift. It often takes a lot of repetitions, but a little more of the goo will stay on the packing tape each time. Rotate the tape around your fingers to get a fresh surface as needed. Takes some patience, but basically zero risk so it's the first thing I try.
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
GooGone or another citrus based cleaner should do the trick without harming the cork.
Standard Member
Liked 940 Times
Kop, I am going to try that! Cool! I was concerned about the cork absorbing any chemical I might use, because my bike is near my bed and I don't want to be inhaling it for like the next 4 weeks.
If it doesn't work, I'll maybe keep trying with the Dish Safe, or maybe, as a last resort, go with
the Finish Line Citrus De-Greaser. Thanks also, Fiets, Satan.
Bikes: Spec Roubaix, three Fisher Montare, two Pugs
Quoted: 39 Post(s)
I'd try some Goo Gone on a small area on the underside and see if it's a problem. I'd also dust an area with talc powder or fine dirt. If the former works you'll have nice clean tape. If not, the latter will result in tape that isn't sticky and the imperfect areas will soon wear off.
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
I'm liking your style. Had a friend back in the seventies who had an old slant-six Dodge Dart that leaked oil from the intake manifold. He kept topping it off with new oil, and after about 5 years, the old dirty oil which he never changed sealed up the leak.
Mike J
Quoted: 392 Post(s)
Liked 6 Times
